Old 05-24-2012, 07:36 PM   #1
Alabama Flying Dude
Alabama Flying Dude's Avatar
Club: Alabama Phantoms
Default Phase 3 f-16 elevon setup help needed?
I'm workin on the Phase 3 f-16 Kit.
Instructions regarding 2 servos don't relate how to hook up to reciever.
I have the spectrum dx6 an a hobby king spectrim reciever.
Where do I plug in the 2 servos to get them to operate on elevon setting?
aeliron and elevator ports??? ,is my guess, I need someone experienced with this on, for the answer
thanks for the insight
Flying Dude
Alabama Flying Dude is offline
Old 05-24-2012, 08:17 PM   #2
max2112
WG1 pilot #2.
max2112's Avatar
View max2112's Gallery59
Globetrotter Pilot
Friends: (13)
Flying Dude
You guessed right. Just plug the two servos in the Aeleron and elevator plugs. When you build the model in your DX6 make sure and set it up for Delta Wing mixing. That is explained on page 35 of the manual.
If you need more help just check back in!
Please call me John. I came up w/ Max2112 when I thought you were all internet predators after me Lucky Charms!!
max2112 is offline
Old 05-24-2012, 10:59 PM   #3
Alabama Flying Dude
Max, tks a lot I appreciate the tip on page 35. as well. So far so good on the build , Ill be sure to log in t he site when I need advice. Lot of helpful people
Happy Flying,
Dude
Old 05-24-2012, 11:29 PM   #4
crxmanpat's Avatar
Club: Arizona WingNutz
Friends: (24)
Almost every one of my planes are elevon. I fly JR, but Spektrum is the same. First, set the wing type to Elevon (Delta, Wing, I forgot what it is called on the DX6).
Plug the left side servo into Aileron, plug the right side servo into elevator. If your switches on the radio are set to factory spec, then everything should move in the proper direction right off the bat. If not, then reverse switches or switch the plugs on the RX until it is all correct.
Also, when you set the trim on the elevons, "neutral" will have the forward points of the elevons near the bottom edge of the pylon support. I know, it looks like a lot of "up", but trust me that's where you want to start off at, otherwise your handlaunch may wind up nose in the ground in about 20'. Don't ask how I know.
Pat Gagnon
Owner - Nico Hobbies
Your source for micro pusher jets!
crxmanpat is offline
Old 05-25-2012, 07:47 PM   #5
mcross
mcross's Avatar
If you're using a DX6i there are reports of the elevon mix not working correctly and errors in the 6i manual. Check your throws for even travel after setting it up. There's a thread on the other site, including a work around, I'll look it up for you if you need it.
I'm on my 2nd EF-16 and the 3rd is in the box in my closet, when I need it. It's a fun plane!
mcross is offline
Old 06-28-2012, 01:40 AM   #6
jimballs
I'm building the hobby lobby f-16. It's only my second
jet. I just got the micro f-86 and love it. 3 questions. What is v tail mixing mode? With elevons, do you not have ailerons? What is the in flight difference?
jimballs is offline
Old 06-28-2012, 03:21 AM   #7
View xmech2k's Gallery21
Club: CVMRCC, SEFSD
Outstanding Contributor Award
V-tail mixes elevator and rudder.
Elevons mix elevator and aileron.
V-tail is used on planes with wings, and use a v-tail in place of the standard vertical and horizontal stabilizers.
Elevons can be used on flying wings, delta wings, and like on the F-16, the full flying stabilizers that replace the h-stabs and elevators. More maneuverable I think.
Old 06-28-2012, 09:49 PM   #8
jersy/hank
jersy/hank
Club: cape may co. w.a.s.p.s.
Friends: (17)
ihave 1 great flyer stock!! i mix gear to elv. 10% to throw it myself. does't look like much but works good. i can't throw well with left hand. so this way i don't worry about geating on the elv.
jersy/hank is offline
Old 06-29-2012, 11:19 PM   #9
jimballs
Still trying to understand. Guy at LHS said with elevons, no ailerons. can you make elevons work with ailerons too? Doesn't seem like it would roll that well without the ailerons, but that guy said it would. The question is wether or not to cut the ailerons in. F-22, aile and elev can be synced.
jimballs is offline
Old 06-29-2012, 11:21 PM   #10
jersy/hank
jersy/hank
Friends: (17)
jimballs you are flying it like a delta or a flying wing so it is elalons
Old 06-30-2012, 02:28 AM   #11
Augermeister
View dahawk's Gallery6
Club: 114th RC Aero Squadron
Friends: (15)
My Scratchbuilt SU-37 and F4J Phantom work that way. They share servos. Takes a little "putzin" to get it where it needs to be but works good. The mini Jpowers 50mm F-16 edf works that way as well. Using the elevon setting, I think the key think is to set it up with less mechanical throw on the ailerons than on the elevators.
-Hawk
" Something Ain't Right ! "
Old 06-30-2012, 04:24 PM   #12
jersy/hank
jersy/hank
Friends: (17)
guys you have full control over when you set it up elalon. duel rate for elv. duel rate for airl. also same for expo
Old 06-30-2012, 08:48 PM   #13
Love my Stinger
Fishbonez's Avatar
Send a message via AIM to Fishbonez Send a message via Yahoo to Fishbonez
Friends: (15)
Just picked one of these up myself looks like a blast and I too am using the DX6I. any D/R sugestions? Going to maiden her hopefully this evening or in the morning
Happy flying may your crashes be limited and if they are not limited let them be cool.
Fishbonez is online now
Old 06-30-2012, 09:57 PM   #14
Augermeister
Friends: (15)
Fish ,
You're addiction is worse than mine ! LOL I bought the Son of Phase 3, the smaller Jpowers 50mm F-16. Blasphemous for an ole Navy guy! Let em know how you like it. Our club Prez has one and it sure is nice looking in the air.
-Hawk
Old 07-01-2012, 01:32 AM   #15
Love my Stinger
Fishbonez's Avatar
Friends: (15)
Fish ,
-Hawk
Its LIKE CRACK!!!! But legal and better.
Im realy stoked was going to maiden this evening bu found a stripped servo horn screw so I aborted because I did nt have the right siz in the ole flight box. Found one at the house and figured I would wait till morning. Good luck with SOP3 sailor LOL
Old 10-18-2012, 11:31 PM   #16
le fou
subscribe
le fou is offline
Need help with complete setup. KenSue Power Systems 9 01-29-2011 01:36 AM
Page generated in 0.31209 seconds with 49 queries
