Old 04-02-2012, 03:38 AM   #1
skywagon
Default Banana Hobby Airfield FHSS radios..Manual
With my Cessna 182 ARF came the option of a 6 Chan. radio. It was an Airfield brand (powered by 4 AA cells instead of the usual 8). No manual..of course.
It has interesting trim 'lever' functions. They look like standard 'click' trim levers, but they are not. Pressing the trim one direction or the other, the transmitter beeps and the associated servo makes a mini step change.
My question is...what is the range of the 'beeps'..? If seems to be about 20 beeps across its complete trim range or 10 beeps left and 10 right. It has a mystery beep tone change about mid way thru the range. I thought this mystery tone indicated the "mid" point of the trim range, but, it is not same from time to time. The problem is, one does not really know where the trim neutral or mid point is. Because the trim acts like a spring loaded switch, it is always in the middle of what we normally think is the lever type mid/neutral position.
I would appreciate a lead on the radio 'manual' or someone explaining the trim function in this new method of setting the transmitter trim controls.
Thanks......
skywagon is offline
Old 04-02-2012, 03:44 PM   #2
pmullen503
Scratchbuilders Award
Thanks......
Your description is correct. Instead of the analog style of trim you have a computer radio that sets it's trims digitally. The trim levers are no longer connected to pots but to switches.
Anything other than the cheapest 2.4g radios will have a screen showing the trim positions relative to neutral.
pmullen503 is online now
Old 04-02-2012, 08:24 PM   #3
skywagon
No screen on this Airfield transmitter.
Just a series of beeps when the trim swt. is activated in either direction. I am suspecting that it allows about 10 clicks either left/right or up/down for triming.....
skywagon is offline
Old 04-02-2012, 09:54 PM   #4
flydiver
flydiver's Avatar
View flydiver's Gallery1
Outstanding Contributor Award
The beep that is different in the 'middle' is the neutral point. Low end Spektrum work that way also.
fly
flydiver is offline
Old 04-02-2012, 11:59 PM   #5
pmullen503
You'll find the digital trims easier to use while flying in that they give discrete steps. There is less of a tendency to over shoot than with analog trims. Analog trims theoretically have finer resolution but I think you'll find the digital trims adequate.
Tags
2.4ghz , airfield fhss , radio , transmitter , transmitters
Choosing a Sailplane Radio - What to Consider AEAJR Hi-Performance and Sailplanes 3 04-09-2012 01:57 PM
Banana Hobby 38" p 51 Moki210 Warbird Electrics 1 03-23-2012 02:42 AM
Don't ever buy anything from Banana Hobby DrDave Company Discussions 1 09-15-2011 12:36 AM
Banana hobby mx2 skystreaker Beginners 33 06-05-2011 03:12 AM
Page generated in 0.07819 seconds with 27 queries
