Old 04-26-2012, 04:46 PM   #1
plastic northerner
Default FPV OSD
Hi, not sure if this is the right place,”Sorry” I am a bit new to FPV OSD, I have on back order HobbyKing 5.8g 200mw FPV Wireless AV Tx & Rx Set and I am also looking at http://www.hobbyking.com/hobbyking/s...dProduct=17140 The HobbyKing OSD Full Combo. can anyone tell me if they are compatible Thanks, Ron.
plastic northerner is offline
Old 04-30-2012, 01:08 PM   #2
startazz
startazz's Avatar
Yeah you should be good with that mate as it says it will work with any system and they normally do,so i'd say you will be be fine as long as you are using a Pal camera set up but it will still work on NTSC camera but you might find a few problems but nothing to bad.
Good luck and let us know how you get on if you don't mind as it might help someone else who is new to FPV.
startazz is offline
New fpv build and questions skyman Aerial Photography 106 02-20-2013 03:59 PM
EPIC FPV! - BEST U.S. Aerial Videos Wind_of_Change Aerial Photography 11 06-12-2012 11:36 PM
Hugo fpv osd dragonlink drone LipoPilot Aerial Photography 21 04-27-2011 06:50 AM
HobbyKing EPP FPV. Junk or good starter plane? NJSwede Aerial Photography 16 04-27-2011 06:00 AM
Page generated in 0.07233 seconds with 21 queries
