Go Back   WattFlyer RC Electric Flight Forums - Discuss radio control eflight > Electric R/C Airplanes > Hi-Performance and Sailplanes
Old 01-03-2012, 07:41 PM   #1
Dean in Milwaukee
Default TheWorldModels Skywalker 400 class
I haven't seen anything on this plane in a long time, so I thought I'd mention it here. Skywalker Glider. I got mine around 5 years ago.
It comes with a geared 400 motor setup that would work ok with 2s lipo, but since I wanted to go 3s, I swapped it out for a gws eps400 set. The much bigger gear reduction the gws set had also allowed a much larger prop, a Cam 12x6 folder. This setup is good, with climb rate Motocalc predicted at over 1000 ft/min, but if I was to do it again there are many far lighter brushless setups I would probally use instead. Mines still light at 20 oz, and thats with a 3.5 oz motor. My only other mod was to add reflective tape to the wings and tail to make it easier to see when its stupid high. This works well, the planes a speck, but I keep seeing flashes of light.
The plane itself is a sweet flyer, about as gentle as you could hope for, and is essentially unstallable. Pull up hard, ( not under power) and the nose rises, a bit, stops, drops a bit and starts flying again. It circles very tightly, perhaps 10 ft diameter, which allow it to stay right in small thermals and also makes its long glide slope no problem for landing. I just circle right in front of myself till it almost touches down, then release rudder and flair for landing. Its going so slow it doesn't really even slide.
Anyways, I just wanted to make sure people don't forget about this one. Its well worth the money.
Dean in Milwaukee
Dean in Milwaukee is offline
Old 03-11-2012, 03:02 PM   #2
Friends: (9)
Thanks for the report. Always want to hear about good planes.
www.lisf.org
Eastern Soaring League
www.flyesl.org
AEAJR is offline
Old 03-11-2012, 04:31 PM   #3
Dean in Milwaukee
Thanks! I am actually considering doing another since my first has a lot of hanger rash now, and going with a super lightweight power system. The existing motor and battery weighs around 6.5 oz. I know I could do much better although this may require adding some nose length to make it balance, not a tough project on this plane. I could wind up around 16 oz if done right, a 20% drop.
Dean
For Sale 400 and 370 Brushless Inrunners w/gearbox dumpsterjay Motors and Speed Controllers for sale & WTB 0 02-10-2011 04:52 AM
Page generated in 0.05999 seconds with 23 queries
