Old 05-14-2012, 02:38 PM   #1
plastic northerner
Default AEO Apache OSD
Hi all, looking for some help with HK OSD Combo, maybe I am a bit slow but I just want a colour coded wiring diagram or video showing the power module connected, the AEO Apache OSD don’t show this connected, and can I use the same battery for this and the plan any help will be appreciated.
Ron
plastic northerner is offline
Old 05-18-2012, 11:32 AM   #2
startazz
startazz's Avatar
If you go to HK where you brought it from and go down to the price tab,you will see 4 other tabs which have something like Reviews,Discussion,Videos and files,what your looking for should be in the files tab mate.
I've been told the reason HK does this is to save on paper which in turn help the planet,good or bad thats how it is but if you have the same sort of problem again you will know where to look.
Good luck and if you have any more problems just post again as i'm sure i or someone else will be able to help you out.
The only reason i know my way around HK so much is because i spend to much of my time and money on there,well thats what my Mrs says even though i don't agree with her i have to pretend that i do.
startazz is offline
FPV OSD plastic northerner General Electric Discussions 1 04-30-2012 12:08 PM
Hugo fpv osd dragonlink drone LipoPilot Aerial Photography 21 04-27-2011 05:50 AM
Page generated in 0.05667 seconds with 21 queries
