Go Back   WattFlyer RC Electric Flight Forums - Discuss radio control eflight > R/C Electric Topics - General > Humor
Humor Have some funny jokes or stories? All is fair game except political, religious or too explicit.
Old 12-02-2011, 02:27 AM   #1
Default Tool Shop Definitions
Tool Definitions:
DRILL PRESS: A tall upright machine useful for suddenly snatching flat metal bar stock out of your hands so that it smacks you in the chest and flings your beer across the room, denting the freshly painted project which you had carefully set in the corner where nothing could get to it.
WIRE WHEEL: Cleans paint off bolts and then throws them somewhere under the workbench with the speed of light . Also removes fingerprints and hard-earned calluses from fingers in about the time it takes you to say, "!"
SKIL SAW: A portable cutting tool used to make studs too short.
PLIERS: Used to round off bolt heads. Sometimes used in the creation of blood-blisters.
BELT SANDER: An electric sanding tool commonly used to convert minor touch-up jobs into major refinishing jobs.
HACKSAW: One of a family of cutting tools built on the Ouija board principle. It transforms human energy into a crooked, unpredictable motion, and the more you attempt to influence its course, the more dismal your future becomes.
VISE-GRIPS: Generally used after pliers to completely round off bolt heads. If nothing else is available, they can also be used to transfer intense welding heat to the palm of your hand.
OXYACETYLENE TORCH: Used almost entirely for lighting various flammable objects in your shop on fire. Also handy for igniting the grease inside the wheel hub out of which you want to remove a bearing race.
TABLE SAW: A large stationary power tool commonly used to launch wood projectiles for testing wall integrity.
HYDRAULIC FLOOR JACK: Used for lowering an automobile to the ground after you have installed your new brake shoes, trapping the jack handle firmly under the bumper.
BAND SAW: A large stationary power saw primarily used by most shops to cut good aluminum sheet into smaller pieces that more easily fit into the trash can after you cut on the inside of the line instead of the outside edge.
TWO-TON ENGINE HOIST: A tool for testing the maximum tensile strength of everything you forgot to disconnect.
PHILLIPS SCREWDRIVER: Normally used to stab the vacuum seals under lids or for opening old-style paper-and-tin oil cans and splashing oil on your shirt; but can also be used, as the name implies, to strip out Phillips screw heads.
STRAIGHT SCREWDRIVER: A tool for opening paint cans. Sometimes used to convert common slotted screws into non-removable screws and butchering your palms.
PRY BAR: A tool used to crumple the metal surrounding that clip or bracket you needed to remove in order to replace a 50 cent part.
HOSE CUTTER: A tool used to make hoses too short.
HAMMER: Originally employed as a weapon of war, the hammer nowadays is used as a kind of divining rod to locate the most expensive parts adjacent the object we are trying to hit. It is especially valuable at being able to find the EXACT location of the thumb or index finger of the other hand.
UTILITY KNIFE: Used to open and slice through the contents of cardboard cartons delivered to your front door; works particularly well on contents such as seats, vinyl records, liquids in plastic bottles, collector magazines, refund checks, and rubber or plastic parts. Especially useful for slicing work clothes, but only while in use.
SON-OF-A-B****H TOOL: Any handy tool that you grab and throw across the garage while yelling "Son of a B****H!" at the top of your lungs. It is also, most often, the next tool that you will need.
Old 12-02-2011, 04:55 AM   #2
con244
con244's Avatar
You know I think i've used just about every tool for it's definitive use. Probably lucky I've still got all my fingers and both my eyes.
Con
con244 is offline
Old 12-02-2011, 05:23 AM   #3
TLyttle
TLyttle's Avatar
Friends: (4)
Wow, I second that! I've seen just about every catastrophe outlined in the OP. The drill press was one of the worst: guy drilling a 1/2" hole in a bar, good curl off the bit, he bent down to have a look at his progress, and the curl caught his lovely locks. It took a long while for that patch to grow back...
One power tool missing on the list is the planer/jointer: same as table saw, except for its ability to develop micrometer slices of finger far faster than anyone thought possible.
How can you tell a retired farmer? He's the guy that gives you a High Three...
TLyttle is offline
Old 12-02-2011, 04:47 PM   #4
CNY_Dave
I always thought the acetylene torch was the tool that sent a white-hot glob of metal into your ear to clean the wax out, while you were cutting off an exhaust system while lying on the floor?
Dave
CNY_Dave is offline
Old 12-03-2011, 03:11 AM   #5
Love my Stinger
Fishbonez's Avatar
Send a message via AIM to Fishbonez Send a message via Yahoo to Fishbonez
Friends: (16)
LOL I am sending that to my Vehicle Maitenance Shop
I think I agree with every definition there especiallt the Oxygen Acetlyne Torch. Oh how many times that has happened
Happy flying may your crashes be limited and if they are not limited let them be cool.
Fishbonez is offline
Flyers, Hobby Shop near? Dr Gyro Off Topic Chit Chat 0 11-12-2011 08:10 AM
For Sale 3D Hobby Shop EBT Trainer - ARF rckowal Airplanes - Electric For Sale & WTB 2 07-12-2011 03:09 PM
Ever use your charger to charge power tool batteries? SpaceFuzz Batteries & Chargers 5 07-11-2011 04:51 PM
Tim Tool Time Taylor would be proud earthsciteach Off Topic Chit Chat 2 05-27-2011 12:42 AM
Page generated in 0.06982 seconds with 27 queries
