Old 04-01-2012, 01:29 AM   #1
mcav8tr
Default Parallel Charging Multiple 2s 500mah iCharger
I have an iCharger 206b and I just picked up a parallel charging board. Normally, I charge the little 2s batteries using my ParkZone charger and an eFlight wall-wart style charger. They charge through the balancing connector. Will the iCharger parallel charge these batteries through the parallel board's balance connectors also or do I need to make some kind of adapter plug to fit the batteries little tiny output plug?
mcav8tr is offline
Old 04-01-2012, 05:03 AM   #2
TheWoodCrafter
The iCharger does NOT charge through the balancing plug.
You will have to connect the main leads to the chargers output.
TheWoodCrafter is offline
Old 04-01-2012, 04:37 PM   #3
mcav8tr
Thanks for the reply. I suspected that might be the case. I just ordered a parallel charging cable for the little JST connectors from ProgressiveRC. That should do the trick.
mcav8tr is offline
Charging multiple Lipo's martyp57 Batteries & Chargers 22 03-20-2013 01:18 AM
charging multiple mcpx batteries at once on Cellpro Gold 4S? matthewcornell FMA Direct 1 10-31-2011 03:54 PM
EP Buddy ParaBoard (Parallel Charging Board) RCFlyer44 Batteries & Chargers 9 05-14-2011 09:02 PM
Page generated in 0.06857 seconds with 23 queries
