Old 03-08-2012, 07:43 AM   #1
Justus
Default hobbywing flyfun esc wont power up rx. just beeps
Somebody help. I just soldered the bullets onto my hobbywing 40a esc. For 64mm edf 5000kv 1300 4s. Plugged it in and it initially beeps a few times then just a consistant single beep interval. My rx does not light up or anything. I tried it on my Dx7 then to uncomplicate I switched to my tactic four channel. No bec No program card. Did I overheat the esc with my soldering iron ? 60w
Justus is offline
Old 03-08-2012, 08:08 AM   #2
Past President of PSSF
Friends: (8)
I doubt you could have over heated the ESC with a 60w iron, unless you cut the leads to about 1/4", so my first guess is your throttle control is on high.
If the stick is in the lower or off position then check if you have a reversing switch on the throttle channel.
Many ESC's use the high stick position to go into programming mode. some of mine will make the sounds you describe.
You can check the transmitter by using a different plane or speed control.
Let us know what you find, and we'll go from there.
Dave R, Proud PGR rider.
http://www.pugetsoundsilentflyers.org/
Wildflyer is offline
Old 03-08-2012, 08:37 AM   #3
Justus
Well I was able to try another esc and without fail I was able to turn the break on and off properly the first try. I am a novice. I managed to set up my Dx7 for three planes without a manual. It's gotta be something I'm just not stumbling across. Scratching my head ..... Now remember my rx is not powering up, no light. But my other esc powers up my rx even without a motor. I spent many hours and combinations on this esc.
Justus is offline
Old 03-08-2012, 03:13 PM   #4
cliffh
Are you talking about the same receiver? Are you saying that the receiver works with one esc, but the same receiver does not work with the second esc? If so, you most likely just have a bad esc. Sometimes they just don't work.
If you are talking about 2 different receivers, don't forget to rebind!
I would recheck my solder connections...do them over again. You didn't overheat it, but you might just have a bad connection. Another possibility is that a wire broke on the esc from handling.
Cliff
cliffh is offline
Old 03-08-2012, 05:15 PM   #5
Justus
Yes the same tactic set up works on another proven esc. Brake on brake off. I'll try resoldering and let u know. I emailed hobbywing support to see what they say. Shall keep you updated. Thank you.
Justus is offline
Old 03-08-2012, 07:45 PM   #6
slipstick
Outstanding Contributor Award
Are you sure you don't have the Opto (i.e. no BEC) version of that ESC ?
slipstick is offline
Old 03-09-2012, 03:23 AM   #7
Justus
I DO have the opto !!!! No bec. Help.
Justus is offline
Old 03-09-2012, 04:03 AM   #8
gramps2361
gramps2361's Avatar
View gramps2361's Gallery9
Friends: (24)
You will need to buy a UBEC to use that ESC I have had great results with the ones from HURC. The UBEC will supply the power to the RX and power the servos so you can use that ESC.
http://www.headsuprc.com/servlet/the...p-3-Amp/Detail
gramps2361 is offline
Old 03-09-2012, 04:50 AM   #9
Justus
Wow. Ok. Thank-you So much. I don't need a UBEC though. It's just more weight and wiring. Next time ill be sure NOT to buy an opto. But I will have to buy one for this esc. Any suggestions for set up on 64mm EDF ? I wanna push 100mph 4s. I have a Stinger 64. I just bought a 5000kv motor
Justus is offline
Old 03-09-2012, 08:53 AM   #10
Friends: (8)
Just curious, How long have you been flying RC airplanes?
Do you have other experiences with EDF planes?
Old 03-09-2012, 10:23 AM   #11
Justus
Two years. This is my first edf. Flew it twice and it was slightly underpowered.I normally stick to plug n play versions. Naturally I'm a Extra 300 sport flyer. I fly a little bit of everything. Just ordered 2 sbach 342's.
Justus is offline
Old 03-10-2012, 04:12 AM   #12
mred
mred's Avatar
45 Minute Thermal Duration  30 Minute Thermal Duration
You can use a 4 cell NiCad or NeMah battery until your UBEC comes in if you have room to put it in the plane. Just plug the battery into an unused port or come off with a Y on something to get power to the receiver. You just need a 600MAh battery or something like that. It doesn't have to be a big one. That will be enough to power the receiver and servos for a couple flights anyway and then recharge it if need be. It depends on how much you are pulling out of that battery in flight. Some planes you can get 4 or 5 flights with a small battery.
Ed
mred is offline
Old 03-10-2012, 09:20 AM   #13
Justus
Thanks ed ! I was wondering about adding a battery but rather not worth the risk. I do have a 700mah 2 cell. Or maybe a three cell 500mah. Would these work ?
Justus is offline
Old 03-10-2012, 10:00 AM   #14
Friends: (19)
No .... they are higher voltage as Lipo's than Rx can handle.
It needs to be maximum 6V ... preferably a 4.8v pack ....
I have a tiny 250mAh NiMH pack at 4.8v that came out of a supermarket twin motor job ... I fitted a JR style plug to it anmd it now provides bench test power for Rx's ... A 250mAh pack like that will give enough normal sport 3 - 4ch flying on average foamy for about 2 - 3 decent flights. It will go longer but safety is the reqt and not to push the pack too low.
You can also get hold of a 4 cell battery holder for AAA size NiMH and use that. I have various size battery packs of 4.8V in AAA, AA size ... all from battery holders, NiMH batterys inserted, taped up to make sure batterys stay in place ... JR leads coming of. Better than soldered up packs as you can replace 1 or other batterys when they fail ... etc.
Old 03-11-2012, 04:30 AM   #15
mred
mred's Avatar
Yes you can use it IF you use a UBEC with it or some other kind of voltage regulator, but then if you had a UBEC, you wouldn't need it to begin with. No, the battery I was talking about is a NiCad or NeMah 4 cell battery like the old batteries we used to use in our glow engine days when we didn't have all these fancy batteries we have now. What you are looking for is a 4.8 Volt (4 cell) or 6 volt (5 cell) battery, not a LiPo battery. A LiPo runs 3.7 volts per cell, so a two cell battery will be 7.2 volts and while some servos and receivers can handle that, not all of them can and you will burn them up. A 3 cell battery is 11.1 volts and that will burn out almost every receiver out there. I think there are a couple that will handle that, but most won't. Some servos can't handle 6 volts without burning up, so you kind of have to watch that too. Safe bet is to just get a 500MAh 4 cell (4.8V) battery and fly on that.
Ed
mred is offline
Everything You Wanted To Know About Electric Powered Flight AEAJR General Electric Discussions 273 01-09-2017 03:23 AM
100+ MPH Club CHELLIE Hi-Performance and Sailplanes 1994 05-09-2016 04:05 AM
Everything You Wanted To Know About Electric Powered Flight AEAJR Beginners 159 02-16-2016 01:56 AM
Seperate RX battery..does the LIPO pack need to be connected to program the ESC liposucker General Electric Discussions 6 06-12-2011 02:40 AM
rx power FlyingBrick50 General Electric Discussions 28 02-07-2011 07:03 PM
Page generated in 0.46303 seconds with 47 queries
