Go Back   WattFlyer RC Electric Flight Forums - Discuss radio control eflight > Vendor Discussions > New Product Announcements
New Product Announcements Vendors post their latest and greatest products here to let the world know about them
Old 07-06-2012, 10:50 PM   #1
ServoCity
Default Brand New Ultra Slim HS-7115TH Servo - in stock at ServoCity
IN STOCK! The new Ultra Slim HS-7115TH Servo - $84.99
http://www.servocity.com/html/hs-7115th_servo.html
The included mounting bracket allows it to fit into the tightest wings and most compact spaces.
Control System: +Pulse Width Control 1500usec Neutral
Required Pulse: 6.0-7.4 Volt Peak to Peak Square Wave
Operating Voltage Range: 6.0-7.4 Volts
Operating Temperature Range: -20° to +60° C (-4°F to +140°F)
Operating Speed (6.0V): 0.12sec/60° at no load
Operating Speed (7.4V): 0.10sec/60° at no load
Stall Torque (6.0V): 44.44 oz/in. (3.2 kg.cm)
Stall Torque (7.4V): 56.14 oz/in. (3.9 kg.cm)
Operating Angle: 45 Deg. one side pulse traveling 400usec
360 Modifiable: No
Direction: Clockwise/Pulse Traveling 1500 to 1900usec
Dead Band Width: 2usec
Motor Type: 3 Pole Metal Brush with Ferrite Magnets
Bearing Type: Dual Ball Bearings
Gear Type: Titanium Alloy Metal Gears
Connector Wire Length: 11.8” (30mm)
Dimensions: 1.02” x 0.31” x 1.50” (26 x 8 x 38mm)
Weight: 0.71oz (20g)
ServoCity is offline
Let's talk about servos - Whatever is on your mind AEAJR Beginners 188 02-19-2013 08:51 PM
For Sale Hitec HS 75BB Retract Servo brianfp_400 Radio Equipment For Sale & WTB 0 04-22-2012 02:52 PM
servo zero, angle of the dangle, and flight surface equal travel DanWard Beginners 4 02-10-2011 04:57 AM
Page generated in 0.13560 seconds with 19 queries
