Old 06-29-2012, 01:21 AM   #1
flyyy
flyyy's Avatar
Default Can you use one channel to power two gyros?
With a GY48V can you set the gain on the ground without using a channel to adjust gain? Then use a y connector to power two gyros using them as rate gyros? You can tell I know nothing about gyros.
flyyy is offline
Old 06-29-2012, 08:29 AM   #2
Friends: (8)
Most gyros will default to a mode and be unsettable to user setting without a sense connected.
Connecting via Y lead should work - but as you have realised - the problem is sense / setting up.
Have you tried Y lead for the sense leads to the aux ch and y lead for control ch ? It may work.
If I was to fit two gyros to my PKJ ... I would have to find a way to control the sense of both and I would try a y lead to my 5th Aux ch.
It's questions like this that get a lot of us further down the road ... and there are people out there that know the answer - c'mon guys - spill the beans - let us know how to do it ?
Everything You Wanted To Know About Electric Powered Flight AEAJR Beginners 148 04-09-2014 11:31 PM
Everything You Wanted To Know About Electric Powered Flight AEAJR General Electric Discussions 267 03-26-2014 02:57 PM
May have figured out what killed my plane- DX5 power glitch CNY_Dave RC Radios, Transmitters, Receivers, Servos, gyros 9 08-12-2012 03:17 AM
Choosing a Sailplane Radio - What to Consider AEAJR Hi-Performance and Sailplanes 3 04-09-2012 12:57 PM
MPJA Power Supply kyleservicetech Batteries & Chargers 0 02-15-2011 02:02 PM
Page generated in 0.13432 seconds with 21 queries
