Old 12-21-2011, 01:01 AM   #1
CanCanCase
CanCanCase's Avatar
Default UMX Beast battery (EFLB1802S20): how to charge?
The battery for a UMX Beast is an e-flite EFLB1802S20. I broke their top-secret part numbering code to interpret that part number as a 180 mAh, 2-cell, 20C discharge rate LiPo.
Here's where I get confused. I've always known multiple-cell LiPo packs to have a balance lead and a discharge lead. This pack only has a single lead with red, white and black wires. It LOOKS like a balance lead to me!
I really want to avoid buying yet another charger designed to suck another $20-$40 out of my wallet and only charge one specific battery for one specific airplane.
Can anyone identify the connector and possibly a manufacturer part number for a charging adapter? I need to get from the banana-jack outputs on my Triton 2eq charger to this little battery with its single unusual lead.
Thanks in advance!
-Case
NO ADVERTISING ALLOWED! (But you can ask me what I do...)
CanCanCase is offline
Old 12-21-2011, 02:28 AM   #2
Past President of PSSF
Friends: (8)
Your battery has a 3 wire lead, that indeed is all that is necessary to hook it to a balancing charger, IF that same charger is capable of charging through the balance leads.
Your battery has only the one lead, because the load that will be put on it is less than 3 amps, which is what most companies agree the balance leads can handle, either charging or draining.
But I am sorry I can't identify the connector, or tell you what adapter you need.
Dave R, Proud PGR rider.
http://www.pugetsoundsilentflyers.org/
Wildflyer is online now
Old 12-21-2011, 06:12 AM   #3
TheWoodCrafter
Can't help you with a connector either but your charger better be able to charge through the balance connector or you will run into some trouble.
Not all chargers do.
I know my iCharger will not work.
TheWoodCrafter is offline
Old 12-21-2011, 07:04 AM   #4
flydiver
flydiver's Avatar
View flydiver's Gallery1
Outstanding Contributor Award
That's a stock balance connector, probably jst-xh. You need a charger that works ONLY through the balance tap. Some of the cheap ($5-10) low rate chargers will do this or a Cellpro 4S.
Don't think your Triton will as it appears to charge through the main leads and balances though the balance tap.
You don't have the stock charger?
fly
flydiver is offline
Old 12-21-2011, 04:33 PM   #5
CanCanCase
CanCanCase's Avatar
Originally Posted by flydiver View Post
...You don't have the stock charger?
Look at the new UMX Beast 3D at Horizon... they've pulled the battery and charger that usually come with the UMX planes from the box - I presume to keep the price down. With the gyro/stabilizer thingy (AS3X) there's a LOT going on in this little plane! All that comes in the box is the plane, manual and a spare prop.
What about something like this?:
from rc-connectors.com
-Case
Old 12-21-2011, 04:46 PM   #6
flydiver
flydiver's Avatar
It says it will.
[beast-F-to-XH-male-banana
$8.99
Charging cable for new UMX Beast battery, WITH banana jacks
Charge that stock Beast battery with YOUR charger
This is the Charger/Plane Side with 2.5" of 28 gauge wires, attached to a JST-XH lipo balance tap, plus extra wires into 4mm banana jacks
Note that the Eflite UMX Beast, Eflite UMX Sbach 342, and Parkzone UM F-27Q Stryker 180 use the same batteries and therefore the same battery connectors.]
If you have 2 batteries may as well get the double one. Isn't it fun how industry is constantly able to come up with non-standard BS devices to make our lives complicated?
fly
flydiver is offline
Old 12-21-2011, 04:56 PM   #7
CanCanCase
CanCanCase's Avatar
...Isn't it fun how industry is constantly able to come up with non-standard BS devices to make our lives complicated?
I know, right? After I got over the shock of an ultra-micro that didn't come with a battery or charger, I couldn't figure out who to blame for ruining my early x-mas... Horizon/e-flite for putting out a battery with only a balance lead? Electrifly/GreatPlanes for putting out a charger that won't charge via the balance tap? LHS for not pointing all of this out and not having any idea about a charge adapter?
Oh well, at least the SlowStick is flying again and I've got lots of colored Sharpie markers to make the plain white DW 40" Juka not so plain white while I'm waiting to fly the Beast!
-Case
Old 01-07-2012, 06:36 PM   #8
Sakai's Freedom Flight
aka: "Jim"
Sakai's Freedom Flight's Avatar
It says it will.
[beast-F-to-XH-male-banana $8.99
Okay. I'm terribly confused now. My Beast is in her box, too. But I have the old Beast 2S charger with non-standard 2S connector hook-up so should be okay (It won't fit other 2S chargers, I tried two and backed off fast).
Regardless, I put in a request to HH for a "universal charging system" that would include all the necessary hookups and leads and whatnot for PZ, Eflite and HobbyZone birds from 1S to 3S (why not 4S, too). I hope they make it. It will look like an artificial heart or something but this flyer would buy it and put it on the fireplace mantel.
...do not let the sun go down on your anger
--Paul, in Ephesians, ch. 4
Sakai's Freedom Flight is offline
Old 01-11-2012, 07:21 PM   #9
murmas
Default Cheap Batterie (2,56$) for UMX series flyers from HK
Hello everybody,
if you´re looking for a powerful and cheap batterie for UMX (2,56$):
hobbyking(dot)com/buddy(dot)asp?code=7F9EE6F4-DDD6-4E96-959D-6AF855FC6F40
Note: Login first on HC to get Your discount before clicking the ling above.
Regards
Andreas
murmas is offline
Old 01-20-2012, 11:34 PM   #10
CanCanCase
CanCanCase's Avatar
Wow... I didn't know WattFlyer allowed spam!
That does raise the question, however... what's everyone's favorite source for a 240 mAh 2S LiPo with that standard (but not JST-XH) balance tap connector pre-wired? I know Hyperion cells are the choice, but all I can find from them is a kit to wire up your own packs for the Beast... I'd much rather have a drop-in pre-made pack...
-Case
Old 02-04-2012, 05:00 PM   #11
everydayflyer
Southern Pride
everydayflyer's Avatar
View everydayflyer's Gallery13
Hyperion now has LiPolys with the UMX compatible connector as stock.
FYI The HK nano tech 2S 25C 180 mAh LiPoly with an everyday price of $5 are indeed very good ones.
My test here
http://www.rcgroups.com/forums/showthread.php?t=1584967
Charles
everydayflyer is offline
Old 03-27-2012, 06:26 PM   #12
supi7
TrueRC.com
supi7's Avatar
Default Charging harness
check out the new UMX charging harness for the Beast and the Sbach 342
They are available from TrueRC
Dan
TrueRC
supi7 is offline
Old 03-30-2012, 05:44 PM   #13
REVOJohn
REVOJohn's Avatar
Send a message via Skype™ to REVOJohn
I'd say you have no choice. Either get one of those cheap RC chargers or the connector CanCanCase mentioned.
CellPRO is probably the only node charger only that can handle your pack the way it is.
REVOJohn
Singapore RC Electronics Factory
Facebook: REVOLECTRIX
-- quality batteries direct online from Singapore --
REVOJohn is offline
Old 07-05-2012, 10:03 PM   #14
dre414
Hi all, I bought this battery hoping to use it for my micro RC car and saw your posts after I realized it had 3 wires.
May I ask if its possible to convert this battery (soldering the correct wires/connectors, etc) so that it only uses a positive and negative lead and a seperate balance lead?
Does it even need a balance lead? (the stock lipo for my RC car doesn't have a balance lead)
dre414 is offline
Old 07-06-2012, 01:07 AM   #15
Nitro Blast
Nitro Blast's Avatar
View Nitro Blast's Gallery45
Frankenstein Build Contest Award  100mph Speed Demon  3kW  1kW
Friends: (67)
Dre, balance leads are included normally anytime there is more than 1 cell.
However, if you find the first, and last tabs in the pack, you will have your pos and neg for total pack voltage. Those are the red (pos) and black (neg) leads. Use those directly for full pack voltage.
It is possible to solder onto those leads, but personally, I have never been successful in doing so.
Electricity... It's not just for light bulbs anymore.
GoProfessional Cases industry grade protection for your gear
Dinogy Lipos professional grade energy
Project Globetrotter Participant 7/09
Wings Across America Participant 6/10
Nitro Blast is offline
can the FMA PowerLab 8 v2 be used to charge the battery in use? miernik FMA Direct 6 10-21-2012 02:58 AM
Using car's engine to charge marine battery?? FlyWheel Batteries & Chargers 9 10-03-2011 05:14 PM
Introducing the ALL NEW Cellpro 10XP Charger Howard Matos FMA Direct 0 07-28-2011 02:04 PM
Page generated in 0.44520 seconds with 47 queries
