Go Back   WattFlyer RC Electric Flight Forums - Discuss radio control eflight > Electric R/C Airplanes > Hi-Performance and Sailplanes
Old 09-26-2012, 12:55 AM   #51
aeroknot
learning by doing
aeroknot's Avatar
Default Throwing blade
Good to know, Frans. I sanded for about 5 minutes yesterday, that's the only free time I've had to build the past few days.
I started my throwing blade last week (9/13). It's a little thin and I may add two more layers. Filed in a water bucket as in Frans' web site photos.
I used 0.5mm x 10mm (edit correction 8mm wide) CF flat inside a cylindrical CF tube seems pretty durable. Currently weighs 1 g.
I tried to get the light to reflect over the embedded CF flat on the photo.
Name:	2012 09 12 - DSC_2851.JPG
Name:	2012 09 12 - DSC_2852.JPG
Name:	2012 09 12 - DSC_2853.jpg
Name:	2012 09 13 - DSC_2858.JPG
Name:	2012 09 13 - DSC_2859.JPG
ID:	162846 embedded CF flat
Name:	2012 09 13 - DSC_2860.jpg
aeroknot is offline
Old 09-29-2012, 11:21 PM   #52
aeroknot
learning by doing
aeroknot's Avatar
I made a second throwing blade, and added 0.5mm CF flat and thin non-directional CF to the first.
The second throwing blade has two pieces of 0.5 x 8 x 45 mm CF flat, both inside the 10mm diameter CF tube.
Name:	2012 09 29 - DSC_2909.JPG
Name:	2012 09 29 - DSC_2912.jpg
Name:	2012 09 29 - DSC_2922.JPG
aeroknot is offline
Old 09-29-2012, 11:24 PM   #53
aeroknot
learning by doing
aeroknot's Avatar
Default It's the journey....
I'm completing my first wing. It'll be good practice.
Name:	2012 09 29 - DSC_2899.jpg
Name:	2012 09 29 - DSC_2900.JPG
Name:	2012 09 29 - DSC_2901.JPG
Name:	2012 09 29 - DSC_2902.JPG
aeroknot is offline
Old 09-29-2012, 11:27 PM   #54
aeroknot
learning by doing
aeroknot's Avatar
Default ...not the destination
improving from one to four. CA sometimes takes a while to harden, I found out.
Name:	2012 09 29 - DSC_2904.JPG
Name:	2012 09 29 - DSC_2903.jpg
Name:	2012 09 29 - DSC_2905.JPG
Name:	2012 09 29 - DSC_2906.JPG
aeroknot is offline
Old 09-29-2012, 11:33 PM   #55
aeroknot
learning by doing
aeroknot's Avatar
I ordered some uni-directional CF and uni-directional (UD) kevlar, the kevlar to substitute for the rooving.
1" x 12 feet of each from ACP composites.
3.7 oz CF,
2.5 oz kevlar
hopefully not too thin,
2.5 oz. "Uni-Web" Unidirectional Kevlar®
3.7 oz. "Uni-Web" Unidirectional Carbon Fiber
aeroknot is offline
Old 09-29-2012, 11:35 PM   #56
aeroknot
learning by doing
aeroknot's Avatar
I prepared the balsa with some thin spray polyurethane - I also have some spray clear acrylic - but used the spray polyurethane to prepare for fiberglassing the wingtips and wing panel joints.
Name:	2012 09 29 - DSC_2920.JPG
aeroknot is offline
Old 10-02-2012, 01:12 AM   #57
aeroknot
learning by doing
aeroknot's Avatar
Default a lucky cut
test test measure measure test cut
used the skyshark p100
Name:	2012 10 01 - DSC_2927.jpg
Name:	2012 10 01 - DSC_2930.JPG
Name:	2012 10 01 - DSC_2931.JPG
Name:	2012 10 01 - DSC_2932.JPG
Name:	2012 10 01 - DSC_2933.JPG
Name:	2012 10 01 - DSC_2935.JPG
aeroknot is offline
Old 10-02-2012, 01:18 AM   #58
aeroknot
learning by doing
aeroknot's Avatar
Default a short fuse
note that Frans on his web site shows a rectangular blank as the fuselage bottom, and shapes it after all the gluing, which is the preferred method, but I had already cut my fuselage bottom.
Be careful of epoxy leaking to the side of the front CF tube block when gluing the front block in - this will interfere with the fuse sides if not cleaned up.
Name:	2012 10 01 - DSC_2928.JPG
Name:	2012 10 01 - DSC_2929.JPG
Name:	2012 10 01 - DSC_2936.JPG
Name:	2012 10 01 - DSC_2937.jpg
Name:	2012 10 01 - DSC_2939.jpg
Name:	2012 10 01 - DSC_2940.JPG
Name:	2012 10 01 - DSC_2941.JPG
Name:	2012 10 01 - DSC_2944.JPG
aeroknot is offline
Old 10-03-2012, 09:25 AM   #59
oswaldcroaker
I'm enjoying your thread; thanks. One question: on the plan is shown "Template balsa 1x1mm, 1x5mm" and "Template ply 0.8". It looks like these are in reference to the wing tip piece; is that correct? It looks like you used two ply pieces instead of two balsa pieces; am I missing something here? I guess I'm not sure what "Template balsa" and "Template ply" are referring to. Any help would be appreciated. Thanks!
oswaldcroaker is offline
Old 10-04-2012, 09:05 PM   #60
Frans Bal
Frans Bal's Avatar
Club: RMVV
The tip is a lamination of three pieces.
First 1 mm balsa
second 0.8 mm ply
third 5 mm balsa
The balsa pieces fit between the D-box and the trailing edge.
The ply piece is a bit bigger at the D-box side. The extra material fits in a slot cut in the D-box
Frans Bal is offline
Old 10-04-2012, 10:09 PM   #61
aeroknot
learning by doing
aeroknot's Avatar
Frans' web page (http://f3k.nl/) (also, email him for his plans) has very detailed and extensive step by step documentation of the Mimi build. Click on the "MiMi" link there - lots of photos organized by plane part. (There's also a link to his web page on post one.) He's posted a few of those photos here - very nice.
The wing tip I built according to his plans, with no unintentional deviations.
The only major building blunder so far was to glue the wing outer panels at the incorrect angle - therefore my current wing is a "practice" wing.
aeroknot is offline
Old 10-04-2012, 10:14 PM   #62
oswaldcroaker
Thanks. I emailed Frans and he was very helpful. He answered my questions and then directed me to his site, which, BTW, is great!
Old 10-04-2012, 11:31 PM   #63
aeroknot
learning by doing
aeroknot's Avatar
Glad to answer questions and to help! It's a great idea to review his photos before a major building step.
aeroknot is offline
Old 10-04-2012, 11:43 PM   #64
aeroknot
learning by doing
aeroknot's Avatar
Default fuselage front 1 - 2 - 3
1 - sides - wait a little while - (using Titebond II)
2 - top - and wait 10 minutes
3 - front - wait until set
and then sand.
Not showing every detail of the build, such as forming the front block, etc - but most of those are on Frans' site. It's a good idea to check his photos.
Name:	2012 10 03 - DSC_2945.JPG
Name:	2012 10 03 - DSC_2946.JPG
Name:	2012 10 03 - DSC_2947.JPG
aeroknot is offline
Old 10-04-2012, 11:49 PM   #65
aeroknot
learning by doing
aeroknot's Avatar
Default tail feathers - sand too much and then some more!!
I wasn't sure what to use on the trailing edge - I used a hardwood 3mm dowel (maybe cedar?), planed and sanded. I like the trim, though. Ply would have worked. Could probably still sand some more
Name:	2012 10 03 - DSC_2952.jpg
Name:	2012 10 03 - DSC_2956.jpg
Name:	2012 10 03 - DSC_2957.jpg
aeroknot is offline
Old 10-04-2012, 11:53 PM   #66
aeroknot
learning by doing
aeroknot's Avatar
Default last night's dinner
and today's lunch.
shrimp, potatoes vegetables. I'll post the recipe if anyone is interested. Could substitute other for shrimp.
Name:	2012 10 03 - DSC_2960.JPG
aeroknot is offline
Old 10-05-2012, 12:01 AM   #67
aeroknot
learning by doing
aeroknot's Avatar
Default A diminuative deviation...
...a minor modification. I used 10mm wide balsa for the elevator support, glued then sanded from about 7mm at the CF tube to 10mm at the elevator side.
Other than that, I don't plan on any modifications.
When I'm finished buildings - and I can see it from here - I'll post a list of unplanned deviations from the plan - blunders, oops, gaffes etc.
Again, note that how I'm building (beginning balsa builder) and order of building may differ than what's better
Name:	2012 10 04 - DSC_2963.JPG
Name:	2012 10 04 - DSC_2965.JPG
Name:	2012 10 04 - DSC_2984.JPG
Name:	2012 10 04 - DSC_2989.JPG
aeroknot is offline
Old 10-05-2012, 12:06 AM   #68
aeroknot
learning by doing
aeroknot's Avatar
Default leveling the elevator
the front block is the original 6mm balsa support that I did not use. I'm using it to make sure the elevator support is parallel to the CF tube fuselage.
I also tried to make sure it was level right to left.
The tape is to protect the portion that I do not want to sand. Learned from Fran's photos.
Name:	2012 10 04 - DSC_2991.JPG
Name:	2012 10 04 - DSC_2993.JPG
Name:	2012 10 04 - DSC_2994.JPG
Name:	2012 10 04 - DSC_2996.JPG
Name:	2012 10 04 - DSC_3011.JPG
Name:	2012 10 04 - DSC_3000.JPG
Name:	2012 10 04 - DSC_3006.JPG
aeroknot is offline
Old 10-05-2012, 12:14 AM   #69
aeroknot
learning by doing
aeroknot's Avatar
Default balancing the wing
Balancing the wing left to right
I'm glad this is my practice build wing, because I've learned -
1. how to CA - with thin non-directional CF, lay the thin CF down and use a tiny needle to limit the amount of CA, use kicker or make sure the CA is hardened
2. in general, use tiny needles or nozzles for the CA, and store upside down.
3. I still have a 'heavy' hand with the epoxy.
Name:	2012 10 04 - DSC_2966.JPG
Name:	2012 10 04 - DSC_2969.jpg
Name:	2012 10 04 - DSC_2970.JPG
Name:	2012 10 04 - DSC_2972.JPG
aeroknot is offline
Old 10-05-2012, 12:24 AM   #70
aeroknot
learning by doing
aeroknot's Avatar
Default wing retaining
I placed the front peg of the wing against the front former, marked where the hole should be, then hand drilled it starting with a thin drill bit and progressing to the proper size. So, the fuselage and front former are all glued before drilling the hole, so the hole ends up in the right place.
For the retaining screw further back, I measured the distance from the front former to the block in back, placed the wing peg in a hole with the wing upright - photo - then marked the previous distance.
Then, 3rd photo, I double checked the mark - looked about right - before drilling.
Name:	2012 10 04 - DSC_2977.JPG
Name:	2012 10 04 - DSC_2975.JPG
Name:	2012 10 04 - DSC_2981.JPG
aeroknot is offline
Old 10-05-2012, 12:36 AM   #71
aeroknot
learning by doing
aeroknot's Avatar
Default tap
I used a drill bit one size smaller than the recommended drill bit size for the tap I'm using, since the tap is through wood and not metal.
I tapped the threads through the fuselage block and through the top of the CF tube but not through the bottom. My screw will of course not enter the CF tube, since that is where the control kevlar fishing line runs, but I wanted to get a good tap through the wood. Thought about squirting some CA in the hole to firm up the wood, but I don't want to make the taped hole threads brittle.
the retaining screw tap is specified on the plans as M3 - 3mm.
I have on hand a 4-40 English size tap, which is about 2.8 mm diameter and a selection of 4-40 nylon screws. I also have I think an 8-32 tap, whatever, which is 4mm and no corresponding screws.. so I used the 4-40 tap.
Photos - no tap photos, but maybe the tap hole is visible on the fuselage - the wing photo is pre-tap, I think.
Name:	2012 10 04 - DSC_3003.JPG
aeroknot is offline
Old 10-05-2012, 11:52 PM   #72
aeroknot
learning by doing
aeroknot's Avatar
Default Vertical stabilizer
First (first two photos), I checked the fuselage aft wing section fuselage sides height and angle - the bottom of the wing should line up and be parallel to the bottom of the horizontal stabilizer, otherwise, the fuselage sides need sanding. On first check, looks like it will be good. I'll recheck after the horizontal stabilizer is glued on.
[I beveled the vertical stabilizer so that the hinge line trough for the rudder will be on the right, for a right side control arm, for a right handed thrower. Maybe should be opposite for a left handed thrower? So looking from the top, the rudder hinge line will look like this l< . I'll post a photo of the hinge later, when hinged.]
I drew some guide lines, slid the vertical stabilizer - it was a tight fit but not too tight. So I used some non-stretching fishing line for the two wraps, then CA'ed it all at once.
I'll use the same fishing line for the control lines to the control horns from the servos. The fishing line is some type of kevlar dacron type material and does not stretch.
Next, I'll drill the hole for the tiny tube for the control line for the rudder, and install the tube and then on to the horizontal stabilizer.
Learning by doing.
Name:	2012 10 05 - DSC_3013.JPG
Name:	2012 10 05 - DSC_3014.JPG
ID:	163157 upside down
Name:	2012 10 05 - DSC_3017.jpg
Name:	2012 10 05 - DSC_3066.JPG
Name:	2012 10 05 - DSC_3021.JPG
ID:	163162 fishing line - does not stretch
Name:	2012 10 05 - DSC_3022.JPG
aeroknot is offline
Old 10-07-2012, 12:48 AM   #73
aeroknot
learning by doing
aeroknot's Avatar
Default control line tubes
Tape to protect the CF tube.
Used thin hard wall fuel line tube, probably outer diameter 3/32 inches, just over 1/16.
Used the power drill at about 30 revolutions per minute straight down using a 1/16 inch bit followed by a 3/32 inch bit.
Then drilled an angled hole - 1/16 inch bit followed by the 3/32 inch bit. I drilled the angled hole through the vertical stabilizer.
Then placed the thin hard wall fuel line tube into the hole, a tight fit so no need for CA. May need to tie it down. Tested with the kevlar fishing line I posted a photo of before and no binding.
Name:	2012 10 06 - DSC_3070.JPG
Name:	2012 10 06 - DSC_3073.JPG
Name:	2012 10 06 - DSC_3075.JPG
Name:	2012 10 06 - DSC_3076.JPG
Name:	2012 10 06 - DSC_3083.JPG
Name:	2012 10 06 - DSC_3077.JPG
Name:	2012 10 06 - DSC_3085.jpg
aeroknot is offline
Old 10-07-2012, 12:56 AM   #74
aeroknot
learning by doing
aeroknot's Avatar
Default Gluing the horizontal stabilizer on
Gluing the horizontal stabilizer on -
Used the magnets again to hold everything in place. Used Titebond II again.
The horizontal stabilizer was moved forward after the third photo.
Angles to make sure the horizontal stabilizer is perpendicular to the vertical stabilizer.
Name:	2012 10 06 - DSC_3086.JPG
Name:	2012 10 06 - DSC_3088.JPG
Name:	2012 10 06 - DSC_3089.JPG
ID:	163180 The horizontal stabilizer was moved forward after this photo
Name:	2012 10 06 - DSC_3091.JPG
Name:	2012 10 06 - DSC_3099.JPG
Name:	2012 10 06 - DSC_3100.JPG
Name:	2012 10 06 - DSC_3103.JPG
Name:	2012 10 06 - DSC_3121.jpg
aeroknot is offline
Old 10-07-2012, 01:00 AM   #75
aeroknot
learning by doing
aeroknot's Avatar
Default horizontal and vertical stabilizer - all square
Was going to skip the kevlar strip on the horizontal stabilizer, but realized that the kevlar strip also protects the CF tube at the control line tube hole.
Name:	2012 10 06 - DSC_3125.JPG
Name:	2012 10 06 - DSC_3126.JPG
Name:	2012 10 06 - DSC_3128.JPG
Name:	2012 10 06 - DSC_3129.JPG
aeroknot is offline
Model Airplane Building Clinic >> Begins 29 Sep. All Skill Levels Welcomed Murocflyer General Electric Discussions 282 11-04-2012 10:35 AM
Model Airplane Building Clinic Murocflyer Scratch and Kit Built Aircraft 2 10-01-2012 10:53 PM
Model Airplane Building Clinic - - Instructors Needed Murocflyer ParkFlyers 9 09-21-2012 01:55 AM
Page generated in 5.68920 seconds with 153 queries
