Go Back   WattFlyer RC Electric Flight Forums - Discuss radio control eflight > Electric R/C Airplanes > Special Interest Aircraft
Old 08-18-2012, 07:28 PM   #1
wbuttry
wbuttry's Avatar
Default scratch built gondola build log for hobby king para wing
Hello everybody i'm in the process of building a gondola for a powered parachute .I am not much of a scratch builder so all the help i can get would and will be very much appreciated so to start off i guess i need to list the parts that i have so far. It is gonna be a fairly simple build so here i go ...
1. 3/4 by 3/4 hardwood square dowels for main frame not sure of length i'm gonna build yet .
2.landing gear i'll use it off of a 25 size gasser i got with 2 in tires
3. lite ply plywood scrap pieces
4.sewing thread and gorilla glue i dont use epoxy or ca
5.plastic hoops for knitting i got some 10 incers if need bee can cut and extend we will see will be used for prop guard to keep out of lines out of propeller..
6. using a motor that might be way overkill but i dont half to use full throttle . The motor has 5 1/2 pounds thrust with a 13.6/5 prop and using a 70 amp esc the wing calls for a 3530 motor so if all else fails i can always order a different motor
so far that is what i got i got some nose gear somewhere i'll try to find them and i also got plenty of full size standerd servos to use havent decide on weight shift to turn or use the brakes that will come with time..
wbuttry is offline
Old 08-18-2012, 08:24 PM   #2
wbuttry
wbuttry's Avatar
here i started gluing the frame together there is 2 pieces of plywood sandwhiching the to mounts for the landing gear but only one is glued the other is to help keep every thing in line
ID:	161962 there are to pieces of plywood there only one is glued the other isnt it is used to sandwitch together while glue dries and keep straight
wbuttry is offline
Old 08-18-2012, 11:08 PM   #3
wbuttry
wbuttry's Avatar
love this project so far may grow to hate it
wbuttry is offline
Old 08-18-2012, 11:12 PM   #4
wbuttry
wbuttry's Avatar
few pics of the stuff i'm using
ID:	161972 landing gear i plan to use
ID:	161973 hoops for prop protection
ID:	161974 motor i plan to use
wbuttry is offline
Old 08-18-2012, 11:25 PM   #5
wbuttry
wbuttry's Avatar
making more progress. After gear is dried real good then come the verticel pole that has motor bolted to it....
ID:	161975 gluing in landing gear with gorilla glue the gear has a place to stik rod in a hole so i drilled to hole a plopped them in after i put glue in hole and then put little glue on rod base and started wrapping thread around then soaked it with glue again and
ID:	161976 completed landing gear except trimming off wood at the metals curve
ID:	161977 next after glue sets real good gotta cut off excess t pieces so it will look better and a little liter
wbuttry is offline
Old 08-19-2012, 04:00 AM   #6
Birdmanpete
Birdmanpete
It is taking shape. Good on you. Interested in that motor. I have one very similar. Does yours have a makers name on it. BMP
Birdmanpete is offline
Old 08-19-2012, 04:20 AM   #7
wbuttry
wbuttry's Avatar
nope all i know it is from china like everything else is now days but i'm letting all the glue dry over nite
wbuttry is offline
Old 08-19-2012, 02:25 PM   #8
Love my Super Cub
Fishbonez's Avatar
Send a message via AIM to Fishbonez Send a message via Yahoo to Fishbonez
Friends: (15)
IM sighned up. Looks to be an interesting build. As far as the Spektrum Tx would this be considered an airplane? I assume yes but was curiouse non the less
Happy flying may your crashes be limited and if they are not limited let them be cool.
Fishbonez is offline
Old 08-19-2012, 03:41 PM   #9
wbuttry
wbuttry's Avatar
yes it would be considered a airplan i'm gonna use the elevon mix on my spectrum specially if i do the brake for turning left for lrft right for right and down elevater for flare.
wbuttry is offline
Old 08-19-2012, 08:21 PM   #10
wbuttry
wbuttry's Avatar
More photos. Now put on my first upright drilled pilot hole put glue in the hole and dilled a long wood screw to hold it all together then added side braces glued them in. And after i get the main frame done i will sand it down and get all the inperfections excess glue and fill in dips with filler putty. And then get some epoxy and mix up a good size batch mix with alcahol and paint it with the mixture to seal wood and make stronger joints at the end. But i still got a long way to go for that step .It is not perfect like i mentioned at begining of build log im not a scratch builder none what so ever but doing the best i can though and it will stay together after it is done being built i hope...
ID:	161985 first upright glued in with braces
ID:	161986 yes upright is to long will be cut later whe i get ready to install motor and hoops
ID:	161987 drilled pilot hole in both pieces of wood then ran a 2 inch wood screw athe way couter sunk
ID:	161988 more glue joint pics
wbuttry is offline
Old 08-20-2012, 05:49 PM   #11
wbuttry
wbuttry's Avatar
did some reworking on the frame wasnt wanting to hold together so i'll post new pics and everything else i got done so far sanding filling painting hiding glue radio install and servos cage dang i got still another weeks worth of work at least
ID:	162023 20 inch wheel base
ID:	162024 nose gear on it now
ID:	162025 still gotta trim it or add pieces on the sides of frame to make it sturdier
ID:	162026 main frame completed now getting ready for servos and cage and batt compartment
ID:	162027 side view of frame completed still got a lot of work to do to it
wbuttry is offline
Old 08-21-2012, 02:38 AM   #12
Birdmanpete
Birdmanpete
Looks pretty convincing to me. The weather is still not quite right for my tests but the leading edge is now lowered by 55mm and it sems like it neds to go lower. I think that adjusting the middle risers is more of a fine tuning thing to keep the underside of the airfoil as close to its manufactured shape as possible. (and minimise drag) BMP
Old 08-21-2012, 04:00 AM   #13
wbuttry
wbuttry's Avatar
Hopefully i can get mine in this or next week so we can start compareing notes. I read the forum part on this wing an it says to hang up side down by the riser strap and move the leading edge riser down one inch and then adjust the other risers to take any play in the strings out. And that is where you start at on this 84 inch wing i'll try that when i get it and see if i can get it to kite like it is suppose to. Then adjust as needed . Is the leading edge suppose to be level or down a little compared to the trailing edge?
wbuttry is offline
Old 08-21-2012, 04:25 AM   #14
Birdmanpete
Birdmanpete
As in any airfoil the centre of the leading edge is about two degres higher than the centre of the trailing edge (and here comes the tricky bit) IN THE FLYING ATTITUDE. With a Paraglider it is almost impossible to establish the flying attitude.
However in my tests I had a little insight today. As the wind gets stronger the wing is less likely to fly over the top of you. That's because your weight acting as a tether is way too heavy and because it cannot lift that weight the weight never "centres" under the wing as it must in forward flight. With my leading edge held down by 55mm I have probably got close to the point where, with a weight in a harness I could let it go and not have it go backward. Taking the slack out of ther middle lines is the obvious first step. Under load things may be slightly different but it will also be very hard to see. I saw an indoors upside down test where someone was using weights at the attachment points. Might be worth trying.
I had another knot let go today. Every knot needs glueing. My next test is with a weight and today's the day.
BMP.
Old 08-21-2012, 05:07 AM   #15
Birdmanpete
Birdmanpete
Default Goes Forward.
The picture shows my launch handle; now with 1 pound of old batteries taped on. I raise the wing and when it is almost over head, let it go. At this weight (1 pound) and with less than 10 knot winds it descends, moving forward and shows a glide ratio of less than 1 to 1.
I am happy with the forward movement but the sink rate is too high.
My thinking is that 55mm low on the leading edge is too much and the next test will be at 45mm. Most real Paragliders flown like this with no brake control and no lift source would probably have a glide ratio of less than 5 to 1. I am not sure what to expect of this one. 2 to 1 would be encouraging. At this stage I think more weight would do no good
I have had another line let go but this one was different. This was a failed tab at the wing undersurface. The stitching may have only "pinched" it in place. So now we know the tabs need to be glued into the wing.
BMP
ID:	162039 A Test Set up. Brake lines loose.
Old 08-23-2012, 06:26 PM   #16
wbuttry
wbuttry's Avatar
sounds like you are getting that wing under control did you say u ordered the 2.15 meter wing also i'm waiting on mine to come in so i can get a good look at it and see what i need to do with mine maybe with luck i will get mine in the next day or to i might just half to build a different gondola for it's first trials and then finish this one after i get this wing flying ...
wbuttry is offline
Old 08-26-2012, 12:28 AM   #17
wbuttry
wbuttry's Avatar
hey bird man i got to looking at that pic on hobby king of the bridal location it looks like it is in full length actuall size pic and actual size bridal setup here is the link cause the pic is long and wide leeds me to believe that putting bridal up aginst that pic and then putting the steel rings even with the ones in the pic and it would be a starting point anyway http://www.hobbyking.com/hobbyking/s...dproduct=14284
wbuttry is offline
Old 08-26-2012, 01:06 AM   #18
Birdmanpete
Birdmanpete
That is one very good observation
Old 08-26-2012, 01:54 AM   #19
wbuttry
wbuttry's Avatar
thanks i appreciate that put it in a pdf file that way you can expand and retract it to get your pefrfect size then match up
wbuttry is offline
Old 08-27-2012, 06:06 PM   #20
wbuttry
wbuttry's Avatar
Finally got a day off from work now i work on my gondola for the para glider. I'm still waiting on the wing. Man thats why i hate ordering from china take foreever but that ok. Test ran motor and everything runs good maybe wing will come this week...
ID:	162170 finally got cage on it
ID:	162171 side view
ID:	162172 top view
ID:	162173 front view
ID:	162174 plenty of prop clearence
ID:	162175 on bottom also
ID:	162176 back view
ID:	162177 esc i'm gonna use had for a while used it on 3 different planes requires a seperate bat pack or a bec
ID:	162178 glued and then screwed in
ID:	162179 same with the pipe the pipe i used was for a ice maker hook up to your fridge from lowes
ID:	162180 motor kv 900
ID:	162181 4248 size motor has 5.5 pounds thrust 800 watts
wbuttry is offline
Old 08-28-2012, 01:36 AM   #21
Birdmanpete
Birdmanpete
I have no doubts about the thrust. It really has to go up. Have you given any thoughts to how you will inflate and launch it. I think you might be able to force the wing up with the throttle while the gondola is tethered. On a flat field that could be really neat. BMP.
PS I'm off doing it full size for a fortnight.
Old 08-28-2012, 01:49 AM   #22
wbuttry
wbuttry's Avatar
i'm sure it looks different than you thought it would but like i said i'm not good at scratch building and i'm cheap to and i still have alot of work ahead of me gotta do servos and battery location and place for the bridal location I think the cart would possibly pull it up with me holding the top of the wing then giving it full throttle i think it will rise to the occation and it might even fly i wont be using full throttle all the time just to launch and maybe not even then half to wait and see
wbuttry is offline
Old 08-31-2012, 02:44 AM   #23
wbuttry
wbuttry's Avatar
After waiting a while finally got in my para foil and god it was a mess ropes twisted tied to each other any way very tangled. Dont got them all done yet but got it good enough to seperate the to side. Had to cut the ropes of one of the bridals and retie them. And i see i'm gonna half to do the other side to here are some pics of the wing.
ID:	162253 new wing folded out
ID:	162254 this is the one i cut and retied
ID:	162255 this is one i gotta retie
ID:	162258 the tunnel for the ram air
wbuttry is offline
Old 09-06-2012, 07:12 PM   #24
wbuttry
wbuttry's Avatar
here is a link to a utube video on how to adjust angle of attack on this wing from hobby king
wbuttry is offline
Old 09-07-2012, 10:06 PM   #25
wbuttry
wbuttry's Avatar
here is a vid i did today of how far i got and telling a little bit about this project
wbuttry is offline
B-47 1/10.2th Scale, Boeing Stratojet...In The Beginning Flite-Metal Electric Ducted Fan Jets 525 08-25-2012 04:49 PM
The Hobby King Para Wing Birdmanpete Special Interest Aircraft 17 08-19-2012 03:51 PM
$100 Scratch Build Contest: Simple Pylon Racer Stevephoon Scratch and Kit Built Aircraft 57 01-19-2012 01:27 AM
$100 Scratch Build Contest "Best Looking" poll here hillbillynamedpossum Scratch and Kit Built Aircraft 100 01-07-2012 11:12 PM
$100 Scratch build: Micro SSX Simon Scratch and Kit Built Aircraft 14 05-11-2011 12:37 AM
Page generated in 3.11212 seconds with 108 queries
