Old 02-17-2012, 02:53 PM   #1
flybuy
Default Hawk Sky Problems
New to rc planes and needing some guidence. The tail of fuslage has broken off twice. I was thinking of reinforcing with carbon rods or wood dowls. I don't think carbon rods will bend to fit form of fuslage so do you think wood dowls will be better,and if so should i put them on sides or bottom and top of fuslage toward tail of plane? Other problem i upgraded to micro jet v3 kit from grayson hobby. Kit comes with motor, esc, battery ect.Motor goes dead when going to full throttle stays off for few seconds and comes back on. This only happens at full throttle. Esc is 20amp. that came with kit. So is esc bad to small or what do you think.
Thanks for your help.
flybuy is offline
Old 02-17-2012, 03:28 PM   #2
pmullen503
I'd put the dowels on the sides. That's the direction the tail hitting something has the most leverage.
It's possible you are overloading the ESC and it hit's thermal shutdown. Using too large a prop could cause this problem. If you are using the right propeller (6x4 or smaller) and your wiring is sound then you may need to change the ESC timing or you could have a bad ESC.
Can you run up the motor to full throttle and hold it there without a prop?
pmullen503 is offline
Old 02-17-2012, 04:11 PM   #3
flybuy
Thanks pmullen for reply. It is 6x4 prop that came with kit. How do I go about changing timing of esc. I will check when i get home to see if it will run with out prop.
Update
I did check it without prop runs fine. Put prop on and run , battery was getting warm. Esc was getting pretty hot when run at full throttle.
flybuy is offline
Old 02-26-2012, 10:32 AM   #4
Friends: (8)
if you add dowels to the tail don't forget to rebalance the plane. You will be shifting the CG to the rear and may make the plane unflyable till you rebalance it.
www.lisf.org
Eastern Soaring League
www.flyesl.org
AEAJR is offline
Old 02-26-2012, 01:14 PM   #5
flybuy
Thanks AEAJR for reply.
I did try to fly after adding rods and rebalancing at what book calls for 58-62mm behind leading edge. It was a nightmare to keep plane in the air.Plane kept wanting to nose dive and i had to keep a lot of up elevator all the time. By balancing from original CG I had to move battery all the way to front and add weight to get plane to balance. So do you think I still need to balance from the 58-62mm point or move back a small amount maybe 65mm and balance. I guess my question is do you ever move the point back farther from what is called for in manual to obtain balance. I have read in post CG should be 1/4 to 1/3 wing width from leading edge. Old but new to flying, but trying to learn.
flybuy is offline
Old 02-26-2012, 02:52 PM   #6
Friends: (8)
I think you may have not balanced at the right point. It sounds like you are super nose heavy. Recheck your balance point and your measurements.
It is also possible you have added so much weight that the plane is having trouble flying at the speed you expect. Every gram of weight increases teh wing loading. As you increase your wing loading you increase your stall speed so you have to fly faster just to stay in the air.
What was the weight of the plane before you started the modifications. Or what is the MFG stated weight.
What does it weigh now?
www.lisf.org
www.flyesl.org
AEAJR is offline
Old 02-29-2012, 03:15 AM   #7
flybuy
Original weight 600g. I don't have anyway to weight it now. You were right though it was nose heavy. I rebalanced took some weight off nose and it flew much better. Still was a little nose heavy. Will move battery back some next flight if and when I get it down out of huge pine tree. 90+ acreas pasture and i still end up in pine tree. Live and learn for me the hard way.lol
Thanks AEAR and everyone else for your help. Can't beat experience.
flybuy is offline
Hawk Sky from Hell! NJSwede Foamies 42 01-16-2012 07:28 PM
hawk sky binding Melnick Beginners 8 10-16-2011 09:53 PM
First onboard flight - Hawk Sky nubbel Video Parking lot 0 10-16-2011 08:23 PM
Newbie with dynam sky hawk sadman ParkFlyers 36 09-12-2011 05:10 PM
Need to upgrade motor on SKY HAWK TW-742 zep77 Foamies 0 04-01-2011 06:37 PM
Page generated in 0.24747 seconds with 31 queries
