Old 07-10-2012, 05:36 PM   #1
waterfire
Default lateral balance Question
When you balance a plane like the 4*, do you do it upside down by the prop shaft and tail gear? When balanced level, if a wing is touched should it drop, no matter which side? I think I have mine balance correctly, when done, both weighed the same and it stayed level unless I breathed on a wing, then it would roll to the side I breathed on. This is a big MF to hang from a string, I put a hook in the ceiling to do it.
waterfire is offline
Old 07-10-2012, 05:45 PM   #2
Sir Crash-A-Lot
Crash Specialist
Sir Crash-A-Lot's Avatar
Club: East Valley Aviators
This is what I started doing to all my planes since I started flying IMAC. Takes some time but well worth it. There is a article that goes with this chart I can upload as well if you want.
Sir Crash-A-Lot is offline
Old 07-10-2012, 06:26 PM   #3
Past President of PSSF
Friends: (8)
Thumbs up Trim and adjustment chart
I would like to read the full article, I think it be helpful to many people with full built up stunt planes. Small foamies may not need all this adjustment, but this is vital to having a plane that is a true joy to fly.
I have talked to other IMAC flyers, and similar people, some have told me it may take close to 50 flights to get the plane set up perfectly.
I am going to show this to the members of both clubs I belong to.
Thank you for sharing this
Dave R, Proud PGR rider.
http://www.pugetsoundsilentflyers.org/
Wildflyer is offline
Old 07-10-2012, 06:41 PM   #4
Hey, that PDF file is good info!
As for me, just did a quick calculation with my giant Big Stick and it's Hacker A60 motor. The prop is a 19X12, turning at 7100 RPM.
Just spinning up the motor at full power is the same as putting a one pound weight on the left wingtip, due to the torque effects from that motor.
Old 07-10-2012, 06:45 PM   #5
Sir Crash-A-Lot
Crash Specialist
Here is the whole article. Fifty flights sound about right but it can be done quicker by some of the guys I know.
Scratch Built Balance Cables kyleservicetech Batteries & Chargers 2 10-09-2011 03:32 PM
PLS HELP! Spektrum TM1000 Voltage Balance plug raitheslacker General Electric Discussions 5 10-06-2011 04:45 AM
Why would I not want to balance? NJSwede Batteries & Chargers 31 07-15-2011 06:13 PM
Balance cable alone charge doesn't work kyleservicetech FMA Direct 4 04-18-2011 11:08 PM
Page generated in 0.06890 seconds with 29 queries
