Old 05-14-2012, 01:43 AM   #1
danauti1
Default Help with hobby zone super cub plz
I recently purchased the Hobbyzone Super cub. I have flown it several times and now when I go full throttle (even with a full battery) the motor cuts out. I can fly it all day at 3/4 or so throttle but go full and it cuts as if the battery was dead. I bought the kit that came with 4 ch spektrum and 11.1v 1300mah battery I even purchased another battery of the same. It does it with either or...
Any help would be greatly appreciated..
danauti1 is offline
Old 05-14-2012, 02:42 AM   #2
View xmech2k's Gallery21
Club: CVMRCC, SEFSD
I'm not that experienced with that plane, but first thing I'd check are the connections to the motor. Also, I believe it's a brushed motor which has a capacitor accross the terminals. It didn't come loose, did it? Also, did this happen after a plane-vs-ground or tree incident, or something like that?
Another thought, it's a geared prop, I believe? Make sure there's nothing wrong with the mesh of the gears, etc.
Good luck, and if you find anything, plz post it as you'll be helping others. Hopefully someone with SC experience will chime in soon.
Old 05-14-2012, 02:43 AM   #3
zoltron55
Club: mon valley rc club
I have the same plane. back off the trim a notch & see if that helps. Do yourself a favor & disconnect the act at the receiver, I had a much easier time flying mine after I did that
zoltron55 is offline
Old 05-14-2012, 02:46 AM   #4
NJSwede
3D wannabe
NJSwede's Avatar
View NJSwede's Gallery1
2kW  1kW
Friends: (11)
I own a cub, but I can't say I've had that problem. I would take the cowl off and slowly increase the throttle and try to see and hear what happens. Are there any weird noises when it cuts out?
Did you buy it new? In that case, call Horizon Hobbies. They'll probably replace it for you.
AMA #959089
NJSwede is offline
Old 05-14-2012, 02:48 AM   #5
View dahawk's Gallery6
Club: 114th RC Aero Squadron
Denauti,
I have the HZSC but mine has been modded out with the emax 480 BL and Hurc 40 amp ESC
Sounds like an esc issue to me but not 100% sure. You can try this though:
1). Turn on your TX and move the the throttle stick to full power
2), Now connect the esc to the battery. You should hear an ascending musical tone followed by 3 beeps then a 2 second pause followed by 2 beeps. Immediately after the 2 beeps, move the throttle to the off position
3. You should then hear one long beep
This procedure resets the esc. Again, not sure this is your problem but might be worth a try.
Good Luck,
dahawk is online now
Old 05-14-2012, 04:46 PM   #6
danauti1
I did have to glue a crack in the gear box back shaft area a couple weeks ago. I noticed there was a vibration in the prop and some thick ca took care of it. I have since flown it several times before this issue arose.
I will try the reset on the esc. Thanks for that advice.
I will also take a close look at the gears and watch it as I increase the speed.
It just seemed wierd to happen all of a sudden and I thought it had to be some sort of overspeed safety or condition. To allow me to fly at 3/4 throttle for 15 mins made me think the battery is ok.
Thanks everyone for the help/advice. I am old to flying but, new to lipo and motors...
danauti1 is offline
Old 05-14-2012, 04:57 PM   #7
flydiver
flydiver's Avatar
View flydiver's Gallery1
That plastic does not glue well. You would be better off with a new gearbox. Since it got that broken is it very suspect as a part of your problem.
When a motor cuts out like that is is likely because the battery is not supplying enough power > you are hitting LVC=low voltage cut-off. Lower throttle is less draw so the battery is not taxed as hard.
You get LVC due to ordinary low battery (normal), excessive draw (binding or other power robbing condition), or a battery that is lame and can't cope with the draw. Over discharging a lipo even a couple times can damage a lipo.
fly
flydiver is offline
Old 05-14-2012, 05:32 PM   #8
danauti1
I will replace the gearbox. As for the batteries I have 2. They both did this on the same day so I didn't think the batteries would be the issue. It did act like a LVC issue but I don't know enough about it.
I still use the charger that came with the plane. It is the hobbyzone car charger and I have heard they are not too good to use repeatedly. Any thoughts on that? I did just order a nice charger for lipos.
danauti1 is offline
Old 05-14-2012, 05:42 PM   #9
flydiver
flydiver's Avatar
None of the Cub electrics are high quality. The battery is relatively expensive and only moderate at best. The charger is quite lame but it should work.
Contrary to your thinking if BOTH batteries are doing it at the same time, the problem is more likely something else.
Are you using floats? What prop are you using.
Do you fly to LVC routinely?
fly
flydiver is offline
Old 05-14-2012, 07:59 PM   #10
danauti1
Originally Posted by flydiver View Post
Are you using floats? NOT YET
What prop are you using. THE FACTORY STILL THAT CAME WITH IT.
Do you fly to LVC routinely? I THINK I HAVE DONE THAT 2 TIMES ACCIDENTLY?
I am headed out to lunch now and am going to check the couple things suggested thus far...Thanks again...
danauti1 is offline
Old 05-14-2012, 09:31 PM   #11
danauti1
Well, I guess I need to start fresh with the gearbox lol...It must have broke again in transport in my truck...I leave it nose down when the kids are in it and the glue must have gave way...
It has a 9x6 prop that is specifically for that model/motor...
I know there wasn't any vibrations last time I flew it so it must have just came apart again...That would have been the first thing I thought...
I'll update soon as I know whats going on...
danauti1 is offline
Old 05-15-2012, 02:21 PM   #12
danauti1
Holy poo...Bought a new gear box and prop even...Set it up, made sure the gears meshed correctly...The motor seemed to not move as freely as I thought it should...(prior to putting it back in the new gear box)
Tried the ESC reset and it didn't work...
Started off slowly with the throttle...Sounded good and moved freely....
Increased throttle and it shut off again at the top end...
Adjusted my trim down as to not let it go full throttle...
At about 3/4 throttle it started singing and surging, then siezed!!!
Smoke from the motor :-(
Open to suggestions for a replacement motor that will work with that gearbox...
danauti1 is offline
Old 05-15-2012, 02:52 PM   #13
startazz
startazz's Avatar
Sounds as though the motor has given up and/or he ESC,now this has happened i'd tend to just go with a brushless motor and a new brushless ESC now as the dahawk as done.
Most 480 motors will work fine in the Super cub and a 30/40amp ESC and you should be good to go.
I'd go with the Easy match up motors from Hobbyking and one of there plush series brushless ESC's if i were you,but the choice is yours and there are loads of to RC out lets to choose from so you will be spoiled for choice.
I'll leave a link in case you want to check out the motor and ESC,the motor is designed to spin a 9x5 so you should be fine with the 9x6 to be honest,if not just use the 9x5 and you might be surprised how well it will fly.
What ever you decide to do i'm sure you will be back in the air soon so good luck mate.
http://www.hobbyking.com/hobbyking/s...r_1320kv_.html
http://www.hobbyking.com/hobbyking/s...e_Series_.html
startazz is offline
Old 05-15-2012, 03:25 PM   #14
danauti1
Thanks for the info! My only question now is do I use the same gear off the old motor and use the gear box? or do I just mount the prop onto the motor somehow?
I am totally new to electric. Never built or modified anything like this yet?
Would I have to buy a different mount? Is this too many questions? lol
Any additional input is greatly appreciated.
danauti1 is offline
Old 09-08-2014, 06:12 AM   #15
noo
Default Hobbyzone Super Cub Throttle Cuts Out
Hey, I just got into flying rc airplanes. I also cannot figure out how to post a question, so I am just replying in this thread even though it is a question haha.
My Super Cub decided to nose dive into the ground (I guess thanks to ACT, I didn't unplug it like so many people suggested). Now when I go over 3/4 throttle, the throttle totally cuts out. When I take the propeller off though, it works just fine. But if I put it back on to the motorshaft, the throttle will cut out again after I get over 3/4 throttle. This did not happen until after my crash. Does anyone know what the problem could be?
noo is offline
Old 09-08-2014, 07:38 AM   #16
View mclarkson's Gallery26
Friends: (8)
Hmmmm.... Well, welcome to WF to begin with.
That's a peculiar-sounding problem. It sounds like it's cutting out under high loads. The higher the throttle, the higher the load. Taking off the prop reduces the load.
But that's about all I've got.
Are you sure the shaft is still straight?
Is there anything weird going on with the propeller? (bends, mud, etc.)
Is there any debris jammed in the motor/gearbox anywhere?
Old 09-08-2014, 02:02 PM   #17
NJSwede
3D wannabe
NJSwede's Avatar
2kW  1kW
Friends: (11)
I agree with Mark. The first thing I would check is whether the prop shaft is straight. Does the plane vibrate more than usual when you spin up?
AMA #959089
NJSwede is offline
Old 09-08-2014, 04:43 PM   #18
flydiver
flydiver's Avatar
!. Do you have ACT (old) or SAFE (new)? That's important.
ACT > disconnect, it's trash.
SAFE > Is good, use it.
It's either mechanical or electrical. Since it runs the probability is mechanical; broken gearbox, bent shaft, dirt in the bearings, etc.
Pull off the prop and cowl and start looking at the operation CAREFULLY. If you take it apart pay attention to the order-take pictures, or your next question is going to be how to put it back together.
fly
flydiver is offline
Old 09-08-2014, 11:02 PM   #19
noo
Thanks for the quick response and suggestions! I will take a look when I get home and let you guys know what I find out. It is a very old super cub that I bought used, and it has ACT. I had flipped it off on the remote, but since the crash I have totally unplugged it, and it will never be plugged in again haha. I do not think the plane vibrates more than normal. Thanks again guys!
noo is offline
Old 09-09-2014, 12:10 AM   #20
flydiver
flydiver's Avatar
It is NORMAL for the motor to point slightly down and to the right to counter motor torque, so don't get freaked about that. Breaking the gearbox, bending the shaft, breaking the firewall, stripping mounting screws, messing up the gears are all common things that happen.
Also, in the panic of the crash people forget to turn off the throttle. With the prop jammed and power still on to the motor the speed control (ESC) can fry due to a short (common newbie error). Usually the ESC either works, or doesn't, but it's possible you've 'maimed' it somehow.
FWIW the Cub ESC is a 'brick' which is an ESC+receiver....IMO a VERY VERY bad idea for Horizon since you have to buy a $50 part to replace a fried $15-20 one.
But, they make more money that way I guess.
fly
flydiver is offline
Old 09-09-2014, 01:58 AM   #21
noo
So I checked for all the things you guys suggested, and everything seemed normal to me. There isn't any mud or dirt in the gears, I do not think that the motor shaft is bent, and I fully charged the battery before I tested it again. I do not know what to do. I made a video showing what the motor does, and I will post the link down below. Any additional help/tips would be greatly appreciated!
https://www.youtube.com/watch?v=2l8uKw2OBzY
noo is offline
Old 09-09-2014, 02:37 AM   #22
flydiver
flydiver's Avatar
Good video!
Old SC, right? Are you using lipos or NiMh? The older-large 10x8 prop and THAT generation of transmitter (TX) strongly suggest NiMh era.
Take a look at this picture.
http://supercubclub.proboards.com/thread/988
If you are using an ESC that uses jumpers like this, and NiMh, you may have knocked out the jumper, which resets it for lipo batteries and you are essentially hitting low voltage cut-off (LVC).
You can replace it with most any PC jumper that fits.
fly
flydiver is offline
Old 09-09-2014, 03:29 AM   #23
noo
Thanks so much for replying and posting that link. Yes, it is an old Super Cub and I'm running a seven celled NiMh battery.
It turns out that I am missing the low voltage cut off jumper, just like you suspected! It's probably out in the field of the crash site haha. I will go buy one soon, and let you know if that fixes the problem. Thank you so much for all your help! I really appreciate it!
noo is offline
Old 09-09-2014, 03:52 AM   #24
flydiver
flydiver's Avatar
If you have ANY old PC motherboard, hard drive, many add-in cards, etc, they almost all use jumpers that are the same.
Once you are looking for more performance this plane is completely capable of some noticeable performance improvement by REMOVING that jumper, getting some 1300mA 3S lipos + suitable charger and a smaller prop. Learn to fly first.
fly
flydiver is offline
Old 09-14-2014, 05:21 PM   #25
noo
Sorry it took me so long to get back to you guys. I've been busy, but this morning I found a LVC jumper. I installed it, and now I can spin up to full throttle! Thank you so much flydiver for sending me that link, and figuring out the problem. My super cub would still be grounded if it were not for you. Thanks again for helping a newbie out! Much appreciated!
noo is offline
"Best Super Cub, Ever" (well, maybe not) KenSue ParkFlyers 16 07-19-2015 03:03 PM
For Sale Aluminum Motor Mounts for Multiplex, Parkzone, and Flyzone Super Cub Planes terrynshed Motors and Speed Controllers for sale & WTB 4 09-24-2012 06:33 PM
For Sale Aluminum motor mount for Flyzone Select Scale Super Cub and 450 size motor terrynshed Motors and Speed Controllers for sale & WTB 43 09-04-2011 05:32 PM
For Sale FS: Hobby Zone Super Cub BNF Kyonic Airplanes - Electric For Sale & WTB 2 07-05-2011 01:38 AM
For Sale HZ Mini Super Cub All American Airplanes - Electric For Sale & WTB 2 02-08-2010 10:17 PM
Page generated in 0.57377 seconds with 67 queries
