Go Back   WattFlyer RC Electric Flight Forums - Discuss radio control eflight > Electric Helicopters > Standard & Large E-Heli Talk
Standard & Large E-Heli Talk Discuss all standard and large sized electric rc helicopters in here
Old 05-20-2012, 01:05 PM   #1
akumar40
Question HK 500 GT Issue
Hi all,
I'm not sure if I'm the only one facing this issue, but would definitely love to hear suggestions. I have an HK 500 GT, with Typhoon 500 motor, 70 Amp HK ESC with BEC, 6 cell, 3000mAH Lipo (Tried and puffed 2 turnigy Nano-Tech packs with rating of 35-70 C). The motor runs HOT, along with ESC and the battery pack.
I have a 12 tooth pinion, and the belt tension is reasonable, the meshing of gears also havs fair amount of play, so not too tight a mesh.
Any suggestions on what could be the issue on this one, as I have recently bought a Zippy, 2650 Mah, 40C pack and am concerned if this would stand the load or not.
Thank you in advance for your time and suggestions.
Amit K
akumar40 is offline
Old 05-20-2012, 01:47 PM   #2
newjak
AMA Park Pilot Partner
newjak's Avatar
Club: Central Delaware Parkflyers Association
1kW
Friends: (15)
I have the same heli with a similar setup. How long are your flight times? The lipo is under increased strain as the voltage drops. If you are a 3D flyer it will surely be harder on your packs than regular sport flying.
A.M.A Park Pilot Partner / Wattflyer Mentor
newjak is offline
Old 05-21-2012, 07:18 PM   #3
akumar40
Hi Newjak, I am not into 3D, just general sport flying. What should be the ideal flight time with a 2650 mAH, 6cell, 40C pack...? Maybe, I am stretching beyond the limit on flight time.
Posting video, for reference:
http://www.youtube.com/watch?v=ElxIee6Cn-k
Thanks for your time.
Amit K
akumar40 is offline
Old 05-21-2012, 07:34 PM   #4
newjak
newjak's Avatar
1kW
Friends: (15)
I fly my packs in both airplanes and helis only down to about 3.7 - 3.8 volts per cell. In my helis that translates to about 5-6 minutes of flight time. In my experience it helps with longevity of my lipos.
newjak is offline
Old 05-22-2012, 05:06 PM   #5
akumar40
Thanks Newjack, guess I will need to control the flight time. I was over this limit that you have specified. Again, thank you for your time, I really appreciate it.
Amit K
akumar40 is offline
Old 05-22-2012, 05:49 PM   #6
newjak
newjak's Avatar
1kW
Friends: (15)
Be kind to your lipos! Enjoy!
newjak is offline
bungie launcher for small hk parkjet? any suggestions? tobydogs Delta & Flying Wings 13 05-01-2013 06:53 AM
BD-5B Comparison of Aeroworks Vs. Hobby King kits frenchstan Pusher Park Jets 0 01-30-2012 05:11 AM
HK watt meter with lipos in series problem emjdrvr Power Systems 1 10-25-2011 06:44 PM
ElectriFly de Havilland Tiger Moth Issue? reef_rc WWI Era 0 09-23-2011 03:57 PM
Page generated in 0.06332 seconds with 29 queries
