Go Back   WattFlyer RC Electric Flight Forums - Discuss radio control eflight > R/C Electric Topics - General > Aerial Photography
Old 09-15-2012, 12:57 AM   #101
watt
Default been away awhile!
I probably missed this info. but here goes! I hear 2.4 radios have a shorter range than the 72s with long antenna. I have a new Hitec 2.4 Optic programmable. And a 72 . something Hitec. Which do you recommend for FPV Flying? I have a FPV setup from Wirelessvideocameras.com Suppose to have a 2 mile range. I have goggles from them too but the older style. I also have an auto-pilot that connects to a laptop and has a long range using sattelites.Feyiu Tech is the company that I got it from. I hear that the 2.4s are interferrance free, so I bought it for use on my auto-pilot system. I can take over the long range flight using the laptop PC so I think I should use it. If I chose using the 72 Frequency Radio I beleive I could pick up interferrance and lose the plane. My system has OSD that tells me my battery power that's remaining, the battery temperatuse , RPM, location and speed, and altitude. it has a return to me function and it can be programmed to go to differant waypoints using the laptop. I'm finishing the plane now and going to maiden flight before I add the Auto-Pilot. If you have experience at this kind of flying I need your input before I fly it with auto-pilot. Want to give me advice without critisms? Thanks to All of You for your feedback, watt..
watt is offline
Old 09-18-2012, 04:29 AM   #102
skyman
skyman's Avatar
All I can say is... I hope your a much better programer than me! :P
If you only plan to fly the plane manually short range, then use the 2.4. Short range as in line of sight like you would do any model airplane, plus a little more. I had a very bad experience with FPV on 72mhz as you can read about somewhere in this thread if you want more info. I got bad interference when flying in a city, out in the country was fine, but I don't really trust it for FPV personally, however many people love it.
"I didn't crash... I just did an inverted nose landing!"
skyman is offline
Old 09-18-2012, 04:40 PM   #103
flybuy
A lot depends on what frequency your VTX And VRX are on and where you fly. Some will interfear with 2.4 more than others. I personaly use 72mhz with 1280 vtx. Some get 3 miles with 72mhz. I have only been out 1/2 mile or so. Working on getting RTH set up in case signal is lost before i go any farther.
Best
flybuy is offline
Old 11-12-2012, 10:18 PM   #104
flybuy
Finally got ET RTH working and made my first flight out of los.Only made ti to 3400 ft before losing signal. Had some problems coming home getting signal ,finally locked in RTH and let it come home. I think I may have got an answer to signal problem from I B Crazy. Needed to twist servo wires. Haven't got a change to check it out since doing that. Weather has been to bad.
Still lots of fun flying out to 3400ft.
https://vimeo.com/52481958
Best
Michael
flybuy is offline
Old 12-06-2012, 08:09 PM   #105
skyman
skyman's Avatar
Best
Michael
Nice!!
skyman is offline
Old 12-06-2012, 10:21 PM   #106
flybuy
[QUOTE=skyman;891191]
Nice!!
[/QUOTE
Thanks Skyman:
Haven't heard much from you lately, Hope all is well!! Have you been flying much?
Twisting servo leads made a big differance in tx range. Made it out to 1 mile on my next flight after that.Longest flight i have made is 1 1/2 miles.
I have enjoyed flying FPV since i got RTH set up. Takes a little of the worry out of it . Still get a little shakey at times.
http://youtu.be/OvWala2OLgQ Just over 1 mile flight
flybuy is offline
Old 02-20-2013, 02:59 PM   #107
skyman
skyman's Avatar
[QUOTE=flybuy;891223]
Originally Posted by skyman View Post
Nice!!
[/QUOTE
Thanks Skyman:
Nice footage! I really need to get a UHF, 1.5 miles was always kinda goal of mine .
No, I haven't been flying too much this winter. Had a bad crash from around 500ft at the start of fall, and simply haven't really gotten a chance to get things all running again. I believe all my equipment is still good, however my OSD isn't picking up satellites. I'll get it all figured out when the weather gets good, and post some flight footage .
skyman is offline
another A-3D build project bill morris Electric Ducted Fan Jets 21 12-10-2011 10:48 PM
Giant Foamie F-15 Scratch Build Otto Dieffenbach Scratch and Kit Built Aircraft 44 11-20-2011 03:50 PM
park zone corsair build questions flying dad ParkFlyers 6 11-17-2011 07:32 PM
First Electric build questions..... Doclove524 General Electric Discussions 33 09-03-2011 03:04 AM
New to flying, couple of foamie Build Questions Brown7 Beginners 5 12-16-2010 02:01 PM
Page generated in 0.19738 seconds with 33 queries
