Old 02-03-2012, 02:08 AM   #1
cbinfl
Default Finished a Cub kit ...
I just finished an Alien Aircraft Piper Cub kit and thought I'd show some photos. Kit is builds easy and flying is great. Finished model weighs 18 oz. with a 1300 3s. Only changes I made were upsized the landing gear wire to 3/32" and added carbon rod braces to the stab. for looks. So far 12 flights; two cartwheels taking off in cross wind ? Tail lifts real easy and then it weathercocks into the breeze when you punch it instead of aborting. LOL. strong build cause there was no damage, (yet !). Nice wheel landings though, into the wind ...
The motor is a little oversize, 150 watts at full throttle with an 8x6 prop. Flies at 40% throttle. This is my second Alien kit and they are really nice flyers.
Charlie
ID:	156899   Click image for larger version
ID:	156900   Click image for larger version
ID:	156901   Click image for larger version
cbinfl is offline
Old 02-03-2012, 02:55 PM   #2
riverrat
circa: 1946
riverrat's Avatar
Club: NRA Life Member
Friends: (30)
Default CUB!!
Nice JOB!!
Regards
Jimmy
riverrat is offline
Old 02-03-2012, 05:12 PM   #3
cbinfl
Thanks for the reply Jimmy. Too windy for it this am, maybe tomorrow? Two other changes i forgot to list. Made the LG 1/2" taller to deal with grass and prop clearance, and mounted the side windows inside rather than paste them on the outside as per plans. They kit has frosted plastic for the windows and maybe I should have changed that to clear ? Flew the "Hornet" 3 batteries this am. It's really good in a breeze. Clean and smooth like a mini pattern plane, but lands slow, and fairly short if there's a head wind.
cbinfl is offline
Old 02-03-2012, 05:16 PM   #4
View xmech2k's Gallery21
Club: CVMRCC, SEFSD
Good looking bird! If she flies half as good as she looks, should be great!
Old 02-03-2012, 08:56 PM   #5
Bill G
Super Contrubutor
Bill G's Avatar
View Bill G's Gallery88
Club: rcg staff
Friends: (17)
Tom Herr makes nice kits that build up well. I like the little Sportster that they have also:
http://www.alienaircraft.com/k301.htm
I noticed that you have Multiplex wheels on your Cub. I was going to use them for a recent project, as the proportions were perfect for it. Them thing's ain't cheap though, and I am.
Bill G is offline
Old 02-04-2012, 02:44 AM   #6
cbinfl
The wheels are from a Multiplex Gemini that finally after 100+ flights, fell victim to my inattention. They are very light and wear very well. I guess you could say they cost me a little over $100 ...
Charlie
cbinfl is offline
Old 02-04-2012, 06:15 AM   #7
Bill G
Super Contrubutor
Bill G's Avatar
Club: rcg staff
Friends: (17)
Charlie
I figured that you got them from a plane. 100+ flights isn't bad though, and its spirit still lives on in the tires. They have a light compound that doesn't wear, or flat spot from sitting like other cheapie "foam" tires.
BTW, I was just looking at my Guillows Cub that was one of my first builds, and was thinking I need a flying Cub here myself. I had it flying, but at around 9oz and 24" span, it just wasn't a very practical every day flyer.
Bill G is offline
Old 02-05-2012, 01:18 AM   #8
cbinfl
If you almost double the size of yours, this one will be very similar. Pretty light for everyday flying. 42" span and 18 oz with a 1300 battery. Super nice in still air though.
cbinfl is offline
Old 02-05-2012, 03:14 AM   #9
Bill G
Super Contrubutor
Bill G's Avatar
Club: rcg staff
Friends: (17)
18oz is a good weight for that size. I don't know why people use overpowered motors, and large batteries such as 2100 and larger, for a plane like this. Your 1300 is perfect for the plane, and probably gets 15 minute or longer flight times. I've usually had more than enough flying for one flight, after that amount of time.
Enlarging plans is one of my favorite build methods. I just bought a little 24" Beaver kit, and am thinking of enlarging it to roughly your size, for a scratch build.
Bill G is offline
Old 02-05-2012, 05:53 PM   #10
cbinfl
Bill, I've never been able to get long flights out of any of my planes. With the Cub I usually land at 6 min. and the battery is about 3.8 volts. Maybe I'm too conservative with the batteries, but running the down to 3.3 or 3.4 I always worry about needing to go around again. I have an 8x6 on it now and will try an 8x4 prop this coming week.
cbinfl is offline
Old 02-05-2012, 10:42 PM   #11
Bill G
Super Contrubutor
Bill G's Avatar
Club: rcg staff
Friends: (17)
I'm conservative also. Rarely hit lvc, and really don't care to. I'm convinced your batteries will last longer. I usually find 6 minutes per flight to be more than enough. I don't think there's much that I ever fly over 8 minutes, and the 8 minute plane is one that I buddy cord with a friend, where we have it timed and know what we can get out of it. BTW, it's an old GWS Islander with an inefficient DD brushed twin setup, running 2s-1320 cells.
Bill G is offline
Old 03-30-2012, 07:49 AM   #12
cc83
looks really nice, I just have to put the wing halves together and cover my kit. so far has gone together really nicely, what did you use to cover yours? I have some cub yellow ultracote but i'm not sure if it will be too heavy. i'm thinkng about using a GH2208-17 for power that i have from a beat up foamy. it's only 100 watts though so i'm not sure if it will be too underpowered.
cc83 is offline
Old 03-30-2012, 04:54 PM   #13
cbinfl
cc83, i used Ultracote Parklite. Works well and is lighter than Ultrakote. 100 watt motor might be a little small, but it flies best in light wind so maybe not. I cut the elevator throw down to 75% and use about 30% expo. Just got back from flying it this am, four batteries. Good luck.
Charlie
cbinfl is offline
For Sale Aluminum Motor Mounts for Multiplex, Parkzone, and Flyzone Super Cub Planes terrynshed Motors and Speed Controllers for sale & WTB 4 09-24-2012 05:33 PM
Finished a Cub model cbinfl ParkFlyers 0 02-03-2012 01:38 AM
Sold Eva Sport KIT NIB+ 2 rolls of covering. price dropped. 1987tc Airplanes - Electric For Sale & WTB 3 02-25-2011 07:59 PM
super cub to a warbird? corvette Beginners 17 12-27-2010 06:01 AM
For Sale HZ Mini Super Cub All American Airplanes - Electric For Sale & WTB 2 02-08-2010 09:17 PM
Page generated in 0.36760 seconds with 49 queries
