Old 04-04-2012, 02:39 PM   #1
npowell28
Default How do i connect my Corona 35mhz receiver
Just got a COrona RD820ii 35mhz receiver through the post. THere is a big warning on the site i bought it from saying that if it is connected wrong it will burn out. I'm stuck on how to connect the servo's. I've attached a photo, which pin should the white wire on the servo connect to?
npowell28 is offline
Old 04-04-2012, 02:49 PM   #2
mumblinaviator
R/C Work and Play
mumblinaviator's Avatar
Club: PaxAero
Friends: (4)
Depending on the servo's you use, you'll notice two different color coding options, but the layout is always the same.
Negative (-) is always the black or brown wire
Positive (+) is always the red wire
Finally, the white or orange wire will fit where it's supposed to.
________
FLY NAVY
mumblinaviator is offline
Old 04-04-2012, 02:59 PM   #3
npowell28
Thats the conclusion i'd come to but it's great to get some confirmation.
Thanks, most helpful
Everything You Wanted To Know About Electric Powered Flight AEAJR Beginners 165 06-28-2017 04:22 PM
2.4Ghz Receiver "Brownouts" E-Challenged Power Systems 38 11-12-2011 12:05 AM
LiFe vs Nih Receiver battery tests kyleservicetech RC Radios, Transmitters, Receivers, Servos, gyros 23 07-08-2011 02:40 AM
Corona Receiver antenna problem sidecar53 RC Radios, Transmitters, Receivers, Servos, gyros 3 04-22-2011 01:43 PM
corona synthesized receiver help CrashnBurn09 General Electric Discussions 21 02-18-2011 10:31 PM
Page generated in 0.15642 seconds with 26 queries
