Old 01-07-2012, 07:47 PM   #1
mrbicknell
Default lipo usage time
Hey guy's, I am trying to work out a good usage time for my lipos. I know how to work it out if I know what amps the motor is pulling, but I have a few models with old brushed motors which i don not know the amps. How can I work out a flight time?
mrbicknell is offline
Old 01-07-2012, 08:08 PM   #2
Club: A lone flyer!
Scratchbuilders Award  Scratchbuilders Award
Friends: (7)
You really must invest in a meter to actually measure the current draw.
If you consider the cost of replacing a LiPo damaged by over discharging (or for that matter the ESC and motor by over loading) it is a sound investment.
quorneng is offline
Old 01-07-2012, 08:16 PM   #3
mrbicknell
yeah, I am new to all this and my dad only ever flew nitro stuff. I shall look for a meter. Silly question, how do I use one, like a volt meter I guess, but how do I use it to measure the amps being drawn?
Old 01-07-2012, 08:44 PM   #4
dumo01
dumo01
dumo01's Avatar
Club: Westerville Model Aeronautics Assc
Friends: (7)
The watt meters go in line between your battery and ESC. They measure voltage applied from the battery and current draw, display volts amps and calculated watts.
You can also get different type of meter that is a clamp around one of the wires between the battery and ESC that will measure current. Little different set up to do the same thing, but not as dedicated
http://www.sears.com/craftsman-digit...p-03482369000P
dumo01 is offline
Old 01-07-2012, 09:02 PM   #5
mrbicknell
ok cheers, I will try and find one
Old 01-13-2012, 09:58 AM   #6
Friends: (19)
Ebay .... Hobby King .... Local Hobby Shop ?
It's a common item and called by the generic term : Wattmeter
I use mine every day to check LiPo's charge and usage ... balance etc.
With new set-up out of interest - I run up to check amps and watts ...
For about $30 ... it's a good tool.
Old 01-13-2012, 03:18 PM   #7
whitecrest
whitecrest's Avatar
Originally Posted by mrbicknell View Post
. . . how do I use one, like a volt meter I guess, but how do I use it to measure the amps being drawn?
Here's an illustration using an inexpensive DVM that are widely available:
Name:	3 Dollar Watt Meter 2.jpg
~Tim
whitecrest is offline
Old 01-13-2012, 08:48 PM   #8
mrbicknell
yeah, I'm sure I have one of those, I will check it out, Thanks
Old 01-13-2012, 11:25 PM   #9
One of those generic "wattmeters" will serve your purpose well. As for the common digital multimeters, their maximum current range is generally on the order of 10 Amps, far to low for most electric motors used in our models. (My kilowatt sized motors typically pull some 60 amperes.)
Take a look, this explains some of this stuff.
http://www.wattflyer.com/forums/showthread.php?t=52821
If you want to spend the $$$$, (About $60) the Sears Craftsman #82369 meter can measure the current pulled by just about any electric motor you have access to. Including the starter and alternator in your car/truck. Its current ranges are 0-40 and 0-400 Amps, AC and DC. It doesn't require special connectors, just clamp it's jaws around one battery cable. Note that most clamp on ammeters are AC only, not suitable for our stuff.
This meter can also measure current pulled by your AC appliances and so on, but it needs to clamp its jaws around ONE wire of the power cord. Clamping around the usual two wire extension cord will result in zero current measured.
But, this Sears meter can't measure things like ampere hours and such, only the usual volts, amps, resistance, temperature and so on.
Old 01-14-2012, 12:28 PM   #10
Friends: (9)
See chapter/post 71 in this e-book
http://www.wattflyer.com/forums/showthread.php?t=31368
www.lisf.org
Eastern Soaring League
www.flyesl.org
AEAJR is offline
Old 01-14-2012, 02:51 PM   #11
mrbicknell
cool thanks
Old 01-18-2012, 07:20 AM   #12
betomxl
nice info
betomxl is offline
Lipo Usage mrbicknell Batteries & Chargers 8 10-07-2011 04:09 PM
Solid experience on RC Model Lipo Battery Accident & Charger Guide SimonXi Batteries & Chargers 0 08-12-2011 06:08 PM
Anyone interested in a Longest Flight Contest? AEAJR Hi-Performance and Sailplanes 26 07-23-2011 04:27 AM
Charging LiPos inside the airplane Henry111 Batteries & Chargers 118 03-18-2011 07:27 PM
Page generated in 0.14693 seconds with 44 queries
