Old 02-20-2012, 04:43 PM   #1
paxskipper
New Electric Flyer
paxskipper's Avatar
Club: Cumberland County RC Club
Question DX6i Mix to throttle
Hello,
I'm trying to do a mix to throttle to be able to inhibit throttle advance until ready to fly my plane.
I have tried to mix the elevator to the throttle and that has no effect. I am able to mix the elevator to the rudder, so it seems that I can manipulate the mix capability on the DX6i.
So far no joy doing a throttle -> throttle mix to prevent having the motor run.
Any help would be appreciated.
paxskipper is offline
Old 02-20-2012, 05:06 PM   #2
View xmech2k's Gallery21
Club: CVMRCC, SEFSD
Outstanding Contributor Award
Maybe use the throttle cut? Page 41 in the manual.
xmech2k is online now
Old 02-20-2012, 05:10 PM   #3
paxskipper
New Electric Flyer
paxskipper's Avatar
Tried that - no joy. Would work for IC engine, but when released with electric the motor is back on.
Old 02-20-2012, 05:44 PM   #4
Club: CVMRCC, SEFSD
Sorry, I never used it so didn't totally understand how it functioned. So it only holds the throttle full down while the button is depressed? Good to know. If I learn anything more for this I'll let you know. I saw a guy at the field do something like this to a Dx7s, and saying to the guy he did it for that it's not in the manual... I'll ask him next time I catch him. Hopefully it might work with the 6i as well.
Old 06-10-2012, 10:13 PM   #5
Flywhat2
One hitch AE1 -- USN
Flywhat2's Avatar
DX6i throttle Problem
I have a GWS Slow Stick which has been flying just fine controlled by a Spektrum DX6i xmittr. Today after a mild crash ( popped the wing bands, broke prop and broke vert stab) the throttle requires me to push 3/4 of way up before motor starts, then does not go to full RPM. Anyone have any ideas or where I might post to get an answer?
Many thanks, I NEED to fly!
Flywhat2 is offline
Old 06-10-2012, 10:40 PM   #6
Club: CVMRCC, SEFSD
I would be looking more at the motor than your radio. It would have had to have been a real bad crash to shake up your transmitter!
Maybe check the wires to the motor, check the motor for binding/bent shaft, etc.
Old 06-10-2012, 11:27 PM   #7
flydiver
flydiver's Avatar
View flydiver's Gallery1
As stated, motor may be messed up.
My bet is the ESC. You forgot to turn off the throttle IMMEDIATELY at the crash and the stopped prop under power partly fried the ESC. Easiest way to check it a BRIEF check with a new ESC.
fly
flydiver is offline
Old 06-10-2012, 11:52 PM   #8
Flywhat2
Flywhat2's Avatar
Throttle prob. solved. Found other threads that suggested re-bind. I tried that and solved the prob. Many thanks for the replies and suggestions.
Tomorrow I fly again!!
Fly
Flywhat2 is offline
Old 08-14-2012, 12:43 AM   #9
Andrew James
Club: Halifax Electric Flyers
The throttle channel on a DX6i can't be mixed as a slave.
Andrew
Andrew James is offline
Modification of throttle cut switch DX6i cjg Micro Sized Electric Helicopters 0 01-09-2012 11:25 PM
Programming a mix - who wants to walk me thru it? mclarkson RC Radios, Transmitters, Receivers, Servos, gyros 25 07-13-2011 09:07 PM
Dx6i aileron-rudder mix? xmech2k RC Radios, Transmitters, Receivers, Servos, gyros 2 04-28-2011 12:32 PM
New guy asks - Anyone ever setup throttle fixed endpoints on CC ICE75 & DX6i? DanWard Beginners 2 03-11-2011 01:23 PM
DX6i throttle 'calibration' or scaling? tehlump RC Radios, Transmitters, Receivers, Servos, gyros 3 03-09-2011 01:52 PM
Page generated in 0.22309 seconds with 35 queries
