Go Back   WattFlyer RC Electric Flight Forums - Discuss radio control eflight > Company Support Forums > FMA Direct
Old 07-01-2012, 03:41 PM   #1
BobMaine
BobMaine
Default Cell Pro 10XP Questions
Still learning to operate my new 10XP. (1)Can someone please explain the rational for different balance voltages? The choices are 4.20, 4.22, and 4.10 per cell. How do you know which one to choose?
(2) Didn't see much info on charging other chemistry batteries like NiMh, Pb. Should I assume everyone makes there own cables and they plug in to the outside banana jacks? One battery at a time? Settings for these batteries are found where?
Thanks,
Bob
BobMaine is offline
Old 07-02-2012, 01:48 AM   #2
Tim Marks
President FMA, Inc.
Thanks,
Bob
Hi:
For charging LiPo, mostly people use 4.20v preset. The 4.22v preset is provided mostly for "car guys" who like to pack as many electrons into their batteries as they can to get the most speed at the sacrifice of some battery life. Conversely, we preovide the 4.10v preset to provide the longest possible life out of your LiPo packs. The extra 0.1v to 100% charge actually provides very little in terms of additional run time, but it can substantially shorten the life of your batteries.
Yes, use the outside banana jacks, and for the most part, you will usually charge only one battery at a time. But you could plug a battery into the two left most banana plugs and another battery into the two right-most banana plugs. This would automatically series wire the packs for you. They must be same chemistry, but they can have different cell counts. Just make sure you select a preset that works for the total number of cells in both packs combined. You can safely charge Pb in parallel, but never Ni chemistry. It's likely you will need to wire up your own cables (banana plugs on one end and whatever mates to your battery packs on the other end). We do sell these to get you started:
http://www.usastore.revolectrix.com/...ables-2-pack_2
Hope this helps!
Tim Marks
Tim Marks is offline
Old 07-02-2012, 02:30 AM   #3
Friends: (16)
Tim Marks
On my recommendation, a club member bought a 10XP charger a week or two ago. Checked it out at my home, set up all the presets, checked it on the club members battery. Worked fine.
Took it to his house, the 10XP charger didnt' work! Took a couple of minutes to determine that the total voltage on the balance cable didn't match the voltage on the power leads. The battery power connector was intermittent.
He was going to fly a 30 cc gasser next day with that LiFe pack, this charger likely saved him an airplane. Talked to the club member today, he's putting all of his old (non Cellpro) chargers into a box, and leaving them there.
Old 07-03-2012, 02:32 AM   #4
BobMaine
BobMaine
Tim, thanks for the info. Will make up some new cables or find the ones I had on my Triton.
Bob
BobMaine is offline
Old 07-03-2012, 05:42 PM   #5
startazz
startazz's Avatar
I've got the older cellpro 4s gold charger and the cell pro 10s chargers and i've been more than happy with mine,plus they are idiot prof which is a plus for me.
startazz is offline
Show your Heads Up RC Set Up smokejohnson Heads UP RC discussion 295 04-22-2013 05:05 PM
Cell pro multi + jst PKNEC FMA Direct 3 08-09-2011 10:15 PM
Introducing the ALL NEW Cellpro 10XP Charger Howard Matos FMA Direct 0 07-28-2011 02:04 PM
Cell pro 10s safety code 96 Jlbrad1 FMA Direct 3 02-11-2011 10:17 PM
Page generated in 0.24637 seconds with 27 queries
