Old 05-04-2012, 04:14 AM   #1
scigs30
Default Peter Rake 18" Se5
Here is a 18" Peter Rake SE5 laser cut short kit from Manzano Lazer. The kit is great and the build only took 2 days. Weigh as shown without electronics is 19 grams. The plans call for the motor and electronics used in the Parkzone Vapor. I have not decided if I am going to use tissue or light plastic film.
ID:	159675   Click image for larger version
ID:	159676   Click image for larger version
ID:	159677   Click image for larger version
ID:	159678   Click image for larger version
scigs30 is offline
Old 05-04-2012, 02:17 PM   #2
offtom
Megans Servant
offtom's Avatar
View offtom's Gallery6
Club: Maggie Mae's Menagerie
WAA-08 Pilot
Wow! Nice looking plane.
You think about silkspan instead of tissue?
http://www.rcgroups.com/forums/showthread.php?t=259388
Cheesy poofs are what Yankees get when they eat Southen Food!! bub, steve
offtom is offline
Old 05-21-2012, 04:37 AM   #3
scigs30
Here she is done and flying. Covered with Domestic tissue applied with 50/50 Elmers glue and water. They I brushed on 2 coats of dope. Flying weight is at 40 grams, the Vapor motor did not have enough power.
I received my Champ Motor in the mail and put it in the Se5 today and she flew great. She balanced out perfectly with no trimming or added weight. It was a little windy but the Se5 did ok, would definitely perform awesome indoors or on a calm day. The Se5 flies at half throttle, but opening it up is impressive. Once again, this was cut by Manzano Laser and built per the plans minus changing out the Vapor motor for the Champ motor. I had to enlarge the 2 holes in the plywood motor mount, add a battery extension cable and made the Motor cable longer to reach the receiver. I hope Charlie can produce this kit for others to enjoy, once again a great kit and design.
ID:	160148   Click image for larger version
ID:	160149   Click image for larger version
ID:	160150   Click image for larger version
ID:	160151   Click image for larger version
ID:	160153   Click image for larger version
ID:	160154   Click image for larger version
ID:	160155   Click image for larger version
ID:	160156   Click image for larger version
scigs30 is offline
Peter Rake SE5 scigs30 WWI Era 11 01-30-2015 03:37 PM
SE5 comparison planefixr WWI Era 8 05-24-2012 08:28 PM
Peter Rake Fokker DVII scigs30 Scratch and Kit Built Aircraft 3 05-02-2012 09:08 PM
peter rake 1/8 albatros dIII waynek WWI Era 6 02-21-2011 02:12 AM
Page generated in 1.12041 seconds with 40 queries
