Go Back   WattFlyer RC Electric Flight Forums - Discuss radio control eflight > Electric Helicopters > Micro Sized Electric Helicopters > E-Flite Helicopters
Old 01-19-2012, 02:06 AM   #1
Bill Fleming
Bill Fleming
Club: Nanpa Model Aviation
Default 120SR Flight adjustments
Hello:
Having a ball with my 120SR. I'm where I can put it where I want it a hold a hover until I'm bored. However, I have noticed that when in hover, cafefully adding rudder either way, I get a slight forward or reverse response in addition to a greater yaw response. Is this normal? I'm using a LP5DSM transmiter. I suppose I could trim it out with a programable trans, but can I trim the heli someway to remove it?
Thanks, Bill
Bill Fleming is offline
Old 06-16-2012, 10:18 PM   #2
Heli Jim
Grandpa, Golfer, Pilot
Heli Jim's Avatar
Well, just a guess here, but when a heli is in a stable hover, it's not really straight and level
due to the side thrust of the tail rotor. You are really leaning (as seen from behind) a bit to
the right and this is perfectly normal. However, if you then add some tail rotor input in either
direction, you aren't really just inputting rotation, it is slightly skewed up or down depending
on the input. Just my 2 cents worth.
Helicopters don't really fly.......
They're just so ugly, that the earth repels them.
Heli Jim is offline
Old 06-17-2012, 03:23 PM   #3
Bill Fleming
Bill Fleming
xxxxx
B-47 9th Scale, Boeing Stratojet...In The Middle Flite-Metal Electric Ducted Fan Jets 252 02-27-2013 02:09 AM
Extreme Flight Extra 300 EXP__Clean Sheet Doc Austin 3D Flying 5 01-05-2013 03:19 AM
Extreme Flight 48" MXS__Something Completely Different Doc Austin 3D Flying 2 11-27-2011 07:03 AM
Anyone interested in a Longest Flight Contest? AEAJR Hi-Performance and Sailplanes 26 07-23-2011 03:27 AM
Checking CG in flight? DanWard 3D Flying 14 04-15-2011 12:41 PM
Page generated in 0.18499 seconds with 23 queries
