| RC Radios, Transmitters, Receivers, Servos, gyros Discussion all about rc radios, transmitters, receivers, servos, etc. |
#1 | ||
Its got a speed 600 motor with belt drive, weight will be around 3lbs, span of 53", and I have a brushed esc good for 35 amps. My question is, what about these old airtronics servos? Would you trust them? And if so, can I simply grind off the extra tabs and plug them in? My preferred option for a receiver is a gws (futaba trans), only beacuse I have it already. I've never used standard sized servos with a micro receiver. Will this be ok? Or, should I try using micro servos in this beast? |
#2 | ||
Friends: (9)
The really old Airtrinics servos are wired differently. Does the plug look like this? If so it is NOT compatible without an adapter.
Here is an adapter: http://www3.towerhobbies.com/cgi-bin...?&I=LXLX67&P=7 |
#3 | ||
Thanks, that's them. I may see if I have enough dead servos to just clip off and solder some new connectors onto the airtronics.
#4 | ||
Friends: (281)
Originally Posted by k-vette
you may be able to just use a pin and remove the wire connector from the plugs and use a plug that will fit your radio system
http://www.fatlion.com/sailplanes/servos.html Servos and How They Are Wired Some of the in's and out's of Servo Wiring... About 1991 or soon after, most of the major brands of analog servos became compatible with each other. When this happened, you can use any of these brands of servos with any brand of receiver, but you must be careful about the polarity of the wiring. Some brands of servos are really great for a particular use in a particular plane, and there are other companies that sell their servos with each different manufacturer's connector installed (you just have to ask for what you want). You can mix Futaba servos with an Airtronics receiver, mix Hitec & JR servos with a Futaba receiver, etc. as long as you are careful about polarity. In Futaba, Hitec, and JR Radio servos, the servo and battery connections have the same polarity (+/-) and signal wiring, although the connectors are slightly different. One thing to remember: You can't reverse the direction of a servo (reversed servo) by just swapping (+) and (-) wires. If you do, you'll burn out either the servo or the receiver or both. If you're really good at soldering very small wires, you can reverse the normal direction of servo by swapping the wires that connect directly to the servo motor inside the servo case as well as the little servo wiper that moves as the servo moves. However, it's a lot easier to buy any of the newer radios; even the cheaper, standard radios these days have servo reversing as a built-in feature of the transmitter. Because Airtronics received so much bad press about the fact that their servos had reversed polarity (+/-), in December 1997, Airtronics started shipping servos with the optional "Z" connector that mostly matches the connector found on JR Radio or Hitec servos (or other brands). This means that if you have a Airtronics servo with one of the "Z" connectors, you won't have to switch (+) and (-) wires to use that servo with Futaba, Hitec, or JR, or other receivers. If you want to switch the wires around, almost all the connectors have little tabs or pins that you can push with a small pin to remove the wires and push them back into the connector in the right place. For Airtronics servos with the older, non-"Z" connector, follow the diagram: For Futaba, JR, & Hitec servos (or servos WITH the Airtronics "Z" connector), use this diagram: If you are handy with a razor knife, you can get all the brands of connectors to fit each other. I usually cut off the little flat tab on the Futaba connector to get it to fit in a Hitec or Airtronics receiver. You can also cut off the three little 'teeth' on the Airtronics connector to get it to fit in another brand's receiver. Some of the Airtronics servos have white colored wires for the 'Signal' wire, so it's easier to determine which black wire is (+). I can't emphasize this enough, just be sure that if you connect Airtronics with the older (non-"Z" connector) to any other brand, that you reverse the (+) and (-) wires as you will burn out either the servo, receiver, or both. I usually wrap all my servos that I've converted to Airtronics polarities with a little 'band' of bright blue tape to remind myself that the servo is setup as an Airtronics servo. Lots of people are now asking, "What is the difference between analog and digital servos?" The motor of an analog servo receives a signal from the servo amplifier (inside the servo) at 30 times a second. This pulsing signal tells the servo motor when to start rotating and which way to rotate. Since it only happens 30 times a second, that's the minimum reaction time. Digital servos use a higher frequency amplifier that sends a signal to the servo motor 300 times a second (or sometimes more on very fast servos, such as those used for helicopter tail rotors). Since this signal is received by a digital servo's motor more often, it is able to react much faster and hold its position better. This means the servo has better centering and considerably higher holding power. This power comes at a cost, however, as digital servos tend to draw a lot more power from the on-board battery which means your battery just won't last as long. There are also different types of servo motors available: cored, coreless, and now brushless. You can read definitions of brushless, coreless, and cored servo motors in the glossary. Below are the four standard connectors that are used by the 'big' four radio manufacturers (other manufacturers or third-party servo makers, such as Cirrus, use the Hitec standard): For a listing of most the servos that are generally in use today and their specifications, click THE GIGANTIC SERVO CHART. |
#5 | ||
Thanks, it didn't occur to me that I might be able to swap pins without cutting and soldering. I'll try that first!
#6 | ||
Friends: (9)
Been a long time - but I am pretty sure those old Airtronics pins are too large and a bit different than the universal ones today. Check carefully! I would just cut and solder personally.
![]() Mike |
#7 | ||
Pilotpete2
No problem with the pins, back when the "old style" ATX plugs were still in use, some suppliers of ESCs and servos included one of the old style ATX plug housings and instructions on how to switch over the wires from the JR/universal plug on the device. It wasn't until I switched over to 2.4Ghz that I finally got away from the old ATX stuff for good. It's one thing to convert the old ATX servos over to on modern receivers. It's another thing to rewire a modern servo to accommodate the reversed +/- bus positions on the old ATX receivers. You can do it, but it's not a matter of will you smoke a servo, only a matter of how long it will take you to plug one in 180dg. out. This is not based on theory, but personal experience
![]() ![]() Pete |
"If the women don't find you handsome, they should at least find you handy"
Red Green |
#8 | ||
Originally Posted by rcers
The pins are fine. It's the thickness of the plastic body.
In many of the compact receivers you may need to sand down the thickness of the plastic to allow the servo-connectors to fit side-by-side on adjacent-sets of rx pins. |
#9 | ||
Friends: (16)
Some of the newer servos can be pretty cheap, like $10 each or less.
#10 | ||
If they are old enough you might find a very nice feature that seems to have gone away over the years. If you remove the screw for the wheel/arm, there used to be the slotted end of the pot shaft that could be turned so the centering could be adjusted there. It offers all kinds of options.
| Let's talk about servos - Whatever is on your mind | AEAJR | Beginners | 188 | 02-19-2013 08:51 PM |
| Sold Six- HiTec HS-65HB Servo's | dumpsterjay | Radio Equipment For Sale & WTB | 2 | 05-20-2011 02:22 AM |
| 3S or 4S Battery Question(s) | RCFlyer44 | Power Systems | 22 | 03-29-2011 04:55 AM |
| For Sale Aluminum Servo Mounts for 5g and 9g Servos !NEW DESIGN WITH MORE COMPATIBLE SERVOS! | terrynshed | Radio Equipment For Sale & WTB | 0 | 02-04-2011 08:33 AM |
| For Sale Aluminum Servo Mounts for 5g and 9g Servos | terrynshed | Radio Equipment For Sale & WTB | 0 | 11-19-2010 07:48 PM |
