Old 05-20-2012, 06:37 AM   #1
Cowboy
Airborne Cowboy
Cowboy's Avatar
Default Question on Gens Ace Bat
Are the Gens Ace battery balance plugs wired differant? The reason I ask, I have a Extreme Power Analyzer PA-010 which has a option to balance. Works on all my other batteries, but when I hook it up to my Gens Ace, same type plug, nothing happens on the screen just like I am not hooked up.
If I hook up my two prong connector into the Gens Ace Batt balance plug hooked to my multimeter every cell reads just right. I'm confused. Any help would be appreciated.
Cowboy
Cowboy is offline
Old 05-20-2012, 02:20 PM   #2
View rcers's Gallery57
WAA-08 Pilot
Friends: (9)
Mine are not....
Old 05-20-2012, 02:42 PM   #3
Nope.. just a standard JST-XH type balance plug on my 11 Gens Ace batteries.
Old 05-20-2012, 04:59 PM   #4
Sir Crash-A-Lot
Crash Specialist
Sir Crash-A-Lot's Avatar
Club: East Valley Aviators
What are the other battery types?
There are 4 types of balance plugs but the JST-XH seems to be the most common. This link has a list of some of the more common batteries and the balance plugs they come with.
http://www.empirerc.com/hyperion-mul...ro-p-4483.html
Sir Crash-A-Lot is offline
Old 05-20-2012, 11:08 PM   #5
Cowboy
Airborne Cowboy
Cowboy's Avatar
It is a JST-XH plug ,and the other batteries that it works on are ElectriFly, Common Sense RC. All have the JST-XH plug. The only differance I can see is the Gens Ace batts have differant colors of wire. One red and then three black. CSR batts have red white yellow black from battery to JST-XH connector. I will have to call Hobbypartz I guess and see what they have to say. Thanks anyway guys.
Cowboy
Cowboy is offline
Old 05-20-2012, 11:44 PM   #6
Cowboy
Airborne Cowboy
Cowboy's Avatar
I just figured it out, Gens Ace wires coming to the JST-XH connector are in total reverse of CSR batts and others. I will have to pull all wires out, turn over plug and reinsert them.........geeeeeeeeeeeeeees I wish we had one standard set of plugs for everything, but I guess that won't happen. Its this way with everything.
Cowboy
Cowboy is offline
Old 05-21-2012, 06:00 AM   #7
That must be a fault, all JST-XH connectors should be wired the same way.
If you look at the plug from the side that has the two locating pegs then the red wire should be on the left.
Old 05-21-2012, 08:01 AM   #8
Cowboy
Airborne Cowboy
Cowboy's Avatar
Yep, it is a fault on whoever put them together. Here is a pic of CSRC's and the Gens Ace. Hope it is clear enough.
Cowboy
Cowboy is offline
Old 05-21-2012, 08:01 AM   #9
View mclarkson's Gallery26
Friends: (8)
I use a ton of different size Gens Ace batteries and have no problems with the balance plugs.
Old 05-21-2012, 08:04 AM   #10
Cowboy
Airborne Cowboy
Cowboy's Avatar
What do you balance them with?
Cowboy
Cowboy is offline
Old 05-21-2012, 08:36 AM   #11
Friends: (8)
I use a Passport Dynamite charger and a Thunder AC6 charger, both. Same chargers I use for my EFlite, Blue Lipo, Power Up, and NanoTech batteries (and whatever other brands I have lying about.)
Old 05-21-2012, 08:43 AM   #12
Cowboy
Airborne Cowboy
Cowboy's Avatar
Are your gen aces wired like mine in the picture I posted earlier, the red wire on the right?
Cowboy
Cowboy is offline
Old 05-21-2012, 09:32 AM   #13
Friends: (8)
As nearly as I can tell, my batteries match yours. But they also match all my other brands of batteries. All my LiPos have red on the right, though most of them have multi-colored wires, e.g. Red, White, Blue, Black as opposed to Red, Black, Black, Black.
I have a small voltage meter that I use at the field. It reads the Gens Ace batteries the same as the other ones.
Old 05-21-2012, 09:39 AM   #14
Cowboy
Airborne Cowboy
Cowboy's Avatar
Boy maybe its my CSRC batteries that are wired backwards, but JetPlaneFlyer seemed to think the red should be on the left. thanks for your help Mark
Cowboy
Cowboy is offline
Old 05-21-2012, 09:49 AM   #15
Friends: (8)
I'm not sure what to call 'right' and what to call 'left', but here's a random assortment of four 3S lipos batteries pulled out of my flight box - a Gens, a Power Up, a Zippy and a stock Parkzone. I've made sure that the balance plugs are all oriented in the same way. It's consistently black, something, something, red.
Old 05-21-2012, 10:00 AM   #16
Cowboy
Airborne Cowboy
Cowboy's Avatar
Those batteries are wired just like the Gen Aces I have, so the CSRC batts are maybe ones that are wired backwards as you can see in my picture. Thanks Mark for your time. I gotta go to bed, daylight in 3 hours. Later
Cowboy
Cowboy is offline
Old 05-21-2012, 10:08 AM   #17
Sir Crash-A-Lot
Crash Specialist
Common Sense batteries used to be wire backwards from others, a few friends of mine fried their battery meters because of that.
Old 05-21-2012, 11:23 AM   #18
Yeah, sorry, my description wasnt the best Looking at the XH plug, plug in front of you with wires facing down and the locating pegs facing toward you; the red wire should be on the left.
That's the same as all of the batteries in your photo. Mike is right Common-Sense must wire their balance plugs reverse to anyone else. Kind of ironic that they do it that way given their name
Old 05-21-2012, 05:16 PM   #19
Cowboy
Airborne Cowboy
Cowboy's Avatar
Ok, we have it figured out Marks batts and my Gens Ace are wired correctly and my CSRC batts are backwards. I will end this thread by thanking everyone for their input............Thank you
Cowboy
Cowboy is offline
iMars Gens Ace Charger - Does Anyone Have One? Cole Mayfield Batteries & Chargers 4 03-31-2012 04:49 PM
Wanted iMars Gens Ace Charger Cole Mayfield Batteries and Chargers Forsale/WTB 8 01-29-2012 04:54 PM
GENS Ace lipo battery Flysohigh Batteries & Chargers 14 11-09-2011 10:01 PM
Gens Ace LiPo by HobbyPartz.com hobbypartz New Product Announcements 3 11-09-2011 03:07 AM
Hobbypartz coupon for Sky Lipo and Gens Ace dditch66 Batteries & Chargers 0 09-10-2011 02:22 AM
Page generated in 0.62022 seconds with 59 queries
