Go Back   WattFlyer RC Electric Flight Forums - Discuss radio control eflight > Electric R/C Airplanes > Sport Planes (Formerly I/C & Gas Conversion)
View Poll Results: How many flights a day do you typically fly?
1-2 1 5.26%
3-4 5 26.32%
5-6 6 31.58%
7+ 7 36.84%
Voters: 19. You may not vote on this poll
Old 02-07-2012, 02:40 AM   #1
bbrowncods
Club: Chesapeake Flyers
Default Flights a day?
How many flights do you typically fly during a day at the field?
I was wondering what you are limited by. For me, I am a social person so I like talking and looking at others "toys". So I typically fly only 3-5 times on a typical day. If there is someone on my channel it is usually less as I don't want to monopolize the frequency.
Now that I am switching to electric I am wondering if it would be better to just buy 5-6 battery packs and save the cost of a high C charger and associated power options (deep cycle batteries, generator, etc.), and just charge at home with a 1C AC/DC charger.
bbrowncods is offline
Old 02-11-2012, 03:57 PM   #2
mred
mred's Avatar
45 Minute Thermal Duration  30 Minute Thermal Duration
I normally bring two batteries for my plane when I go out. I change one while I am flying the other and just change it at 1C. This is enough to keep me flying for the day and I fly just as much as when I was flying glow. Normally that about 6 or 7 flights a day if I stay out all day. I normally don't take a battery with me as the club has charging setups at the field. If I take my Super Sportster, I can get 3 normal flights on one change, since the battery is way bigger then the plane needs to fly. It just needs that big battery ti get the CG right. I also take a couple of planes so I am not flying the same one all the time, and I always have one ready to go when I am.
Ed
mred is offline
Old 02-11-2012, 06:04 PM   #3
My models are mostly 1KW and larger in size. So, having four or five LiPos on hand for a half dozen models gets to be quite a few $$$$.
So, they've all got A123 cells that can be charged at just about any rate your charger can put out. Problem is, with a 12S2P battery pack, it takes a pair of 120 Ampere Hour deep cycle lead acid batteries, and then those batteries will only last a bit more than a year.
So, went to a gasoline engine/alternator power supply!
http://www.wattflyer.com/forums/showthread.php?t=63918
Old 02-12-2012, 12:20 AM   #4
Friends: (22)
always take 3 planes,with 3sets of batteries[series,and parrallel] for two of the planes and 3 or 4 bateries for the smaller plane..average # of flights on a good day...6 maybe 7. sometimes only a few if it's real crowded and the conversations are good.
Old 02-12-2012, 12:49 AM   #5
I'm usually limited by time, there are always other things that need doing at home. But I try to cram as much air time in as i can during the time i have at the field, i usually get 7 or so flights. With 2.4HHz frequency restrictions isn't an issue any more so the only limit is how fast i can swap over batteries!
Maryland Electric Day Spectacular June 4, 2011 weathervane Events, Shows and Fun Fly's - Electric Airplanes 7 06-12-2011 09:31 PM
Cold, but good day of flying! firemanbill General Electric Discussions 4 12-22-2010 05:00 PM
New Years Day Fly weathervane Maryland 1 12-20-2010 12:43 AM
Page generated in 0.08827 seconds with 28 queries
