Old 06-06-2012, 02:46 PM   #1
chuckinnc
Default How do you measure thrust
I have a junkbox full of motor,prop and esc's, now I am trying come up with
some working setups. I have a wattmeter and scales but need a diy setup to measure thrust so I can come up with something that I hope will fly when I get to the field.
chuckinnc is offline
Old 06-06-2012, 09:04 PM   #2
View mclarkson's Gallery26
Friends: (8)
Here's one way.
Old 06-06-2012, 10:23 PM   #3
I've picked up a scale from Harbor Freight that measures 0 to 50 pounds. To use it, I just tie a rope around the tail of the model airplane, set it on a concrete driveway and run up the motor. Might be that this is not as exact as a real fancy reading, but it works.
Just a reminder though, thrust is not the only factor here. You can have a LOT of thrust with a propeller with a very low blade pitch. And once the model is moving, that very low blade pitch might not have enough prop blast in MPH to fly the model.
One good way to help out in this is one of those computer spreadsheets such as www.motocalc.com. Free for 30 days, then $39.
With this, and an unknown motor, you can "design" a phony motor that will turn over your propeller at the RPM you measure. Just put in the LiPo battery pack, a few numbers for the motor weight, zero load current, motor winding resistance and KV. You can juggle the KV rating to get the RPM your motor turns the propeller. From that, motocalc will let you know how well the model airplane will fly. I've even designed phony motors to represent a glow engines performance.
Welcome New Members to Wattflyer - We ONLY do electric flight here! admin General Electric Discussions 5306 02-21-2017 02:24 AM
BEC question jap71173 Electronic Builders Workshop 21 12-11-2013 08:08 PM
Safe thrust testing, BP Hobbies thrust stand. Dean in Milwaukee Power Systems 0 02-11-2012 05:35 PM
ELERC Micro A-10 Warthog 30mm EDF Beta Test Joe 1320 Electric Ducted Fan Jets 13 02-02-2012 02:15 PM
Prop Selection Hose Man Beginners 7 03-23-2011 02:57 PM
Page generated in 0.07644 seconds with 23 queries
