Go Back   WattFlyer RC Electric Flight Forums - Discuss radio control eflight > R/C Electric Topics - General > Flight Simulators
Flight Simulators Discuss computer flight simulators here
Old 12-07-2011, 03:59 PM   #1
Swanj
Swanj's Avatar
Location: Jamestown California in foothills of the Sierra Nevada mnts.
Club: www.sonorarcflyers.com
Default Have a Pheonix flt sim throttle problem.. Help needed
Hi to anyone that has the Pheonix flt sim..
My simlator has worked great since it was installed. I now have a problem with the Throttle adjustments.. At no power setting with throttle stick in down position it does idle. AS I more the stick up towards mid way throttle, there is no increast in power or rpm. as soon as it hits half way, it goes to full throttle and remains at full throttle, untill I drop it back to idle position.
Is there an option in the menu system to set the throttle to be linear thru the power settings.
Any Help of advice wouldbe appreciated!!
Swanj.. calif
I may not be the best at what I Do! But, if I try my best, I certainly won't be the Worst !
Swanj is offline
Old 12-07-2011, 05:42 PM   #2
newjak
AMA Park Pilot Partner
newjak's Avatar
Club: Central Delaware Parkflyers Association
1kW
Friends: (13)
Have you tried to re-calibrate your TX? It is under the system menu. scroll down to "your transmitter" and then hit calibrate.
A.M.A Park Pilot Partner / Wattflyer Mentor
newjak is offline
Old 12-07-2011, 06:32 PM   #3
Swanj
Swanj's Avatar
Default My Pheonix flt simulator problem
thanks Newjack..
Yes ! I have tried calibrating my DX6i for throttle changes with no luck. I also tried my other transmitter that works with Pheonix. it is the LP5DSM transmitter. it is an early version, and doesn't have any options to change settings within it. Both tranmitters are made by Spektrum also! When I first installed the Pheonix flt sim, the throttle worked just fine. But somehow something got changed. I will do more searching thru the Transmitter menus.
Thanks Again Newjack
Swanj.. off searching and clicking buttons, etc.till I find the problem!
Ps: I have also uninstalled the Pheonix, and re installed it to no avail!:-(((
Swanj is offline
Old 12-07-2011, 06:43 PM   #4
newjak
newjak's Avatar
1kW
Friends: (13)
I have had that problem before. Sometimes I switch the TX that I use on Phoenix. There are 2 DX6/DX6i TX profiles. Have you tried both? Are your TX trims set neutral when calibrating? If nothing else works you mave have to use a fresh memory slot on your TX and go from there.
newjak is offline
Turnigy Plush 10A ESC - throttle setting problem mclarkson Power Systems 5 08-22-2011 10:30 AM
Page generated in 0.15070 seconds with 25 queries
