Old 04-12-2012, 04:28 PM   #1
Glacier Girl
Kamikaze Ace
Glacier Girl's Avatar
1kW
Exclamation Something you might want to check!!!
Last year at my club's fly in I/we got caught in a micro burst.
Everything got wet. I pretty much dried off the birds and packed up for the trip home.
I just got around to pulling some down for repairs and to check em over for this years fly in.
Pulled the Hitec 555 out of the boinked Me 262 as I saw the stress relief was spit on the antenna. Popped the cover off and was greeted with a puff of white dust.
Whole board was covered in corrosion.
Grabbed a can of electronics cleaner and a toothbrush (wife's ) and scrubbed and scrubbed. Then gave it a dunking in Corrosion X to protect it.
I can just imagine what could have happened when I went to fly this bird again with all that corrosion.
Oh well I'll be spending the next couple of days checking rx's in my stuff.
And something you may want to check if your bird gets a little wet.
I normally use Corrosion X on my water birds, but never even though about doing it to my regular stuff.
Glacier Girl is offline
Old 04-14-2012, 03:01 AM   #2
BroncoSquid
Workin on it...
BroncoSquid's Avatar
Club: Bill G fan club!
I find with most electronics, and MOST plastics that encase them, they do very well with a short ride (20 min or so) in the oven set at 100-120 deg. Dries up all water and leaves ALMOST nothing behind. I have done this with 2 digital cameras, 1 underwater camera, 2 watches with the back removed, and a laptop with no ill effects.
Before you freak out, think of it as leaving it in a car on a hot day.
I'm either going to get good at flying em, or get good at fixin em!
BroncoSquid is offline
Old 04-14-2012, 05:17 AM   #3
Yeah, if you can shut off the battery very soon after it gets wet, that's 90% of the problem. (DC battery power on wet electronics tends to cause severe damage to the copper foil patterns on the receiver, like eating them away. The first thing to go is often the extremely thin gold plating.)
I've found it's also a good idea to give the electronics a rinse with a bit of distilled water to get rid of any contamination that might have been in the dunking.
Then, bake it dry at about 100-120 degrees F. As far as the electronics goes, most of that stuff is rated to 150 F, or even higher when its not powered up. Some of those electronic parts are rated over 200 F.
Remember awhile back, Spektrum ran a magazine ad where they placed their receiver inside an enviromental chamber, and heated the receiver til it quit. That receiver quit AFTER the plastic shell around the receiver melted. Something over 300 F if memory is correct.
Old 04-17-2012, 03:22 AM   #4
tom1968
This works on cell phones that have fallen into rivers, and probably works for our electronics too: Put some dry uncooked rice in a small Tupperware container with the lid off and heat in the oven until warm. Then pop the receiver (or whatever) in and put the lid on and let it sit for a day.
I meant to do that! Anyway, I can fix it.
tom1968 is offline
Old 04-26-2012, 12:40 PM   #5
wingspann
Certified Codger
wingspann's Avatar
View wingspann's Gallery5
I dried out a keychain 808 video camera that got washed in my shirt pocket by dunking it in 91% alcohol, then hanging it to dry. Still works perfectly.
wingspann is offline
Old 04-26-2012, 04:24 PM   #6
Past President of PSSF
Friends: (8)
A friend of mine used to work on CB radios.
One day a guy brought in a high end CB base station unit that he had somehow spilled a glass of orange juice into.
Then he dried the radio with a hair dryer !
If only he had rinsed it out with water. The citric acid ate up every tuning coil and small wires in the whole radio. It was a mess inside, sticky goo every where.
One of my daughters cell phones went through the entire cycle of the washing machine.
I took the back & battery off, shook the water out and let it sit in the sun coming through a south facing window, I think the phone got to 110 degrees or so, it worked fine after that, until she fell into salt water about 3 weeks later.
Dave R, Proud PGR rider.
http://www.pugetsoundsilentflyers.org/
Wildflyer is online now
Something else to check, your bec! Glacier Girl General Electric Discussions 6 03-11-2012 01:26 AM
Brushless motor - quick check?? RONALDO_UK General Electric Discussions 17 08-07-2011 08:59 PM
Bringing Model Aviation To Your Schools! MASC - Check It Out! Murocflyer General Electric Discussions 4 12-26-2010 06:54 PM
Here's something you Champ owners may want to check Glacier Girl Indoor & Micro Electric Planes 1 12-23-2010 02:53 PM
User review - Dualsky LiPo Mate check it out gang! rcers Batteries & Chargers 2 12-18-2010 05:24 PM
Page generated in 0.08664 seconds with 29 queries
