Old 04-04-2012, 12:03 AM   #1
emmer03
Default Biplane balancing
How do you balance a biplane? Under the upper wing or the lower wing upside
down.
emmer03 is offline
Old 04-04-2012, 02:20 AM   #2
Turner
Turner's Avatar
Here is a method that will work for any configuration:
http://home.mindspring.com/~the-plum...%20Machine.htm
Turner is offline
Old 04-04-2012, 02:24 AM   #3
View rcers's Gallery57
WAA-08 Pilot
Friends: (9)
down.
Under the upper wing right side up is easiest.
Old 04-04-2012, 04:37 AM   #4
emmer03
emmer03 is offline
Old 04-04-2012, 06:00 AM   #5
5kW  Outstanding Contributor Award  1kW
Friends: (7)
'Where' should a biplane balance is the hard one
Old 04-04-2012, 07:26 AM   #6
Friends: (8)
I've had WW1, 1930's style, fighters, pursuit and general sport as well as Pitts and Skymasters ......... they all seem to be happy with right way up and by using top wing.
Where - as Jet says is the crucial bit and it's funny that near all come out similar with CoG about the mid point or a few mm in front of mid pt. of the top wing except where odd ones have top and bottom wings near vertically in line - then it's balanced same as a single wing job ... 1/3rd chord.
Even my ultimate is just about mid pt of top wing.
Balancing a low wing plane liposucker General Electric Discussions 25 03-21-2012 02:27 PM
$1 foam core biplane build earthsciteach Scratch and Kit Built Aircraft 4 11-27-2011 12:44 PM
Balancing a N-28 icarus46 WWI Era 3 10-19-2011 08:50 PM
Biplane suggestions / thoughts on the following under consideration reef_rc WWI Era 8 08-17-2011 09:23 AM
Balancing an EDF impeller... magnetic balancer vs knife edge balancer Reindeer Electric Ducted Fan Jets 2 02-22-2011 07:50 PM
Page generated in 0.17340 seconds with 29 queries
