Go Back   WattFlyer RC Electric Flight Forums - Discuss radio control eflight > Electric R/C Airplanes > Pusher Park Jets
Old 06-02-2012, 08:35 PM   #1
Cowboy
Airborne Cowboy
Cowboy's Avatar
Default Prop location
On a foamboard pusher jet can you set the prop up higher than the center of the fuse to keep out of the dirt on the belly landings? Does this force the nose down in flight or create any bad tendencies? I have always set the center of the prop on center with the fuse and I break a prop once in awhile even with a good landing, being the prop is hanging down beneath the prop well.
Cowboy
Cowboy is offline
Old 06-02-2012, 08:45 PM   #2
High located thrust line does tend to push the nose down under power.. You may be able to compensate by offsetting the thrust angle so that the projected thrustline passes close to the CG
Old 06-02-2012, 08:54 PM   #3
Cowboy
Airborne Cowboy
Cowboy's Avatar
Thanks for the reply. So I would angle the prop down towards the prop well, but won't this prop wash hit the back of the prop well, creating what, I don't know, maybe I should just try it and find out.
Cowboy
Cowboy is offline
Old 06-02-2012, 09:07 PM   #4
If it's a 'prop in a slot' design then you are kind of stuck...
Old 06-02-2012, 09:13 PM   #5
Cowboy
Airborne Cowboy
Cowboy's Avatar
Not really stuck, just another challenge.........Thanks
Cowboy
Cowboy is offline
Old 06-02-2012, 09:46 PM   #6
pmullen503
Use a prop saver?
pmullen503 is online now
Old 07-15-2012, 02:26 PM   #7
Lord Vader
I have put the the motor completely above the main wing/fuse section with no differences in flight tendancies. Only recently have I started to lower the motor into the prop well site. Like I said, I haven't notice any ill effects in either position. I beleive it's just preference to get the prop high enough above the bottom of the fuse for belly landings and no broken props.
Lord Vader is offline
Old 07-16-2012, 03:08 PM   #8
crxmanpat's Avatar
Club: Arizona WingNutz
Friends: (24)
I agree with Vader. So long as the thrust line remains neutral, you should be able to elevate the motor without causing any pitching issues. And if it does, you can always change the thrust line to accomodate.
Pat Gagnon
Owner - Nico Hobbies
Your source for micro pusher jets!
crxmanpat is offline
Dunam HAwk sky glider with grayson v2 pusher upgrade Prop problems Alabama Flying Dude Pusher Park Jets 3 05-19-2012 04:13 PM
3mm prop adapter impossible? Prop saver issue? mclarkson General Electric Discussions 12 11-26-2011 10:09 PM
Z8-3D Prop -- New invention revolutionizes 3D aircraft hovering performance z-8 3D Flying 227 03-13-2011 12:58 PM
Hacker A60 18L Prop? gdwyer General Electric Discussions 5 01-18-2011 04:36 AM
Page generated in 0.28043 seconds with 33 queries
