Go Back   WattFlyer RC Electric Flight Forums - Discuss radio control eflight > Electric R/C Airplanes > WWI Era
Old 03-23-2012, 03:21 AM   #1
dcwwcp
dcwwcp's Avatar
Default 1/10 Albatros D.V build thread (modified simprop kit)
I had threatened to start a build thread on the subject, so I might as well.
I had been looking for a foam albatros kit and the only one at the time was the old simprop kit. My uncle has had his since they came out and it still flys great, and is pretty light with a brushless and lipo power.
the point of starting with a kit instead of from scratch is to give myself more time to concentrate on the scale details. with two kids in atleast two sports it is hard to get time to fly let alone build from scratch.
so I started by working on the mercedes D.IIIa dummy motor.
I have a set of prints that another builder graciously shared with me. his work is nothing short of amazing.
The cylinders are made from simple XPS foam. cut into strips stuck in the lathe, turned and sanded at high speed until the desired size and shape was attained.
plastistruct tubing is used for the piping. easy to use and looks good.
I coated the cylinder with testors clear semigloss acrylic after sanding to give them a harder shell and so they don't soak up as much black paint.
valve spring seats are just cardstock discs made with a punch, then I use light weight spackling put in a plastic sandwich bag with the very tip of the corner nipped off to make a sort of "caulk tube" I used this to fill in the area below the valve guide, above the intake and exhaust ports.
ID:	158389   Click image for larger version
ID:	158390   Click image for larger version
ID:	158391   Click image for larger version
ID:	158392   Click image for larger version
dcwwcp is offline
Old 03-23-2012, 11:12 AM   #2
floss
floss's Avatar
Cool, checking this one out
floss is offline
Old 03-24-2012, 03:13 AM   #3
dcwwcp
dcwwcp's Avatar
Did a little more to the dummy motor.
the cylinders are painted with model masters semi gloss black and glued to what I believe is the coolant porting tube. then I cut them all even on the bottom, sanded them and glued a piece of cardstock below to hold them together.
I started test fitting some pieces for the intake. Iím using plastistruct butyrate plastic tube and elbow fittings to make it easy and itís pretty light. Itís slightly heavier than the styrene, but more flexible. Should make for good radiator pipes too.
ID:	158420   Click image for larger version
ID:	158421   Click image for larger version
ID:	158422   Click image for larger version
dcwwcp is offline
Alien Aircraft BLINKER kit modification thread Turbojoe Scratch and Kit Built Aircraft 26 11-16-2014 10:17 PM
$100 Scratch Build Contest "Best Looking" poll here hillbillynamedpossum Scratch and Kit Built Aircraft 107 08-26-2013 11:23 PM
P-51D House of Balsa 1/10 kit Build Thread max2112 Scratch and Kit Built Aircraft 59 05-04-2013 08:52 PM
E flite Nieuport 17 modified build... dcwwcp WWI Era 24 06-17-2011 01:38 PM
$100 Scratch Build Contest Best Build Thread hillbillynamedpossum Scratch and Kit Built Aircraft 2 05-17-2011 02:43 AM
Page generated in 0.69600 seconds with 35 queries
