Old 12-31-2011, 12:25 PM   #1
max2112
max2112's Avatar
View max2112's Gallery80
Globetrotter Pilot
Friends: (13)
Default P-51D House of Balsa 1/10 kit Build Thread
Well, gang, I've been sitting on this kit for several years and I finally decided that it is time to brush the dust off of the wax paper and push pins.
I've only done one other kit build before and it was a much simpler design, so I will post up progress good or bad, warts and all. Please feel free to join in, give advice and ask questions. Here we go!
House of Balsa kit - Nick Ziroli design
46 1/2" wingspan
33 1/2" length
AUW in manual 38 ounces
Will probably go with a .10 size motor.
Please call me John. I came up w/ Max2112 when I thought you were all internet predators after me Lucky Charms!!
max2112 is offline
Old 12-31-2011, 12:28 PM   #2
max2112
max2112's Avatar
Globetrotter Pilot
Friends: (13)
Default Stage 1: Right wing.
The plans are nice and well laid out. The included Instruction Book is Fantastic. Color pictures and step by step instructions make this kit very user friendly.
Here's a couple pictures of my progress so far.
ID:	155914   Click image for larger version
ID:	155915   Click image for larger version
ID:	155916   Click image for larger version
max2112 is offline
Old 01-01-2012, 10:42 AM   #3
max2112
max2112's Avatar
Globetrotter Pilot
Friends: (13)
Default More progress on the wings.
Got to work a bit more on the wing yesterday. Again the plans and instruction book are very thorough and anything that might be a little bit tricky has it's own special note or picture.
I love building. It is so relaxing to get all the pieces for the next steps sanded smooth , dry fitted, pinned and glued. Here are some more pictures.
ID:	155947   Click image for larger version
ID:	155948   Click image for larger version
ID:	155949   Click image for larger version
ID:	155950   Click image for larger version
max2112 is offline
Old 01-01-2012, 10:47 AM   #4
max2112
max2112's Avatar
Globetrotter Pilot
Friends: (13)
Default Right Wing Complete
More pics.
ID:	155952   Click image for larger version
ID:	155953   Click image for larger version
max2112 is offline
Old 01-01-2012, 11:12 AM   #5
max2112
max2112's Avatar
Globetrotter Pilot
Friends: (13)
Default Left Wing & Wing Assembly.
Even though these pictures are coming pretty fast, the build has taken me about 13 hours over three days. We just got back from celebrating New Years Eve (Happy 2012 my WattFlying Bubs!) and after I post these pictures up I am ready to start on the fuselage and body.
The left wing went together just as easy as the right. Oddly enough, I did a better job on the right one. I think it was because I didn't stop until about 0315 in the morning.
The final wing is ready for sanding, spackel, sanding and covering.
The only question in my mind so far is the airfoil. I tried to go very slow and methodical, but it just doesn't seem uniform across the leading edge.
We'll just have to wait and see how it turns out.
ID:	155955   Click image for larger version
ID:	155956   Click image for larger version
ID:	155957   Click image for larger version
max2112 is offline
Old 01-01-2012, 07:34 PM   #6
Friends: (22)
nice build so far,keep the pictures coming ....,i built the hob v-tail bonanza and loved how nicly it went together....i over built it though with lights and mech retracts causing to much exess weight. the newer electric retracts would go nice in your build.
thanks for sharing your build with us,looks like you'll be covering in no time.
Old 01-02-2012, 10:32 AM   #7
max2112
max2112's Avatar
Globetrotter Pilot
Friends: (13)
Default Fuselage
Thanks Stuart.
More work last night. Mostly building a box style fuselage and sheeting the top for the rounded taper. The wing joiner was a bit of a chore. But it all got sorted out.
ID:	155991   Click image for larger version
ID:	155992   Click image for larger version
ID:	155993   Click image for larger version
ID:	155994   Click image for larger version
max2112 is offline
Old 01-02-2012, 10:41 AM   #8
max2112
max2112's Avatar
Globetrotter Pilot
Friends: (13)
Default more Fuselage
More fuselage pictures. The instructions were good for this part, but as always dryfitting before glueing definitely helps.
ID:	155996   Click image for larger version
ID:	155997   Click image for larger version
ID:	155998   Click image for larger version
ID:	155999   Click image for larger version
max2112 is offline
Old 01-02-2012, 10:52 AM   #9
max2112
max2112's Avatar
Globetrotter Pilot
Friends: (13)
Default finishing up the Fuse.
and more pics...
ID:	156002   Click image for larger version
ID:	156003   Click image for larger version
ID:	156004   Click image for larger version
ID:	156005   Click image for larger version
ID:	156007   Click image for larger version
ID:	156008   Click image for larger version
ID:	156009   Click image for larger version
max2112 is offline
Old 01-03-2012, 05:39 AM   #10
Bill G
Super Contrubutor
Bill G's Avatar
View Bill G's Gallery88
Club: rcg staff
Friends: (17)
Well Hey!
I have one of those.
Maybe this will finally encourage me to fly mine. I got as close as having it at the field, only to find a horribly out of balance Goldberg snap-on spinner. That has been corrected, and about my only issue now is that it really could use a SBEC. It's an old geared cobalt brushed setup, and will draw power. I have no clue what the BEC rating is in the high amp brushed ESC, and even a 3A linear BEC would be questionable.
This kit builds well, fast and easily. It seems you've probably already determined that. It was one of my first kits, and still hanging like new, along with 1/4" of dust.
Bill G is offline
Old 01-04-2012, 07:00 PM   #11
max2112
max2112's Avatar
Globetrotter Pilot
Friends: (13)
Thanks for the post and pic BillG.
I am to a point where I had to quit working on the nose because I am going w/ a brushless power 15 motor. I'm not sure which brand I'm buying and their dimensions vary a lot. I don't want to fabricate the firewall without having everything on hand.
Next I'll work on the tail section and get what I can prepped for covering.
I am Not decided 100% on the .15 size motor. I am researching if I can keep it light enough to go with a 480 sized outrunner.
max2112 is offline
Old 01-08-2012, 08:01 PM   #12
max2112
max2112's Avatar
Globetrotter Pilot
Friends: (13)
Smile Great Weekend.
Well sportsfans. It's Sunday night so I get to post up the progress from this weekend. I only got to work on "Bear" about two 1/2 hours yesterday, but today was a different story. I got about 5 or so hours of uninterrupted work done today.
Here is where I stand: The balsa cutting and glueing is about 99% done. I have left the bottom of the nose open and one bulkhead loose until I get my motor in-hand and can do the required measurements off of the motor itself (not dimensions from the spec. sheet).
Today I was able to make the battery hatch functional and complete the horizontal stabilizer, elevator, and rudder assemblies.
I am ready to start with the covering!
max2112 is offline
Old 01-08-2012, 08:04 PM   #13
max2112
max2112's Avatar
Globetrotter Pilot
Friends: (13)
Default Battery hatch.
Here are the final pictures of the battery hatch. As you can see I introduced a warp into the left side/front. I thought I had her squared up as I was building, but obviously I didn't!
I think it is repairable. I might work on that during the coming weeknights.
ID:	156177   Click image for larger version
ID:	156178   Click image for larger version
ID:	156179   Click image for larger version
ID:	156180   Click image for larger version
max2112 is offline
Old 01-08-2012, 08:24 PM   #14
max2112
max2112's Avatar
Globetrotter Pilot
Friends: (13)
Default Tail feathers!
Well, I'm done with the front until I get my motor. So... on to the tail!
I really enjoyed the framing, cutting and building on this part. Very relaxing stuff. One piece measured and cut at a time. Then Frame it, pin it, and glue it.
ID:	156183   Click image for larger version
ID:	156184   Click image for larger version
ID:	156185   Click image for larger version
ID:	156186   Click image for larger version
ID:	156188   Click image for larger version
max2112 is offline
Old 01-08-2012, 08:35 PM   #15
max2112
max2112's Avatar
Globetrotter Pilot
Friends: (13)
Default Final dryfitting and static display.
ID:	156190   Click image for larger version
ID:	156191   Click image for larger version
ID:	156192   Click image for larger version
ID:	156193   Click image for larger version
ID:	156195   Click image for larger version
ID:	156196   Click image for larger version
max2112 is offline
Old 01-08-2012, 08:48 PM   #16
View CHELLIE's Gallery13
Friends: (326)
That Looks very Nice, I get to do the Maiden Flight on it LOL, Take care and Have fun, Chellie
Old 01-08-2012, 08:52 PM   #17
max2112
max2112's Avatar
Globetrotter Pilot
Friends: (13)
Default I did say warts and all....
Well, here is another mistake that I made and had to cover up. I hope it doesn't have any negative affects later on.
Short story - While dryfitting the front-most bulkhead ply on the nose, I got ham-fisted and cracked/broke the side of the fuse! Aaargghh!
Well, I fixed it up as best as I could and here are some pics.
Tried it first with Medium CA, but that didn't work. Final repairs were made with 5 minute epoxy.
ID:	156199   Click image for larger version
ID:	156200   Click image for larger version
ID:	156201   Click image for larger version
ID:	156202   Click image for larger version
max2112 is offline
Old 01-08-2012, 09:00 PM   #18
max2112
max2112's Avatar
Globetrotter Pilot
Friends: (13)
Sure thing, Chellie! Two favors, though. I'm going to need round-trip airfare and you have to let me use your camera/aiming rifle!
Deal?
max2112 is offline
Old 01-09-2012, 01:20 AM   #19
Friends: (22)
wow! john,yourflying thru this build. hob kits look like fun to build.
i started building 4 years ago or so....the smaller kits with 35"ws are tough to keep my thumbs from crushing something during the build...lol...the repair you did is super and won't show at all.
i tend to swap out the turtle deck stringers on herr kits for something more solid. on the herr minisport the stingers were so thin that i feared covering shrinkage would crush them.
Old 01-09-2012, 08:36 AM   #20
Bill G
Super Contrubutor
Bill G's Avatar
Club: rcg staff
Friends: (17)
There's a lot of wing on this plane, and a favorable wing loading. Considering that people were flying the plane with geared brushed 480 long can motors, you would do fine with the 480bl. The thing that hinders weight reduction, is that the plane was designed for the heavy cells, so our lipos don't really help. I have a stack of sticky lead weights in the nose, that looks like an igloo. I haven't looked at mine lately, but if possible I would like to install an outrunner, and move the battery further forward, using the space that the gearbox now takes up.
You could always use the old school gearbox setup also. The MPJet 400 size gearbox was pretty much a direct fit, into my P51. I used a MPI 4011 cobalt, but the 400 size gearbox will almost certainly fit 28mm inrunners, which are easily as powerful as the BL15. I used to buy a few spare gears, in case I trashed one while drilling it for the larger diameter motor shafts. The tiny MPI loctite tubes that come with these boxes, are the best stuff I've ever used for locking gears.
http://www.hobby-lobby.com/gearboxes...ns_289_ctg.htm
Bill G is offline
Old 01-10-2012, 09:16 PM   #21
max2112
max2112's Avatar
Globetrotter Pilot
Friends: (13)
Thanks stuart. I hope to get most of the sanding done this week so I can begin with the covering this weekend.
Thanks for the picture Bill G. I realy like the looks of your model. I am still undecided what paint scheme I am going to use.
I know that it's been done many times already but I like...
max2112 is offline
Old 01-13-2012, 02:30 PM   #22
Bill G
Super Contrubutor
Bill G's Avatar
Club: rcg staff
Friends: (17)
Thanks for the picture Bill G. I really like the looks of your model. I am still undecided what paint scheme I am going to use.
Thanks. The box scheme talked me into mine. The added panel graining that they put on theirs looks excellent. Being one of my early builds, the Monokote chrome also got me up to speed quickly with iron-on covering.
Bill G is offline
Old 01-13-2012, 08:58 PM   #23
max2112
max2112's Avatar
Globetrotter Pilot
Friends: (13)
Thanks for the motor advice Bill. I have been wondering what my AUW will be with today's technology.
I have came across a pretty good deal locally. I hope to pick a motor up tomorrow from a local fellow WattFlyer. It is smaller than a .15 (which is OK, that's WAY too much motor!) but it's a bit bigger than an outrunner 480. It's an HK 3536/1400.
I'll post up more specs and info when I get it and can do more research.
I was able to begin covering tonight. I'll post pictures up tomorrow. No promises though, the weather is looking pretty for tomorrow and we all know what that means!
max2112 is offline
Old 01-15-2012, 11:24 AM   #24
max2112
max2112's Avatar
Globetrotter Pilot
Friends: (13)
Default Let the covering begin!
The iron on covering I'm using is Monokote. The pictures show some good, smooth spots and more than a couple places where I have room to improve. I worked on the seperate pieces first.
Horizontal stabilizer and elevator. Rudder and vertical stab. The air inlet scoop. And one aeleron finishes out the first covering session.
I left everything at about 95%. I know that some of these wrinkles can be ironed out.
ID:	156426   Click image for larger version
ID:	156427   Click image for larger version
ID:	156428   Click image for larger version
ID:	156429   Click image for larger version
max2112 is offline
Old 01-15-2012, 11:35 AM   #25
max2112
max2112's Avatar
Globetrotter Pilot
Friends: (13)
Default 1st Covering Session part 2.
More pics.
and we had a break in the weather so we had a beautiful but cold morning of flying here in Kaiserslautern.
ID:	156432   Click image for larger version
ID:	156433   Click image for larger version
ID:	156434   Click image for larger version
ID:	156435   Click image for larger version
max2112 is offline
Tags
hob , kit , p51
$100 Scratch Build Contest "Best Looking" poll here hillbillynamedpossum Scratch and Kit Built Aircraft 107 08-26-2013 11:23 PM
Sig Four-Star 20EP Kit Build Marc Sport Planes (Formerly I/C & Gas Conversion) 17 04-24-2013 04:53 PM
Skyshark Hawker Tempest Build Log Forge Scratch and Kit Built Aircraft 24 06-07-2012 01:33 PM
Not scratch build, not a kit, but a lot of work pd1 Scratch and Kit Built Aircraft 6 09-08-2011 12:00 PM
Sig Senorita Kit Build rminut Scratch and Kit Built Aircraft 12 05-14-2011 08:24 PM
Page generated in 4.71242 seconds with 146 queries
