Old 02-04-2012, 01:03 PM   #1
Rbwindover
Default Slow fly prop question
Can anyone explain to me the concept of a slow fly prop, a model I am considering requires one. If a model needs a certain airspeed to fly how does a slow fly prop make any difference. How do they differ from a standard prop? Can i use a standard prop instead? Thanks in advance
Rbwindover is offline
Old 02-04-2012, 02:27 PM   #2
slipstick
Outstanding Contributor Award
SF prop is designed to be efficient at slow rpms and slow flying speeds.
Standard prop isn't. It will work but usually not as well.
slipstick is offline
Old 02-04-2012, 03:13 PM   #3
flydiver
flydiver's Avatar
View flydiver's Gallery1
Fat blade, produces torque. Have an upper RPM limit.
GWS SF are pretty floppy, very low RPM limit. Only good for slow low power planes.
fly
flydiver is offline
Old 02-04-2012, 05:17 PM   #4
1320fastback
1320fastback's Avatar
Club: Fallbrook R/C Flyers and Oceanside Quiet Flyers
WAA-08 Pilot  AV Contest
There also a lot lighter. Put a standard (glow) 10x6 on a little wimpy brush less and it might not even be able to turn it.
Classic Sig Kadet/ OK Models SupraFly45/ Eflite SU=26M/ Ritewing TL50/ FPV Twin star/ Pheonix Strega .45/ Nitroplanes Bobcat .75 / Cox .049 Pilot Baby/ AMA#1,000,000
1320fastback is offline
Old 02-05-2012, 06:38 AM   #5
Glacier Girl
Kamikaze Ace
Glacier Girl's Avatar
1kW
And for that matter, don't use a SF prop on a higher power bird that specifies a standard electric prop. Like flydiver said a SF is very flexible, and on a higher powered system, the prop blades will fold forward as they spin.
Glacier Girl is offline
Old 02-06-2012, 08:21 AM   #6
1320fastback
That would be a best case scenario
Blade separation and damaged shaft or engine mount would be worst.
Old 03-11-2012, 04:03 AM   #7
SuchIsLife
SuchIsLife's Avatar
Slowfly props usually have a rounded tip too. The tip is the most important part of a prop as it is doing the highest speeds and a lot of the work.
Dynam Spitfire, Dynam P-51, Electrafly Camel, scratchbuilt foamboard F-15 and full fuse Spad XIII, paper airplanes, rubber bands, anything I can fly.
SuchIsLife is offline
Welcome New Members to Wattflyer - We ONLY do electric flight here! admin General Electric Discussions 5290 01-03-2017 05:23 AM
100+ MPH Club CHELLIE Hi-Performance and Sailplanes 1994 05-09-2016 04:05 AM
3mm prop adapter impossible? Prop saver issue? mclarkson General Electric Discussions 12 11-26-2011 11:09 PM
yet another prop question Wrongway-Feldman General Electric Discussions 6 06-24-2011 08:31 AM
Prop pitch question????? Flysohigh General Electric Discussions 10 02-06-2011 02:47 PM
Page generated in 0.08340 seconds with 31 queries
