Go Back   WattFlyer RC Electric Flight Forums - Discuss radio control eflight > Electric Helicopters > General RC E-Heli Talk
Old 05-21-2012, 01:13 PM   #1
ollie10
Default blade 450
got a problem now with 450 when spooling up the tail is uncontrolable, its so sensative that any movement of the controls in either direction causes it to spin and tonight have seen that the micro head lock G210HL light keeps flashing , tried to rebind , solid light until spool , then light starts flashing , do I need to replace it or is ant adjustment I should try first.
ollie10 is offline
Old 06-03-2012, 07:29 PM   #2
sam94
sam94's Avatar
I'm not heli Guru, but I would think maybe adjust the gyro gain on the gyro itself, and maybe try adjusting the gyro values in the transmitter.
Better still, take it too your LHS and ask them to have a look at it
Hawker Hurricane - Cessna 182 - SR120 - Global Hawk (non stop trouble with).
A bit of a heli flyer
sam94 is offline
Old 06-03-2012, 09:17 PM   #3
Heli Jim
Grandpa, Golfer, Pilot
Heli Jim's Avatar
Make sure that the servo isn't reversed. If it's going the wrong way, it would
be uncontrolable.
Helicopters don't really fly.......
They're just so ugly, that the earth repels them.
Heli Jim is online now
Old 06-05-2012, 01:07 AM   #4
zeta30
Team Mulikow
zeta30's Avatar
When ever I have an issue I retrace a path to when it flew right last. Did I adjust something after I flew last? If so readjust what ever it was back to its original position. Did this happen after a crash? If so then when you rebuilt it you got something reversed. As Heli Jim stated it could be that you got the gyro reversed. You may also have accidentally reversed the tail servo in the TX itself.
I'm not sure what TX you have but if you have a DX7 if you adjust the servo travel limits, (this is where you can adjust how far the servos travel in each direction), if you adjust the tail servo it actually does not adjust the travel limit, it adjusts the piro rate, so the higher number you go the faster the tail will react to your inputs.
Hope one of these helps.
zeta30 is offline
blade 450 ollie10 General RC E-Heli Talk 6 01-13-2013 09:23 AM
New Blade 450 3D kenchiroalpha E-Flite Helicopters 3 05-16-2012 05:24 AM
Sold TRex 450 Clone Kit - Builders Kit or for Parts...almost enough parts for 2 helis ABADGTP Helicopters- Electric For Sale & WTB 1 01-21-2012 07:59 PM
d6i for blade 450 3d ollie10 General RC E-Heli Talk 1 12-21-2011 06:44 PM
FMA CPII + Blade 450 3D ukpete FMA Direct 1 12-20-2011 07:26 PM
Page generated in 0.21976 seconds with 25 queries
