Old 01-02-2012, 09:52 AM   #1
PGernix
Default Replacing Damaged wings.
Just crashed my EDF Jet and the wings need to be replaced. I can buy spare parts without a problem but what is the best way to remove the old wings. They are glued on with Epoxy. Otherwise I will have to cut the new replacement wings where I cut the old wings off so they match. Any tips would be helpful.
PGernix is offline
Old 01-02-2012, 08:00 PM   #2
Voltron
Voltron's Avatar
Some Photos of your plane or at least a description of the make and model would be helpful for someone to help you. I would imagine that there is a spar running through the wing that gives the wing support and in some cases helps attach it to the fuselage. You can't just saw the old wings off and stick new ones on. The glue joints would never handle the G load when you pull up out of a dive. You don't say if the plane is built from a kit, is an ARF or an RTF. Is it foam or balsa? Depending on what type of plane it is, the spar may be included with the wings.
Voltron is offline
Stabilize wings when building with EDF? sporren Electric Ducted Fan Jets 2 12-16-2011 05:02 PM
For Sale 26 inch delta wings dr rc Airplanes - Electric For Sale & WTB 0 11-18-2011 11:56 PM
changing wings - what needs to be considered? prof_fate Scratch and Kit Built Aircraft 4 10-16-2011 06:54 PM
West Wings Hawker Hunter JetPlaneFlyer Electric Ducted Fan Jets 0 09-18-2011 08:34 PM
"Full Flying" wings - surely it's been done? mclarkson Aerodynamics 8 08-20-2011 06:26 AM
Page generated in 0.16856 seconds with 21 queries
