Old 08-07-2012, 02:49 AM   #1
WayfaringDreamer
WayfaringDreamer's Avatar
Default Radio > Flaps Question
My rebuilt funcub flew beautifully this evening. Weather was great for flying.
I was using the flaps to slow down before landing and had them set to 60% throw. My DX6i only has a two position switch for flaps.
I noticed that higher end radios have a slider on the side that you can use while keeping your thumbs on the sticks.
I was wondering if you could tie the slider to the flaps and get completely variable control input to them?
Is that possible and does anyone do it?
WayfaringDreamer is offline
Old 08-07-2012, 03:29 AM   #2
Sir Crash-A-Lot
Crash Specialist
Sir Crash-A-Lot's Avatar
Club: East Valley Aviators
Yes it is possible with my Futaba 10CAG to have the flaps on a slider. I can assign any channel to any switch.
No, I do not use flaps.
Sir Crash-A-Lot is offline
Old 08-07-2012, 03:50 AM   #3
pmullen503
Scratchbuilders Award
You can put flaps on a slider or pot and I have, but really only to work out the optimum position and then put them on a switch.
Variable flaps isn't necessarily a good thing. For landing I want the flap position that allows the slowest possible flight and yet still have good aileron authority. It's possible to slow down an airplane with flaps to the point where you have marginal control. What I want is a flap setting (sometimes mixed with elevator) that allows me to set my altitude on approach with throttle (i.e. airspeed). That way I don't have to worry about stalling on approach regardless of wind speed and direction. I use rudder and aileron to line up and throttle to determine where I land. I try not to touch the elevator at all except to flair.
On my Beech twin, I have flaps on a two position switch; Partial flaps to give a slower, more scale like cruise and full flaps to land.
pmullen503 is offline
Old 08-07-2012, 04:20 AM   #4
piercethesky
I totally agree with everything you just said. On my turnigy 9x, I used a pot to figure out the best position while still having that aileron authority to get out of trouble.
On my bixler I could literally slow it down to a crawl with full flap deflection and bring it down with rudder only. That was on calm days feeling a bit frisky! Once I found out the ideal position I stopped using the pot method and just programmed it onto a switch.
piercethesky is offline
Old 08-07-2012, 01:57 PM   #5
WayfaringDreamer
Thanks for the info.
Another question: What do folks use the sliders for?
Old 08-07-2012, 03:15 PM   #6
View rcers's Gallery57
WAA-08 Pilot
Friends: (9)
I use them for flaps all the time and love the variability they allow. I also use them for camber adjustment on gliders. They are often used for launch controls on gliders (DLG's especially).
Old 08-11-2012, 04:28 PM   #7
Club: A lone flyer!
Scratchbuilders Award  Scratchbuilders Award
Whether you have variable position flaps or not rather depends of how big and powerful they are.
For instance a big airliner has to put the flaps down in several stages as the speed decreases to prevent damage and keep changes to the aerodynamic trim under control.
On my plane with big two section flaps they have to be lowered slowly (using a knob) in conjunction with the reducing airspeed.
Put them full down at speed they would either rip off or the plane would loop yet once slowed down (and it really does!) there is only a minor trim change.
quorneng is offline
Old 08-13-2012, 03:22 PM   #8
Motorcycle Jack
I use slotted flaps and have them on the slider adjust. It makes my 182 work like a bush pilot plane, which is what I wanted. I can land it at a fast walk pace with full flaps. Yes it does take full ailerons to control at slow speed but if they're set up for dual rate it doesn't matter.
Motorcycle Jack is offline
Old 08-13-2012, 05:34 PM   #9
View dahawk's Gallery6
Club: 114th RC Aero Squadron
I programmed flapperons for my T-28 just to experiment and they worked pretty good. About 20 deg.
Old 08-17-2012, 06:43 PM   #10
Friends: (18)
Mine are on the top left knob (9x - all switches / knobs assignable to what you want)... so while still working throttle / rudder - I can place my index finger at its side and rotate it to deploy infinitely variable flaps.
I used to have position switch flaps on my Royal P51 years ago and hated it. You had to be so careful about airspeed / throttle before flicking the switch. Now with the rotary knob - the flaps on my 182 are nice. I can adjust to the wind and conditions instead of all or nothing with a switch.
Old 08-17-2012, 08:57 PM   #11
WayfaringDreamer
I just bought a hitec Eclipse 7 pro and they assign flap trim to one of the two variable resistors on the back of the radio.
Basic flap design\mechanism question? xkubr Scratch and Kit Built Aircraft 18 08-04-2013 04:17 PM
Choosing a Sailplane Radio - What to Consider AEAJR Hi-Performance and Sailplanes 3 04-09-2012 12:57 PM
airfield sky trainer 55 inch with flaps and nav lights connector question?? Flysohigh General Electric Discussions 30 09-10-2011 01:17 AM
3 Stage Flaps on a DX6i and a AR600? Hose Man RC Radios, Transmitters, Receivers, Servos, gyros 0 08-29-2011 06:35 PM
Radio Question Futaba 10Cag vs. DX8 RCFlyer44 General Electric Discussions 19 03-01-2011 05:14 PM
Page generated in 0.09861 seconds with 39 queries
