Go Back   WattFlyer RC Electric Flight Forums - Discuss radio control eflight > Electric R/C Airplanes > Pusher Park Jets
Old 02-09-2012, 04:58 PM   #1
Friends: (19)
Default Parkjet and canards ?
I've been thinking over the thrust line and launching issues that some have with the PKJ ....
Now many delta's in full size have canards to give manouevranbility and overcome some aspects of the delta ... A PKJ is a delta and I winder if a canard set-up - fixed angle - could help with launches / thrust line issues ?
It would assist with CoG ... carraige of larger battery's .....
Old 02-09-2012, 05:31 PM   #2
Past President of PSSF
Friends: (8)
I have a plane called the Firebat, it has operational canards. It is a pusher design, with ailerons on the delta type wing, and elevator control on the canard.
It flew very good, I had a nice strong pitch control. I knew it was going to be a fun plane.
Unfortunately I crashed the plane on it's maiden flight, from my own forgetfulness. I had put a small receiver in it to test the servo travels. I totally forgot it was an indoor only RX with very short range, because there had been a large gap in time, between setting it up and final work on the plane.
I am defiantly going to fix it and put in a full range RX, I had enough power to fly at a normally fast speed, at only 1/2 stick. It will be fun.
I felt the canards gave me a better elevator control than mixed elevator/aileron surfaces on a delta. Plus without mixing I had better ailerons also.
Dave R, Proud PGR rider.
http://www.pugetsoundsilentflyers.org/
Wildflyer is offline
Old 02-10-2012, 07:54 AM   #3
Friends: (19)
I wondered if a better stability for launching could be achieved having a bit more frontal authority.
I used to fly a Mirage 2000 model years ago and it was a pig to be honest. t's interesting that the full size sprouted canards in later test developments ......
Look at Rafale .... Typhoon ...... even the ill-fated Concordski TU-144 .....
The Hk Parkjet - when you look at it's shape ... flat bottom run but a marked sloped top form with high canopy ... this must create a large moment to push nose down ? Reason for the large angle of motors at back end ? trying to counter than nose dive ....
Just thoughts .... I may try out some canards later after I have exhausted trials on my hot PKJ .....
Old 03-13-2012, 09:10 PM   #4
dumo01
dumo01
dumo01's Avatar
Club: Westerville Model Aeronautics Assc
Friends: (7)
Default Power for Firebat?
What did you use to power your Firebat? I got one as a freebee last night from a collection of planes from a club member that he no longer wanted ( no longer flying). It is NIB and has a brushed Speed 400 motor included but no ESC. I was giving thought to converting it to a brushless of sometype but had not looked around as yet to see what motor I would use as yet.
dumo01 is offline
Old 03-14-2012, 09:06 PM   #5
Friends: (19)
Originally Posted by dumo01 View Post
?? What has this got to do with PKJ with canards ? I appreciate you want info so why not PM Wildflyer ... ?
Old 07-01-2012, 06:54 AM   #6
Bobdaeronort
Bobdaeronort
Club: Member of Terre Haute R/C Club 2013; AMA member since 2011
Scratchbuilders Award
I built a 58" long 40" WS Su-47 Berkut with active canards.
Here is a video of her in and from the air.
http://www.youtube.com/watch?v=_RT90ett6qU
Bobdaeronort is offline
Page generated in 0.07691 seconds with 28 queries
