#1 | ||
I am about to fly my T28 Trojan durafly model that I got from HK (usa). Anyone know where the CG is located ? Thanks...Kris |
#2 | ||
Augermeister
Club: 114th RC Aero Squadron
Friends: (13)
Is it not stated in the manual ?
" Something Ain't Right !
#3 | ||
Friends: (281)
On all the reports on the T28 Durafly TROJAN, everyone is saying that the CG is way off, to be on the safe side, set the CG at 25% of the wing cord, 1/4 of the way back from the front leading edge, 25% back is a very very safe place to start from, and move the CG back if you need to a little at a time untill you find the sweet spot, every review i have read, says that the MFG recomended CG is Tail Heavy, hope that helps, Chellie
#4 | ||
I just ordered a Durafly T28.
#5 | ||
Recently bought a durafly edge 540. Put it together and adjusted to get cg correct as per instructions. First flight was almost uncontrollable. Turns out it flies great with cg half inch forward of instructions position. This aircraft is 32 inch wingspan and runs on a 4s set up so is ballistic. Scary stuff with all that power and a very rearward cg.
#6 | ||
Friends: (281)
Originally Posted by squidger
I learned the hard way
ARF planes CG info is almost always Wrong, set the planes CG to be a tad nose heavy on all Maiden Flights and adjust from there, a plane with a Tail heavy CG will fly only once and a Plane with a nose heavy CG will fly, but not great LOL ,Take care and have fun, Chellie
#7 | ||
Originally Posted by CHELLIE
Thanks Chellie
![]() I will do so as u adviced . I also found this CG pic for the T28 TROJAN. Need to see if this is 25% from leading edge going back....says it is 2-5/8 inch behing LE. 2 questions : You always measure from LE that is touching the plane's body right? After that you mark that with a X and let the wing rest on your finger tip on each side and it should be a lil' nose heavy correct? If so ...does it matter if I move the finger width wise along the wing few inches from the plane body? Thx! |
#8 | ||
Forgot to post that pic I found about the TROJAN 's CG.
thx |
#9 | ||
The manual says 72 mm = 2.83465 inches = close to 2 and 7/8s.
2 and 5/8ths = 2.625 inches = close to 67 mm Anyone flying one of these? If yes, what are you using? edit: after thinking about it 5 mil forward might be a good place to start. |
#10 | ||
Give me your input. I hung plane upside down on my CG DIY checker. Actual CG, with nose bit down is between manual's suggested point and 25% (from front chord edge of wing)....Actual cg (denoted by A in pic) is more close to manual's suggested point though. Plane nose pointed to right in pic. Is this ok? For maiden? See pic....thx ![]() -- Kris |
#11 | ||
It looks like a good place to start. I usually maiden with a slightly forward CG then once trimmed out I invert the model in flight and the amount of down elevator needed to fly straight and level tells me if the CG is right. I like a rearward CG on my models so they fly inverted with as little as possible down elevator needed. This makes them a bit twitchy but control response is immediate how I like it.
#12 | ||
25% is almost always a safe place to start.
#13 | ||
Thanks guys. There is a small rectangular slot where the esc cable comes out to esc. I can add weights in this slot.
But I need to make sure it sticks to thermocol sides. What can I add as weights, that can stick using super glue? Anything I can buy from art and craft store or HD? THX! -- Kris |
#14 | ||
Go to your local car tyre fitters and ask for a strip of stick on weights.
#15 | ||
I bought a durafly t28 Trojan this week and flew it today. I put the cg where it said in the manual and after a test flight moved it back about 10mm and she flies superbly.So 182mm rear of wing leading edge is good.
#16 | ||
What, me worry?
Club: A.M.A. Member, not currently affliliated with a club
R.C. Hobby is a hole into which one dumps money.
| For Sale Parts from T28 Trojan | 1987tc | Airplanes - Electric For Sale & WTB | 2 | 07-23-2012 04:14 AM |
| T28 Durafly Trojan PNP - Rudder,Gear,flap configuration issue! | 747 | General Electric Discussions | 16 | 07-21-2012 10:48 PM |
| Airfield t28 1400 series | TAUMULLER | Warbird Electrics | 15 | 06-27-2012 11:37 PM |
| Trojan T28 encounter with real plane at the beach | Opuske | Video Parking lot | 10 | 07-29-2011 07:13 PM |
| Checking CG in flight? | DanWard | 3D Flying | 14 | 04-15-2011 12:41 PM |
