Old 02-27-2012, 11:34 PM   #1
Friends: (9)
Cool Problem with the Flyzone TX-R Albatros
Flyzone Albatros TX-R airplane - Don't buy it unless you have a computer radio
I just purchased the TX-R version of the Albatros at the WRAM show in NY. I was interested to try this AnyLink thing and the plane looked kinda cute. Should be good for in front of the house on quiet afternoons. It was too windy to fly it yesterday but I did get a chance to set it up.
WHY DID THEY STICK THE RUDDER ON THE LEFT STICK?
On a 3 channel R/E/T plane the rudder should be on the right stick. In fact if you look at the manual for the RTF Albatros it shows the rudder on the right stick.
This is usually accomplished by putting the rudder into the aileron channel in the receiver. But on the TX-R planes they have it on the left stick. The receiver is sealed inside the plane so you can't get to it to move the servo to the aileron channel without cutting the plane open.
If you have a computer radio, you can use a mix to map the aileron to rudder at 100% and fix their mistake. But if you are tyring to fly this with a standard radio the rudder is on the left stick.
I sent a note to Hobbico to see what they suggest to fix this. They told me how to fix it on my computer radio but had no solution for a standard radio.
www.lisf.org
Eastern Soaring League
www.flyesl.org
AEAJR is offline
Old 02-28-2012, 11:37 PM   #2
Friends: (9)
The wind finally died down enough for me to fly the Albatros in front of my house. Flies great! It is much faster than I expected. I am going to enjoy this plane a great deal!
I had to use my Futaba 9C Super so I could map the rudder to the right stick. As per the instructions I pulled the RF module out of the 9C, then attached the Anylink module to the battery cover using double sided foam tape as I do not want it permanently mounted on this radio.
Worked just fine and enjoyed flying the Albatros.
www.lisf.org
www.flyesl.org
AEAJR is offline
Old 02-29-2012, 05:00 PM   #3
fmw
fmw's Avatar
My advice would be to map it to both sticks. That way you can turn on the right stick and, if you want to do a hammerhead, you can apply rudder with the left stick. That's what I do.
fmw is offline
Old 02-29-2012, 07:02 PM   #4
Friends: (9)
Cool
I like that approach as well.
www.lisf.org
www.flyesl.org
AEAJR is offline
HELP!!! RX problem!! wittpilot General Electric Discussions 13 10-11-2011 07:19 AM
Albatros by Flyzone - Nothin but trouble HobbyJumper WWI Era 5 08-17-2011 02:41 PM
Albatros by Flyzone - Prop came off! HobbyJumper WWI Era 5 08-12-2011 02:55 AM
Glitch / lock out problem!!!! Gee Power Systems 20 04-14-2011 04:29 AM
Unpossible servo problem mclarkson RC Radios, Transmitters, Receivers, Servos, gyros 13 02-13-2011 01:45 PM
Page generated in 0.06557 seconds with 25 queries
