Go Back   WattFlyer RC Electric Flight Forums - Discuss radio control eflight > Electric R/C Airplanes > Warbird Electrics
Old 12-24-2011, 02:18 PM   #1
lou1984
Default Platt Dora 64" wood model -Power Ques?
Little help please or a lot a help
Just picked up a total steal , never been flown dave platt Fw Dora D9 , 64" span .
Question one --
Thinking of a Monster Power 110 , for this plane .
Want to add retracts and flaps so I am looking at aprox 7 channels
Any suggestions on power system and battery ?
Thansk
ID:	155758   Click image for larger version
ID:	155759   Click image for larger version
ID:	155760   Click image for larger version
ID:	155761   Click image for larger version
lou1984 is offline
Old 12-27-2011, 03:13 AM   #2
payne9999
That's gonna leave a mark
payne9999's Avatar
Club: Hillsboro Fly-A-Ways
How much does it weigh? Or, how much will it weigh with the retracts, radio and servos?
Dave
payne9999 is offline
Old 12-27-2011, 10:43 AM   #3
lou1984
Dave , thanks for the help .
So far with the frame , including the existing Robart heavy scale wheels its at 6.4 pounds that has the servos calculated along with a radio flight pack, receiver and 4 servos. Rudder , Elvator , 2 flaps , and current set up 1-alerons (internal belcrank).
If you figure
1)1lbs to 1.5 for the retracts depending on the brand (i am going eletric )
2)monster 110 is 17 oz
3)esc =3 oz
I think i am about 9.3 ready to go with no -lipos calculated , biggest weight gain is the motor .
If I go with a 60 size or 90 size motor , obviously I will lose weight but dont know the power needed yet .
The plane was designed around a 60 to 90 2 stroke , typically = 110 or 120 4 stroke
Would love to get away with less motor =less batterys but I dont really think I have a choice and I figure the Monster 110 = a 120 4 stroke
lou1984 is offline
Old 12-27-2011, 05:18 PM   #4
payne9999
payne9999's Avatar
Is the monster 110 you refer to the existing engine?
The general rule of thumb is 100 watts per pound of aircraft. However, for a fighter plane I like to have more but in reality I end up flying at less than full throttle most of the time. When I want to save myself from an unfortunate mistake or make that high speed low pass it is nice to have a little extra.
I am building a 53" Mustang right now and it is predicted to weigh about 5.5 lbs. ready to fly. It is going to have a .32 size equivalent electric motor with a 13X6.5 prop and a 3300mah 4S battery. It is 800 watts (predicted at full power) and that puts me at about 150 watts/pound. The 5.5 lbs. is the predicted all up ready to fly weight so that includes the weight of the battery pack and motor. Roughly 750 watts equals 1 horsepower.
If the original plane flew on a 1.1 motor that sounds like a lot of motor. Was it originally powered by a 1.1? I think the original design was for a .60 to .90 nitro engine. In that case you could start browsing for an equivalent electric motor. However, be aware, that size electric and the battery to support it can be pretty spendy.
After you find a .60 or .90 substitute do the math with the added weight of the battery and motor and see what the watts per pound comes out to.
There are probably many folks out there with mor experience than I have, we will see if anybody chimes in.
Dave
Old 12-27-2011, 05:34 PM   #5
payne9999
payne9999's Avatar
Are you sure this is not an old Top Flite model? They produced a 63.5" kit that is now out of production.
Here is a link to the original plans/manual for the Top Flite version:
http://manuals.hobbico.com/top/topa0150-manual.pdf
Old 12-28-2011, 11:56 PM   #6
lou1984
Thanks Payne , but it is the PICA 100% , I have built this kit in the past , this one was done and for sale .
lou1984 is offline
Old 12-29-2011, 12:00 AM   #7
lou1984
Model #:
Monster Power 110 (63M56)
Kv:
295Kv
Input Watts:
2000W
Resistance:
.03 ohms
Idle Current:
1.20A
Continuous Current:
55A
Max Burst Current:
65A
Cells Ni-Cd/Ni-MH:
24-32
Cells Li-Po:
8-9
Weight:
17.0 oz (480g)
Overall Diameter:
2.5 in (62.8mm)
Shaft Diameter:
.39 in (10mm)
Overall Length:
2.10 in (54mm)
This is the specs of the Monster 110 , it was ot the motor , the plane was never flown but I happened to have the Monster 110 and was hoping to be able to make it work .
lou1984 is offline
Old 12-29-2011, 12:20 AM   #8
payne9999
payne9999's Avatar
OK, Based on the weight of the plane that is more than enough motor. Do you have the 8-9S battery yet and if so what is the weight of the pack?
I think you will be OK with that motor but if you don't have a battery yet that size battery will cost a lot.
P.S. It looks like the battery will be 2.5 -~3 lb.s and a hundred bucks or more.....
Dave
"Gravity: Natures way of telling you to watch your airspeed"
Old 12-29-2011, 01:35 AM   #9
lou1984
Thanks Dave , this is what I have and I am looking at my options ,
I have 4 new in box 5000 mah 5s 45c 5 cell 18.5 voltz
I have two 3300mah 4S 25c 4 cell 14.8 voltz
Then for my 5500 mm small planes I have about 8 2200mah 4S1P 20c 4 cell 14.8 voltz
lou1984 is offline
Old 02-05-2012, 11:56 AM   #10
lou1984
well made some progress , by the purchased the batterys , going with 2x 4S.25/11936 Turnigy nano-tech 5000mah 4S 25~50C Lipo Pack
ID:	156968   Click image for larger version
Name:	Battery opening.jpg
ID:	156969   Click image for larger version
Name:	dora engine mounted.jpg
ID:	156970   Click image for larger version
Name:	engine off set presanding.jpg
ID:	156971   Click image for larger version
Name:	esp mount.jpg
Name:	esp mounted and attached.jpg
ID:	156973   Click image for larger version
Name:	fw190 tires.jpg
ID:	156974   Click image for larger version
Name:	fw dORA pLATT.jpg
ID:	156975   Click image for larger version
ID:	156976   Click image for larger version
lou1984 is offline
Old 02-05-2012, 12:05 PM   #11
lou1984
well finally has time to get back and as little and mundane as it appears it was about 4 hours worth of work lol .
1) i need to cut a opening in the second internal fuse support to allow access for batterys to move aft and to allow the batterys to fit . Ok challenge one is that it was balsa over a thick ply former , even my dremil could not get into the slot .
I had to cut a hole and then gradually grind the openeing .
2)Challenge two was that the existing servo rails would place the servos in a position to block the batterys from sliding back .The servos had to be turned on there side .
3)Challenge three was that the original builder solder the clevises on , so if you simple try to turn them the dowels would bind .
4)so the solution was cut the original clevises off , solder on new end that would allow adjustments without binding , then add plastic tubes on the existing pushrods at all friction points .
So a night of cutting , soldering , glueing , all for what should have been drop in servos !!!
Well with the exception of a simple battery tray and reinforceing the battery /firwall box the fuse is done and will be preped for repainting .
Now onto the wing , will be cutting in flaps and retracts , yippie wonder whats in store for me
Name:	servos instalations.jpg
ID:	156978   Click image for larger version
ID:	156979   Click image for larger version
Name:	pilot update.jpg
ID:	156980   Click image for larger version
Name:	Fw first pass.jpg
ID:	156981   Click image for larger version
Name:	FW dash 1.jpg
ID:	156983   Click image for larger version
Name:	hatch reattached.jpg
lou1984 is offline
Old 02-05-2012, 12:09 PM   #12
lou1984
If anyone knows the proper colors of German Pilots jackets ect , appreciate the help , mine appears to be an american who has hijacked the German fighter , while interesting in the movies , not so at the flight line lol !!!
lou1984 is offline
Old 02-05-2012, 09:10 PM   #13
foodstick
I have this exact plane built, and wanting to convert it. I never mean't it to turn into a hangar queen, but it got stored and forgotten.. Now with the electric possibilities it will be flown ! Unfortunately I butchered the top of the cowl when I installed the intended motor.. SO, I am thinking of making a two piece cowl to install the battery thru the firewall from the front !
I am real excited to see your thread on here.. possibly it will get me going on mine as well.
Unfortunately I have fixed gear, but its still great looking with the gear down.
Anxious to follow your conversion.
foodstick is offline
Old 02-05-2012, 10:37 PM   #14
lou1984
Hey thanks for the interest I know at times its difficult for some to post comments because the kit is long gone but its great to hear questiions and comments .
Mine has fixed gear as well and I plan on adding retracts , am I asking for some major surgery ?
So far every step of the fuse has been some big time cutting but its so worth it .
I am also adding flaps , do you have flaps on yours ?
Last comment , the cowl is an easy fix , i had to patch and fill cowls many times so let me know if you need help
lou1984 is offline
Old 02-06-2012, 01:37 AM   #15
foodstick
Well I actually went down and started making the new firewall and working on the cowl tonight.
I am going to have to do major repair on the top of the cowl, so I thought I would try to make a nice top that comes off of it.. I just couldn't stand to cut the gun section on the fuse. I am really hoping to be able to load a 6 cell 5000 from the front.. By just simply removing the top of the cowl...
The sad thing about my plane is that I got it third hand from a guy.. he had stripped the landing gear out of it.. But I was cheap and just built in fixed gear....what a mistake ! Oh well it was a lifetime ago.
I will tell you a funny story though, when I got my plane it was METALIC PURPLE MONOCOTE !! I kid you not..
Ha hahahah, I stripped it down and covered it with a fabric and painted it. I have some history all the way back to high school with art, so it was my second scaleish paint job.. and I have always been happy with it...
Old 02-06-2012, 01:44 AM   #16
foodstick
Finally got some pictures taken...
ID:	157010   Click image for larger version
ID:	157011   Click image for larger version
Old 02-06-2012, 01:46 AM   #17
foodstick
Forgot the butchered cowl shot... rats! why did I do it? hahaha, it will repair but wish I had left it uncut.
Old 02-06-2012, 02:03 AM   #18
lou1984
cool paint job !! You will notice on mine its missing the plastic parts , I bought mine built for a steal , I just ordered the plastic parts and got them from Top Flight , while not exact size its close enought .
On the cowl you can fix that . You take plastic , (thick , sand it so that CA will stick to both the plastic and inside cowl.
The most important thing is to get the initial plastic sheet to stick , you can even cut curved plastic from a coke bottle or your favorate beverage .
After glued you mix micro balloons with some 20 mins expoxy , more of the micro ballons , you fill the seem and smooth it as you go along like your are applying puddy to tile , your goal is to simply blend the seems that will eventually be sanded flat into one level surface
lou1984 is offline
Old 02-10-2012, 11:55 PM   #19
foodstick
I just noticed , we both are showing as Yellow 15 !! hhahahah Mine isn't based on any real plane I think? I used to always pick different markings and mix and match..
I am not sure if you had seen my own conversion thread here.
http://www.wattflyer.com/forums/showthread.php?t=65647
Didn't want to hi-jack your thread...
Old 02-11-2012, 02:52 AM   #20
lou1984
Hey Foodstick , great mods your making , you can post in this thread at any time you want . I dont live in any drama buddy , we all love RC and any post is a great post when you on the same subject .
I love this plane and how its turning out .
I have some major work on the wing with the retracts ect . I ordered 80 degree retracts for $69 bucks from Hobby King , there Turnegy that are relabled -RC Landers
I know the plane takes 74 degree from Spring Air but I know I can get the look from 80 degree as well .
Hobby King is so backloged I dont know when I will get my gear and batterys
lou1984 is offline
Old 02-11-2012, 02:53 AM   #21
lou1984
hey Food , if you need a spinner check out sdnhobbies , I should have mine by Saturday , prepainted
lou1984 is offline
Old 02-11-2012, 03:02 AM   #22
foodstick
I will be interested to see how your retract swap goes.. Unfortunately I ampretty sure when I installed my fixed gear I REALLY put those blocks in there...
believe this or not but I THINK, I have an actual metal spinner made by pica for this kit. however when I look at it I think I might have cut it wrong 20 years ago.. I was pretty noobish then
The spinner is so big I think it will keep the motor from getting any air...
Old 02-11-2012, 04:58 AM   #23
foodstick
Lou, I forgot to add, do you have the balance point on the 190?
I have been chasing balance points for old planes of mine all winter.. I guess i should be glad my planes lasted longer than the plans did !
Old 02-11-2012, 10:02 AM   #24
lou1984
On the spinner I expect it to arrive today , received notice from the post office yesterday and will pics so you can see if you like them .
The retracts ... well I expect major work lol . I bought a seafury 66" about 7 years ago , I acutually burned our my dremil cutting the rails .
My plane is as follows , remove existing gear legs , carefully open the wing and I will have to cut out the entire ply rail . The reason is that the retracts houseing will need the space that the rail play rail takes up .Now I have not even seen the inside wing , experience tells me what to expect .
Ideally if I get lucky , I can remove part of the rails and run new play wing ribs inside the cut wing rails , but i dont think that will happen .
I have a contour gauge and that will be my tool of choice to replicate new wing rails .
The CG , I will check to see if I can find any refferance in my paperwork received with my plane , however I never use stock CG anyway . I use 25% of MAC (always ) and have never had a bad maiden as a result of bad CG .
I know the plane will not need flaps , but its the voice in my head saying "you need flaps " lol , its work but I want to be more scale .
If you check out my blog on RC groups , you will see my FW190 bash 71" span , its under LDM . I added split flaps , full scrtach built interior , air powered sliding canopy , functional pilot moves with rudder , all the gear retracts , home made inner gear arms ect , lets just say I get carried away .
I wont do that with this plane because its was build so well by the original builder that its not easy to cut anything !!!
lou1984 is offline
Old 02-12-2012, 01:22 PM   #25
lou1984
Magnets are now on the hatches , there so tight I can barely open the lid lol , the batterys will be strapped in with velcro straps to the base .
The magnets will simply allow easy access .
The biggest challenge is still the motor shaft , if I use the Kyosho spinner i will be ok , but this new medal spinner seems more appropriate to the monster 110 , if I can not find a solution then I will simply use the Kyosho .
The easy option is to attempt to change out the prop shaft with a smaller shaft that has the 4 universal screws that fit the monster 110 , or attempt to tap the monter 110 prop shaft to adapt the spinner bolt directly but that means getting a tap dead center and that will not be an easy task .
I was amazed that in all my fuel engines how small the prop shafts are , I am thing at looking in the gas engine but G26 even has a smaller shaft then the monster 110 , funny thing is even my Giant Turengy motors that are equal to 4 stroke 150 have smaller shafts then then Monster 110 , I tried switching them over but the screw holes are differant
ID:	157221   Click image for larger version
Name:	motor prop nut 2.jpg
ID:	157222   Click image for larger version
Name:	motor prop nut.jpg
ID:	157223   Click image for larger version
Name:	latch magnets.jpg
ID:	157224   Click image for larger version
Name:	latch magnets inside.jpg
Name:	fw190 soinner comparison.jpg
ID:	157226   Click image for larger version
Name:	Fw190 spinner.jpg
lou1984 is offline
Everything You Wanted To Know About Electric Powered Flight AEAJR Beginners 165 06-28-2017 04:22 PM
What's a Good Model for this Power Unit? poiyt General Electric Discussions 2 08-27-2011 03:51 AM
Page generated in 2.78696 seconds with 103 queries
