Old 02-14-2012, 09:23 AM   #1
mustang71
Club: Sherburn MFC
Default Servo Arm - HiTec 65MG
Hi, I have used the Hitec 65MG servos in one of my models but I need to get more control surface movement so I am looking for a larger servo arm.
I have tried a number of aftermarket servo arms but the sizes are either too small or too large.
Has anyone found suitable servo arms for this servo, it seems the metal gearing has a larger than normal output shaft.
Andy
mustang71 is offline
Old 02-14-2012, 04:12 PM   #2
flydiver
flydiver's Avatar
View flydiver's Gallery1
Outstanding Contributor Award
That uses what HiTec calls the B1 arms.
Have you tried these Dubro?
http://servocity.com/html/dubro_micro_arms_.html
fly
flydiver is offline
Old 02-15-2012, 07:32 AM   #3
A.T.
Club: To many to include.
Default typo
Originally Posted by mustang71 View Post
Hi, I have used the Hitec 65MG servos in one of my models but I need to get more control surface movement so I am looking for a larger servo arm. I have tried a number of aftermarket servo arms but the sizes are either too small or too large.Has anyone found suitable servo arms for this servo, it seems the metal gearing has a larger than normal output shaft.Thanks Andy
Be carefull, using longer servo arms results in substantially less force (reverse crowbar effect)
and easier stripping of gear train.
Check that the geometry is correct, as use of excessive EPA does not help either.
In need, use appropriate Hitec horn with CF or Alloy extension:
. Servo - FAQ - Throw, 100% Tx setting is best, 125% is mechanically poor
. Servo - Horn Arm Spline Count and Inter Brand Compatibility refer HS-65 Horns & charta.
. Servo - Horn Arm Extension - DIY Alloy, FRP, CF & Nylon
much more under "Radio Systems, Accessories, Alterations and FAQ." at:
Alan's Hobby, Model & RC FAQ Web Links
Alan T.
A.T. is offline
Old 02-15-2012, 08:19 AM   #4
mustang71
Club: Sherburn MFC
Many thanks for the info, really appreciated, will look at the Dubro Arms today, the red will also match the model.
Andy
Old 02-15-2012, 03:33 PM   #5
Rodneh
Club: Moonport Modelers
Meaning is clear but the text is not quite true; the torgue is not changed--it is a constant for any particular servo. However, the force exerted by the arm is lower, the longer the arm, the less the force exerted at it's end.
Rodneh is offline
Old 02-15-2012, 06:14 PM   #6
A.T.
Quite correct, a late night typo, now corrected.
Thank you
Alan T.
A.T. is offline
Old 02-21-2012, 07:08 AM   #7
Mtrchs
dubro sells them.
Mtrchs is offline
old airtronics servos? k-vette RC Radios, Transmitters, Receivers, Servos, gyros 9 02-06-2012 01:13 PM
Advanced Design 1920 Dayton Wright RB1 Racer with Flight Video Bill G Scratch and Kit Built Aircraft 109 06-27-2011 03:50 AM
Sold servo lot jr, gws, hitec, ect.... REDUCED electrodude71 Radio Equipment For Sale & WTB 4 04-12-2011 02:59 AM
3S or 4S Battery Question(s) RCFlyer44 Power Systems 22 03-29-2011 04:55 AM
servo zero, angle of the dangle, and flight surface equal travel DanWard Beginners 4 02-10-2011 04:57 AM
Page generated in 0.07217 seconds with 31 queries
