Go Back   WattFlyer RC Electric Flight Forums - Discuss radio control eflight > Electric R/C Airplanes > Indoor & Micro Electric Planes
Old 02-01-2012, 10:51 PM   #1
View rcers's Gallery57
WAA-08 Pilot
Friends: (9)
Default UMX Carbon Cub 2s 180 motor with flaps, lights and even floats!!
Wow I am in love. Just take a look at this beauty.
Key Features
  • AS3X System for smooth handling and precise control, even in moderate winds
  • Includes a top-mounted, ultra micro-size sailplane tow hook
  • Perfect for aerotowing! The tow hook equipped UMX Carbon Cub SS makes an ideal tug for the UMX ASK-21 (EFLU1280)
  • Converts to a floatplane quickly with optional E-flite float set (EFLUA1190)
  • Full five-channel control with flaps to enjoy slower flight and shorter takeoffs and landings
  • Navigation wing lights and landing light installed
  • 6-channel DSMX Ultra Micro AS3X/RX/BL ESC unit with Spektrum technology
  • High-output 180BL, 2500Kv brushless outrunner motor
  • E-flite 180mAh 2S Li-Po battery and balance charger
  • Five performance ultra micro long-throw servos
I may as well just work on every few check's being direct deposit for Horizon. Amazing, Brilliant and Stellar.
Here is the vid....
http://www.youtube.com/watch?v=SBwq0aGXBko
ID:	156876   Click image for larger version
ID:	156877   Click image for larger version
ID:	156878   Click image for larger version
ID:	156879   Click image for larger version
Old 02-02-2012, 06:22 AM   #2
Billmanak
Club: Stand next to me when we fly and we'll pretend we are a club.
She is a beauty. Hope its out by the time the lakes melt up here.
Billmanak is offline
Old 02-05-2012, 12:24 AM   #3
stout890
stout890
I am in love with this plane, but it's a darn shame horizon makes you use there radios. So im now forced into selling my AR RDS8000 to fund a spektrum radio lol
Sent from my iPhone using Tapatalk
stout890 is offline
Old 02-05-2012, 03:12 AM   #4
Brick
small Member
i like it also, good to see they are starting to use the more powerful /dependable Brushless motors !!
Brick is offline
Old 02-16-2012, 07:08 AM   #5
stout890
stout890
Bump...let's talk about this cool plane, anyone know the release date? Or is it out already?
stout890 is offline
Old 02-18-2012, 07:23 AM   #6
Germanscott
A release date would be nice, I put my order in for the ASK 21.
Germanscott is offline
Old 03-31-2012, 11:16 PM   #7
vmmattil
Their website state that it will be due in May
vmmattil is offline
Old 05-13-2012, 08:00 AM   #8
Ehawthor
Default It's been released
Just purchased the Carbon Cub SS. Haven't flown it yet, but hope to get it out this weekend.
Ehawthor is offline
Old 05-13-2012, 09:10 AM   #9
vmmattil
Mine had servo issues, causing the elevator to jam. Be careful, check the servos pre-maiden. More in rcgroups about this.
vmmattil is offline
Old 05-13-2012, 12:57 PM   #10
Bill G
Super Contrubutor
Bill G's Avatar
View Bill G's Gallery88
Club: rcg staff
Friends: (17)
Yeah, like 100 cycles. Not a bad idea with any servo, but these ones especially. I believe Horizon actually tests the servos, which would put them ahead of other manufacturers, but a few more cycles in testing would be a good thing.
I'm losing interest in these linear servos, as I had one fail due to an IC failure after a handful of cycles. Removing it from the wing after neatly fairing it in, was not something I was thrilled with doing. I took it apart and noticed that the wiper leaves were not all aligned to the same height also, when unsprung. This was not the problem, but it's not a bad thing to have equal pressure on all of them, since they are all part of the same leaf spring contact. They can be carefully tweaked and reassembled for maximum contact.
Speaking of micro seaplanes, the servo was on a micro Guillows Beaver. Still haven't got it out yet. Hopefully it will be a nice little pond flyer.
Bill G is offline
Old 05-13-2012, 09:56 PM   #11
thomdoe
lakes freeze over then have to melt !
thomdoe is offline
Old 05-13-2012, 09:58 PM   #12
thomdoe
first off just what is a lake ? I live in California ? lake ?
thomdoe is offline
Old 05-13-2012, 10:00 PM   #13
thomdoe
my smartphone doesn't show lake
thomdoe is offline
Old 05-14-2012, 05:54 PM   #14
TopSpin
TopSpin's Avatar
Come on, there are lakes all over the place in Southern California.
The TRUTH is not always what it seems.
TopSpin is offline
Old 05-20-2012, 06:44 PM   #15
sparky1963
UK fixed-wing & heli dude
View sparky1963's Gallery2
Got my Carbon Cub a week ago, from local model show. Not had a chance to maiden it yet cuz of windy weather.
After reading comments here about servos, I thoroughly checked all of mine, because there wasnt much movement on elevator. Everything seems to work ok though.
If there's insufficient pitch authority, I can always move it to next hole on the control horn.
One problem I've found (just with this model), is that it will bind ok - but then lose the binding when you remove battery. Anyone else had this problem with BNF products? I've got 8 other BNF aircraft/helis - none of those are 'forgotten' by the Tx.
Update 5 June: -
After maiden flight, it needed a few tweaks... On deployment of flaps, nose pitched up severely (40+ degrees) and didnt have enough elevator to compensate (as I suspected). Dialled flap movement down by 30% & moved elevator pushrod to next hole on horn. Had to move battery forwards in bay, (only half of it visible), to get CofG right.
Flies nicely & remains easily controllable, on 100% rates and no expo. Loops easily from level but needs some co-ordinated down elevator during a roll. Landings are long and floaty because it glides quite well.
Note: because second aileron uses ch6 port, Carbon Cub flaps are on Gear switch (ch5), not Flap switch, so Tx flap/elev mixing won't work. I was going to swap flap servo onto ch6 but it would need a Y lead with reverser, to run both ailerons from ch2.
Navigation lights share a Y lead with flaps, into ch6, so would be easy to unplug lights and maybe extend flight times.
Strangely, the binding issue seems intermittent - was ok for a few flights but has come back again.
Current hangar: Cessna 182, Cessna Skymaster, PZ Spitfire MkIX. ASW-17, Kalt Whisper.
Micro: Blade mSR, Blade mCPx, Sukhoi 26XP, T-28 Trojan, Beast, Stryker, Carbon Cub, Spitfire, Mustang.
sparky1963 is offline
Old 10-07-2012, 07:54 PM   #16
vmmattil
This plane is great for flying with an onboard camera since it is so powerful. Did a video today with some loops, rolls and inverted flying:
http://www.youtube.com/watch?v=EVGXGEdKQgw
vmmattil is offline
Old 11-02-2012, 10:36 PM   #17
TopSpin
TopSpin's Avatar
Got mine today and the glider to go with it. This is an awesome little setup, film at eleven.
TopSpin is offline
Old 09-08-2013, 09:47 AM   #18
GBLynden
Hey guys,
I am surprised this thread is not more active. This is a pretty cool plane and now that the sailplane is only $50, you all should be all over this.
These videos are of my buddy John having fun with his CC.
GBLynden is offline
Old 12-23-2013, 06:02 AM   #19
GBLynden
I got a new camcorder and used it to record my buddy flying his Carbon Cub yesterday in snow on floats. You can skip the first minute of BSing to get to the good stuff:
GBLynden is offline
Old 08-21-2016, 08:39 PM   #20
Bagoparts
Update 5 June: -
I found that i had to move the elevator throw to the inner most hole to get adequate elevator authority. Makes AS3X more responsive as well. Also 40 degree down elevator with full flaps on dx61 will keep pitch up under control. Odd they would put the flaps on the gear switch though.
Bagoparts is offline
Page generated in 0.69393 seconds with 64 queries
