Go Back   WattFlyer RC Electric Flight Forums - Discuss radio control eflight > Electric R/C Airplanes > Scale E-Powered Aircraft
Old 08-04-2012, 03:08 PM   #1
guapoman2000
Space Ship 1
guapoman2000's Avatar
View guapoman2000's Gallery56
Friends: (11)
Default FMS / BlitzRC Cessna 182 (55-inch) wing span!
Okay, woke up at 4:30am this morning and took out all parts of the model and hardware, plus glue. Finished the assembly right at 7:38am and this includes trying to use the useless Glue that was provided in the Box! I would not recommend using this Glue! The Strut keepers that go on the underside of the wing and FUSE, I used 5-minute epoxy and worked great! I do hope this Glue that came with the model is okay for the Horizontal and Vertical Stabs as that is what I used at this location.
Things I liked about the model:
1. Scale Details, the Struts, Antennas, decals, paint.
2. Magnet detach / reattach Cowl. (Wish FLyZone SENSEI had this...)
3. All cable harnesses and hardware included.
4. All Servos, including those for FLAPS are included! (Hello Park Zone)
5. Brushless Motor and ESC included.
6. Lights Included.
7. Super easy plastic horn and horn anchor plates that go on super easy!
8. Pilot Figure included! (Hello E-Flite!).
Things that I did not Like about the Model:
1. Instructions are super poor and images are really poor quality.
2. Did not know that the Y-Connectors - Extensions were in the Battery hatch!
3. Wing attachment to FUSE is not the best. You need another pair of hands!
4. Plastic Keel that allows the insertion of Wing Dowels made of poor plastic and easy will break.
5. Glue provided should not be used on Plastic parts -to- Foam parts!
6. Spinner is made of cheap Snap-On Plastic! I hope it does not fly Off! (No securing Screws!)
7. The prop adapter had some questionable threads!
BUILD SUMMARY:
Since I was expecting everything in the plastic bags and did NOT see the Y-Connector / Extension Cable Harnesses, I had thought that they were not included and started to search my hobby drawers for some......:censored:
It was not until I was ready to attach the wing -to- FUSE and did so (It was a Royal Pain in the ASHE :censored. You need another pair of hands to keep the two halves of the wings together while you apply downward pressure to allow for the frontal plastic dowels to enter that sorry designed Frontal FUSE plastic keel piece! When I flipped the model upside down and on it's wing assembly, I took off the Battery Hatch where I noticed all the Y-Connectors / Extension cables!!!
Had to take OFF the freaking Wing Assembly from the FUSE to repeat the insertion of the correct Y-Connectors / Extension cables all over again! (This was in a way okay since I had the Lights Disconnected on the first attempt)
The Rectangular Plastic piece that is inserted Vertically and accepts all cables coming from the Wing Assembly (so many wires!) really needs to be larger in width as just too many wires go through here and it was another PAIN IN THE ASHE!!!
IMPORTANT: This is NOT a beginner model in any shape of the imagination! I do realize it is a high wing but, that is the end of the comparison to a real trainer as this model does not have any Dihedral of any sort (perhaps just a Tinney Tiny bit). Also, if you crash this model, the first that will shatter will be the Frontal Plastic Keel piece that accepts the wing plastic dowels!!
A couple of pictures of my Build process (Could not maiden this morning because I have to get a ESC adapter harness so, I can use my batteries that have Ultra Deans!)
guapoman2000 is offline
Old 08-04-2012, 05:34 PM   #2
Augermeister
View dahawk's Gallery6
Club: 114th RC Aero Squadron
Friends: (15)
Quapo,
Nice build log. I have the same model in my hangar. It was actually my first plane since returning to the hobby last summer. You're spot on about it not being a first plane. Actually put it away for a couple of months and opted for the HZSC. Came back to it and still fly it on occassion. One thing that I has to mod out from the start were the wheels. The wheel pants are sexy but if you're flying off a bumby grass field, forget it. I went with 2.5" Dubros. Still kind of a dog. Two things that kept breaking were the little antenae's on the top of the wing(left them off) and the wing to fuse struts. Several glue apps.
Third plane was the PZ T-28 and I think that one, though a low wing, was easier to fly. 11 planes later in the last year, I'm still experimenting with new models including a handful of scratchbuilt pusher parkjets, some arf edf's and my new first twin-DH-88 Comet.
Might just have to take her out for a Sunday drive now !
" Something Ain't Right ! "
Old 08-04-2012, 10:37 PM   #3
guapoman2000
Space Ship 1
Friends: (11)
Hawk,
Yes, I have read up on this model and seems like the wheels are just too small for grass. I am going to fly her off smooth hard pavement such as...
Old 08-05-2012, 04:31 AM   #4
guapoman2000
Space Ship 1
Friends: (11)
http://youtu.be/jZDfr9mw6zQ
Old 08-05-2012, 05:33 AM   #5
Augermeister
Friends: (15)
Have a great maiden. I'll be interested to hear your opinion !
Old 08-06-2012, 03:54 AM   #6
guapoman2000
Space Ship 1
Friends: (11)
Guys,
Perhaps my initial recommendation of this Cessna 182 not being considered as a Trainer was too harsh on my part. What I experienced was a super docile RC Airplane Model and playing with the flaps did not get me into trouble.
I was super amazed on the Super SLOW flying abilities that this model exhibited. There was at least 5 MPH winds by the time I finally commanded the model up for my very first Maiden flight and it handled the wind very well and super stable.
Landings are just majestic on smooth hard surface such as this High School Band Practice "Concrete" surface! I like the Flaps as it allows for slower touch downs.
I did not have any issues!!!
The model flew beyond my expectations!!!:p
http://youtu.be/Hrn4eZe7S04
Old 08-06-2012, 04:30 AM   #7
guapoman2000
Space Ship 1
Friends: (11)
Thumbs up 2nd Flight Summary (No Video)
Guys!
I flew it for a second time (No Video) and this time I reduced the Flap travel (Using the Travel Adjust Programming on my Spektrum DX7 menu) and the model flew even better.
This model does not need that much flap travel to slow it down.
I was able to test the reaction of the model in super DEAD Calm conditions, much better than during the initial Maiden Flight as the wind completely died down for the 2nd flight.
Right on approach, I killed all Throttle and allowed the model to glide towards the Smooth Hard Surface and right over the Grass, I applied the Flaps and the model still pitched upwards "slightly" and I just commanded some Down Elevator and it came in for a very smooth landing.
Yes, a little mix of Flaps + DOWN Elevator is recommended but, I like the manual method.
Some pictures post flight(s):
Old 08-06-2012, 04:39 AM   #8
guapoman2000
Space Ship 1
Friends: (11)
Thumbs up Battery Type and Capacity
What are you guys using as far as Battery
I am using the 3-Cell, Turnigy 2200mAH, 25C Discharge, Li-POLYs!
Anyone else?
Old 08-08-2012, 06:30 PM   #9
guapoman2000
Space Ship 1
Friends: (11)
Default 5th Flight Dedicated for Still Images!
Thanks Gerry!
With Flaps deployed!
Old 08-08-2012, 06:31 PM   #10
guapoman2000
Space Ship 1
Friends: (11)
Thumbs up 3rd, 4th, and 5th Flights of my new Cessna 182!
Guys,
Thanks to my buddy Gerry (simano) Video Capture using my Digital Point and Shoot 1080p resolution was possible! Thanks Gerry.
The 3rd and 4th flights were recorded in Video and the 5th Flight was dedicated for high resolution Still Image Photography shooting and again thanks to Gerry with his nice SLR Digital Camera. The pictures will be available later in the day.
The Set Screw got lose and it was not because of the hard landings but, rather my inability of tightening it during buildup!
Here are the Videos:
3rd Flight:
http://youtu.be/IevM1YoAPe8
4th Flight:
http://youtu.be/24Sks-a_vcs
Old 08-08-2012, 06:45 PM   #11
Augermeister
Friends: (15)
Great pics and vids ! I'd give my eye teeth to have a nice paved runway like yours.
My 182 looks more like a bush version with the big 2.5" Dubros.
Just upgraded the PZ T-28 with a 2820/07 and 50 amp esc. Testing this weekend. Should be a screamer.
It's fun to go back and pull these birds out of retirement. Now I'm inspired to give the C-182 another go.
Nicely done !
Old 08-16-2012, 11:03 PM   #12
guapoman2000
Space Ship 1
Friends: (11)
This Cessna 182 Model is just fantastic!
I never leave her home!!!
Never thought that I would enjoy a scale General Aviation RC Model this much!
Carlos
Old 11-30-2012, 08:25 AM   #13
guapoman2000
Space Ship 1
Friends: (11)
Default Cessna 182 @ EDWARDS again! 11-25-2012
Hi guys!
I enjoyed my visit at EDWARDS (High School Band Practice Surface) with my Cessna 182 again and it was nothing but spectacular!
This time our good friend David Hart who is a professional photographer for a few RC Hobby magazines came over and took some pictures of the action that morning!
Old 11-30-2012, 09:12 AM   #14
View xmech2k's Gallery21
Club: CVMRCC, SEFSD
Outstanding Contributor Award
Very good looking model! Thanks for sharing!
B-47 1/10.2th Scale, Boeing Stratojet...In The Beginning Flite-Metal Electric Ducted Fan Jets 525 08-25-2012 04:49 PM
Wanted 60-65 inch x 10.75 inch or so trainer wing CNY_Dave Airplanes - Electric For Sale & WTB 0 11-03-2011 03:32 PM
Wanted 60-65 inch x 10.75 inch or so trainer wing CNY_Dave General RC items forsale forum 0 11-03-2011 03:31 PM
Hobbyking Cessna 182 Deluxe with Flaps solentlife General Electric Discussions 20 07-19-2011 04:52 AM
For Sale Cub Super Cruiser, 71 inch span. $295 Free shipping. Henry111 Airplanes - Electric For Sale & WTB 0 01-27-2011 12:07 AM
Page generated in 0.30654 seconds with 45 queries
