Go Back   WattFlyer RC Electric Flight Forums - Discuss radio control eflight > Electric Helicopters > General RC E-Heli Talk
Old 03-06-2012, 09:19 PM   #1
NFA Fabrication
Default Spektrum AR600 Suitable for HK450 (Align Clone)?
I recently purchased a Spektrum DX8 to replace the DX5E that came with my E-Flight Apprentice Plane. I used the supplied AR8000 receiver in my plane, and now have the stock Spektrum AR600 left over. I ordered a HobbyKing HK-450 (Align T-Rex clone), and am wondering if the AR600, and my DX8 are a suitable choice for this heli? I am not worried about the DX8's capability, it is the receiver I am concerned about. Is it too basic, or will I be fine?
NFA Fabrication is offline
Old 03-07-2012, 01:35 AM   #2
Turner
I'm a Spektrum user and don't think there should be any problems with it as long as you only need six channels.
Turner is offline
Old 03-07-2012, 04:22 AM   #3
Trammellc2001
Trammellc2001's Avatar
Club: Tulsa Unclub
1kW
You'll be good.
Trammellc2001 is offline
Old 03-07-2012, 06:27 AM   #4
NFA Fabrication
Thanks, I just wasn't sure how the sensitivity control plug worked on the Gyro, and if other receivers had something special to deal with it.
Old 06-28-2012, 10:29 PM   #5
Staubkorb
Staubkorb's Avatar
Send a message via Yahoo to Staubkorb
U need a 7 channel rec to use the transmitter gain sens for a ccpm heli. U MIGHT be able to use the AR600, but but might mean a lot of extra mixing and the gain/mode will have to be set on the gyro itself. The single wire plug should be secured to prevent it from getting where it shouldn't.
I'm not too sure if the ccpm setup will work at all with the AR600, as the swash servos need the AUX2 (Ch7) channel. AR7000s are being dumped cheap on various sites for the 7010s (DSMX), but unless U REALLY feel the need for telemetry...
I'd swap out the 8000 in the plane for the 600.
Pete
BTW, I'm presently putting the same heli together now with a JR DSX11, Align GP780 and the AR7000 rec.
Staubkorb is offline
Old 06-29-2012, 02:05 AM   #6
newjak
AMA Park Pilot Partner
newjak's Avatar
Club: Central Delaware Parkflyers Association
1kW
Friends: (13)
All you need is a 6 channel RX to take advantage of remote gyro gain. I have 8 Trex/clones from 250 on up to 700 and all but the 700 are on 6 channel RX's
A.M.A Park Pilot Partner / Wattflyer Mentor
newjak is offline
Old 06-29-2012, 12:25 PM   #7
zeta30
Team Mulikow
zeta30's Avatar
This is correct. You do not need a 7 channel RX to run a CCPM heli, you only need 6. My 255 and 450 are both on 6 channel RXs my larger ones are on 7 just because I want the satellite RX's to help prevent shadowing. There are plenty of people that fly their 500 and 550's on 6 channel RX's though.
zeta30 is offline
Old 07-01-2012, 03:32 AM   #8
molokaiboy
molokaiboy's Avatar
Club: Maui RC Modeler's
You should do just fine with that rx, your gain will be controlled through your Gear channel.
Flew 450's all the time on 6ch rx's.
Aloha,
Les
Les
Maui RC Modeler's
https://www.facebook.com/mauirc
molokaiboy is offline
Page generated in 0.21239 seconds with 32 queries
