| Hi-Performance and Sailplanes RC hotliners, electric pylon racers, F5B, F5D, sailplanes and gliders |
#26 | ||
learning by doing
Sand to the line - will do - thanks.
Some wing panel details - I looked at Frans' many build photos on his web site which help tremendously - any miscues such as not sanding to the line are me learning. Gusset - custom cutting photo. wingtip - balsa - slightly buried ply - balsa |
#27 | ||
learning by doing
some of my wing panel weights
weight (grams) weight listing order: panel - left outer - right outer - left inner - right inner raw wood - 19.2 - 18.5 - 24.8 - 24.1 - total 86.6 glued unshaped wing - - - - 21.3 - 19.2 - 25.2 - 24.6 - total 90.3 I accidentally posted some higher kilobyte photos - I've 'dumbed' these photos down to a smaller size, maybe a little too low resolution this time. |
#28 | ||
learning by doing
sanding templates update
I switched to better 2mm ply and sanded a little closer to the line. These are better but still need some touch-up. |
#29 | ||
learning by doing
preparing to sand -
I stacked the two inner panels and two outer panels and sanded to the same size where the wing panel joins will be. I made some long sanding bars with 1/16 inch aluminum L pieces, and double stick carpet tape - it's the about 1/16 inch tape that it used to put down carpet. The sanding part of the bars are 17 inches, two 8.5 inch strips cut to width. The join between the two edges were fortunately not a problem, and nothing came apart from the tape. |
#30 | ||
learning by doing
This is the right inner panel - sanded weight is 16.2 g.
Pre-sanded weight was 24.1 grams |
#31 | ||
learning by doing
I set the bottom of the template about 1mm up from the bottom of the wing panel (photo). The template was removed with a #11 blade. |
#32 | ||
learning by doing
Improved on sanding the sanding templates to the line.
I improved sanding the wing panels to the sanding template as I progressed through the panels. The plane was used for the initial balsa removal on the tip panels. |
#33 | ||
learning by doing
Sanding the polyhedral angles - the sanding block is vertical on the left in the fourth photo. I did the two left panels - both the same angle and then the two right panels.
When making the wind tip panel blocks, cut the outer edge straight, round off later. I filled in the circled area with balsa and sanded straight, curved off wingtip later. Only sand the sides shown (red line on photo) for the polyhedral angles. |
#34 | ||
learning by doing
Front wing peg - According to the plans, I should have angled the front of the peg down a little bit, but it should be ok.
I started the groove with a metal hacksaw blade, did not have a round file so gouged out a groove with drill bits by hand. With a drill bit in the middle, I slid the second panel back and forth to mark the groove for the second panel. |
#35 | ||
learning by doing
I've figured out that with a four panel polyhedral wing with three glue joins, the best order of gluing is the two center panels, then one of the outside panels, and then the last outside panel is the critical one - test fit so that the left wing tip is the same height as the right one. For this wing, all the sanded side angles should be the same.
So, I've glued 3 of 4 panels together. Sometime soon, I'll test fit the last one and make sure the wing tip heights match, and then glue the last panel on. |
#36 | ||
learning by doing
For gluing the side panels together, I used 30 minute epoxy and microballoons - 30% epoxy, 30% hardener and about 40% microballoons, or maybe 1/3, 1/3, 1/3. The microballoons shorten the epoxy hardening time a little.
The microballoons make the epoxy white and a little lighter, both nice features if building with white Depron. (And the little lighter is nice for this build.) |
#37 | ||
learning by doing
Another thing I learned (when using epoxy building foamies) is to not try to use less than about 1.5cc of epoxy and the same amount of hardener even if I plan to use just a tiny bit of the mixture.
When trying to mix just a little bit, it was too difficult to guess the identical amount of hardener for the amount of epoxy. A little too much or too little hardener, and the mixture would never cure properly. (the glue ended up sticky even after 3-4 days.)So, I'd rather mix up 3 cc of epoxy, hardener 1:1 ratio and waste 2.5cc and have properly cured epoxy. |
#38 | ||
Club: RMVV
Hello knot,
I am not sure mixing in micro balloons is a good idea. The weight advantage isn't that big and on the other hand micro balloons lowers the strength of the bond. Better is to sand the joints precisely to get a (almost) perfect fit with no gap. Prick some holes Tape the bottom side Ad epoxy liberally Hinge back and wipe of any access epoxy. This method uses a small amount of epoxy(weight) and is very strong. Frans |
#39 | ||
Friends: (12)
this is an enjoyable build ya have going here aeroknot
. frans, i never really thought of using tape on a wing seam like that to join halfs. very nice. . aeroknot,your also doing a nice job with the camera,it's a lot of fun to to see your progress.
narrow is the place to land.
..wide is the space to crash ....choose the narrow way!
#40 | ||
learning by doing
Thanks for the note and photos, Frans. I sanded as best as I could although my sanding skills are improving. I have a wee gap here and there. I've already glued three of the panels together, the two center ones and I think the left wing (I'm right handed so that's the throwing blade wing!) I'm confident the epoxy-microballoon glue joint will be strong enough, particularly with the short CF reinforcement on the plans. (But you're absolutely right that there is minimal weight savings.)
I wish I had made little pin holes in the facing parts when gluing the ribs and the wing panel blocks since I used the Titebond II - I did that with the epoxy and wing panel joints. Thanks for the good words, stuart. I like lots of photos - beats lots of words! These are the only photos of the glued panels I've taken so far. Building will slow down over the next 2-3 weeks. I have made the throwing blade and am working a little on the elevator and rudder. I'll post a few photos over the next few days, so photos will lag my progress a little. I have some thin 5mm wide carbon tow which I can hopefully use instead of the kevlar roving for the fuselage, but that's a few weeks away. |
#41 | ||
learning by doing
To verify that the outside wing panels were at the same angle, I used two methods.
1. Direct looks about right measurements (Photos against the wall.) 2. Placed the glued panel down and put the supporting blocks under each side, then placed the to be glued joint down, checked and glued. |
#42 | ||
learning by doing
Maybe I'll use a worse camera....that way some of my building blemishes would not be so outstanding
![]() Here are some the wing panel joint detail photos. Wing panel weight tomorrow after the last glued joint hardens. |
#43 | ||
learning by doing
I'll fix the left bottom later on.
edit - Also, I think I placed the sanding templates on the right outer panel more aft, so that there is a mismatch in the larger front and trailing pieces compared to the center panel. Still learning. The overall wingform is preserved and I'm sure my built mimi will fly well despite the learning curve |
#44 | ||
learning by doing
Here's a photo of the unsanded wing panel blanks.
#45 | ||
learning by doing
Some early sanding on the horizontal stabilizer and elevator.
#46 | ||
Club: RMVV
The total center angle is 12 degrees and the total angle of each tip is 6 degrees. Lifting each side 26 mm gives a total angle of 12 degrees Here you used the same jig. You should have removed the left block to get a 6 degree angle on the tip. ![]() ![]() ![]() Frans |
#47 | ||
learning by doing
Good eye, Frans! That sure is disappointing. Sigh. I'm glad you caught that and it sure is awesome that your helping me out
![]() Well, the weight of the wing fully glued with too much angle was good at 59.9g. Looking at the tip panels on the current photo, the angle looks maybe even worse, a little greater. I think the center panel measures about 10 degrees and the outer ones 11 to 12. I think I sanded the correct angles, but brain dead used the same gluing jig on the left wing panel as the center which is why the bottom of the left joint was wide. Then a couple of days later, I matched the right wing panel angle to the left side. I think I'll continue with the fuselage, etc. It would be better to rebuild the wing rather than to hack correct this one. I'll be able to build the wing better the second time, now that I have some experience. Won't get too much done the next few days, working. So, the plan is to continue with everything else, and then build a second proper wing at the end. I'll probably end up using both wings - I have plenty of 1.5mil laminate - wish it was 1.2mil. |
#48 | ||
Friends: (12)
seems a fresh razor blade with careful slicing would separate the wingtips and a new angle could be fashioned. remember,a little extra length on the wings [or less] wouldn't effect your flight . far less work than building a new wing for sure. i tend to stick with what ever part i'm building before moving on to other parts,but it's not a bad idea to build the fuse and come back to the wing when less frustrated. i'v spent many hr's in the workshop and good or bad ,it's always rewarding and fun in the end.
one thing i love about building is figuring out how to rectify errors and still have a good build. from what i can see....you'v got a real nice build going on here. wonder what this bird would look like with a 118"ws. a "bird of time" .
#49 | ||
learning by doing
Thanks, stuart - I've been working non-stop at the job, just made it back to wattflyer. I'm going to order some kelar roving and unidirectional CF and proceed with everything else. I think I have enough decent balsa to build a second wing and since I now have a little more experience, building the second wing really won't take very long. Time available for building is highly variable.
| Model Airplane Building Clinic >> Begins 29 Sep. All Skill Levels Welcomed | Murocflyer | General Electric Discussions | 282 | 11-04-2012 10:35 AM |
| Model Airplane Building Clinic | Murocflyer | Scratch and Kit Built Aircraft | 2 | 10-01-2012 10:53 PM |
| Model Airplane Building Clinic - - Instructors Needed | Murocflyer | ParkFlyers | 9 | 09-21-2012 01:55 AM |
