| FMA Direct Discuss FMA Direct products or ask your support questions. |
#1 | ||
would i be able to conect lipos to the new MPA board that needed these different balence boards? Or would i be better buying a combo with seperate pl8 balance boards instead of the mpa board? I`m just so confused... Alan |
#2 | ||
Why not phone FMA and ask your question of Howard or Tim: they will answer you quickly, with definitive responses.
I have 2 PL 8's, operating in the master/slave mode, and each is fitted with an MPA (though they can be "daisy-chained"), and I use only XH style batteries. The MPA is far superior in design and workmanship to any parallel board I have used to date. |
#3 | ||
President FMA, Inc.
Originally Posted by Lucifer
Hi:
Currently, the MPA is for XH balance connectors only. This means any batteries you plugged into the CP10S-GP/KO6S adapter will connect right up to the MPA. If you still need to support the batteries that you connected to the CP10S-TP/PQ6S, you might want to pick up the equivalent adapter for the PL8; either the standard one: http://www.usastore.revolectrix.com/...ho-Std-Adapter or one or more Safe Parallel versions, which can be daisy-chained so you can charge those packs in parallel: http://www.usastore.revolectrix.com/...rallel-Adapter If you have soldering skills, it would also be possible to convert a CP10S-TP/PQ6S adapter over to support PL8. If you're interested in this, let me know. I can tell you how to go about it. Hope this clears things up for you. Tim Marks |
#4 | ||
hi tim can you give me the info for converting the 10s ballance boards for use with the pl8.
thanks Alan |
#5 | ||
President FMA, Inc.
Hi:
Check the attached photo. 1) Purchase Cellpro 9 position pigtail 2) Remove RJ1 from your 10s adapter PCB assy. 3) Install Cellpro 9 position pigtail as per the photo. |
| Everything You Wanted To Know About Electric Powered Flight | AEAJR | General Electric Discussions | 255 | 01-03-2013 11:49 PM |
| For Sale Hyperion Duo 3+ Like New with All balance boards | Chris Moon | Batteries and Chargers Forsale/WTB | 4 | 03-10-2012 05:50 AM |
| Scratch Built Balance Cables | kyleservicetech | Batteries & Chargers | 2 | 10-09-2011 02:32 PM |
| Balance cable alone charge doesn't work | kyleservicetech | FMA Direct | 4 | 04-18-2011 10:08 PM |
