Old 08-23-2012, 05:44 AM   #1
Alaskan Flyer
Default Question on C.G. on a HZ Super Cub
Hello All,
I just finished converting my stock HZ Super Cub to Brushless after a crash that broke the stock motor mount. I put in a set up from Heads up. a Emax BL2220/07 motor and 9x4.5 prop, a HURC 30amp ESC, a OrangeRx Receiver with satelite receiver and a 3s 2200 lipo. Still using the stock servos. but the stock plane C.G was 2.125" from the leading edge of the wing. Now its nose heavy at 2.125" it balances at 1.90625" from the leading edge of the wing. will it hurt to fly the HZ Super Cub being this nose heavy?
Alaskan Flyer
Alaskan Flyer is offline
Old 08-23-2012, 08:49 AM   #2
Past President of PSSF
Friends: (8)
When your plane i nose heavy like that, you will have to put up trim on the elevator to force the back end down to keep the plane from losing altitude.
You are a little less than 1/4" nose heavy on a 48" wing so it will probably fly ok but it will feel more aerobatic if you can get the CG correct, don't get tail heavy, that's when a gentle plane turns into a monster.
Try to move your battery towards the rear to get back to the correct balance point.
The effect of the up trim is about the same as carrying extra weight. if nothing can move. maybe a smaller battery will help.
Good luck & happy landings.
Dave R, Proud PGR rider.
http://www.pugetsoundsilentflyers.org/
Wildflyer is offline
Old 08-23-2012, 03:03 PM   #3
CNY_Dave
"A nose-heavy plane may fly poorly. A tail-heavy plane flies once".
So, try it, it may be fine, might even handle wind better (gusts and turbulence).
CNY_Dave is offline
Old 08-26-2012, 05:34 AM   #4
TLyttle
TLyttle's Avatar
Friends: (4)
My SC flew okay with lots of up trim, elevators definitely deflected up. Taped enough lead in the tail to make it fly without trim, and it handles beautifully. I suppose the forward c/g is for beginners (see CNY Dave's quote)...
TLyttle is offline
I got a question Super Cub LP type Fishbonez Beginners 115 09-23-2011 12:48 PM
HZ charger (came with Super Cub) issue earthsciteach Batteries & Chargers 16 06-13-2011 03:06 PM
Finally did some substantial damage to the HZ Super Cub! earthsciteach Beginners 7 05-09-2011 07:40 PM
HZ Super Cub and LED lights - help needed. bcmedic16 Power Systems 9 02-04-2011 09:54 PM
For Sale HZ Mini Super Cub All American Airplanes - Electric For Sale & WTB 2 02-08-2010 09:17 PM
Page generated in 0.06547 seconds with 25 queries
